Question about KitchenAid Architect Series II 29.7 Cu. Ft. Side-By-Side Refrigerator - Stainless-Steel
We have a kitchen aid model KS SS 48QMW01- serial number QR4543044. The unit wasnt cooling well last night but we had just put a lot of groceries in it. By morning, the food was cool, but not cold. I put a thermometer in and it was about 47 degrees on max cool. I took the top plate off, vacuumed all the coils and the fan. I then took the service papers attached to the unit on top and took the area called " service diagnostic mode" steps 1-7 and set the display by the instructions. Mode 1 and 2 showed a "1", when I switched to mode 3, the display just started to beep quietly, two beeps every 3 seconds or so and will not stop blinking or respond to resetting- even unplugging, replugging etc. We live in a coastal area on the west coast and the weather has been cool. PLease help
3 Suggested Answers
  • 3741 Answers
SOURCE: kitchenaid KSSC42QMS01 refer is beeping. display
three things to check out.
1)the fan wiring's are they getting cut in between or burnt or short.
2)if the wires are proper ,then its faulty fan motor the Fan needs replacement.
3) if the compressor relay is faulty then also fan will not work.the relay is located beside the fan and compressor.
if not familiar with checking a local repair technician familiar with your brand /model is advisable.
to get required parts you can get it from
www.repairclinic.com
or from www.partselect.com
its a common problem occurs many times and checking /replacing the listed parts solves the problem.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Posted on Oct 31, 2009
  • 5370 Answers
SOURCE: Kitchen Aid side by side
Fridge section not cooling and fan is not running.The fan should actually run, then only fridge section will get cold. ----------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.--------- But if fan is not starting to run, then how will cold air from freezer will get to the fridge section.They will just remain in freezer section and freezer will get bit more cool then required.--------- ------------ In some cases its seen, that freezer section gets over frosted and ice gets collected on the freezer fan too.And this causes problem.--------------
So first thing you try is , perform, manual defrost reset procedure.---------
The manual defrost reset procedure is as follows : ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. Then check, if still the fan is not starting to run in few hours then fan motor needs to be replaced.Its easy replacement.--------- Then see if the fridge section is getting cold or not.If still the fridge section is not getting cold with freezer fan running, then problem is defrost board.It has to be replaced.------- You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.
----------- This should help. Thanks.Helpmech.
Posted on Jun 25, 2011
Demo icon is on and some food wind stay frozen
if the machine has been put into 'Demo Mode' the cooling stops working. It is a special setting for when the unit is on the sales floor.... What is the model number and brand?
For Kitchen Aid the way to end DEMO is to hold the 'max cool' and 'cooling on/off' for several seconds until the control beeps...
Apr 12, 2016 | Freezers
Is this a Kitchen Aid? Is it possible to buy this circuit board from somewhere?
This is a kitchen aid. BUT!!!! it is an international model that was sold in countries with 220 volts. Look underneath the mixer for a white tag it should have a model number and a serial number, if you can get us those numbers then we can help with the parts. Hope this helps.
Nov 05, 2014 | Food Mixers
Kitchen aid ksss42 not cooling fan runs
With this particle number you gave there are over 40 different models. So I seek a better model number or a complete number to assist you better. Some models had a inverter to control the compressor and I have seen failure due to heat or surges. But without a model number to verify I can't and won't direct you on a fish hunt without the correct information. Get back to me with more information please.
Aug 25, 2014 | KitchenAid Kitchen Aid 42" Built In...
Where do you find the serial number for a 5 quart glas bowl for the Artisan mixer
The serial number for all KitchenAid mixers is located under the base of the mixer. You will need to carefully tilt the mixer over, and underneath the mixer you will find a label with the model number and serial number.
Feb 16, 2013 | Kitchenaid 5 Quart Glass Bowl Artisan...
Intermittent beep on kitchen aid refrigerator
Your unit is a built-in and your power board had failed, I need a model number to help you further. Normally its located at the top of the unit, also to follow should be flashing display in the refer section, than lack of cooling. Then part expense is about 150 or so, depending on were you live and get the part.
Hope this helps...
Jul 15, 2011 | Refrigerators
Hi my unit wont turn on i have put new batteries in ?
for this you will need to send the unit into their repair at 8500 marshall drive lenexa ks 66214 4-6 week turnaround and put your name address and telephone number inside the package. if there is a cost they will send an estimate.
Mar 14, 2010 | Bushnell MOONLIGHT Night Vision -...
PUT THE OVEN ON SELF CLEAN AND IT DIED
the operating feature i that it will not let you open untill the oven has either fineshed cleaning or the oven has cooled off
Oct 29, 2009 | KitchenAid KESC307 Electric Kitchen Range
Beaters
KitchenAid Turbo Beaters - Stainless Steel
Model: KHM2B
$14.99
Features:
Replacement or Extra Set of Self-Cleaning Stainless
Steel Beaters Mix Cookie Dough Easily.
Turbobeaters fit only Hand Mixers manufactured since
September 1997.
If you have a model produced before 1997 please call
the KitchenAid Customer Satisfaction Center at
1-800-541-6390 with the model and serial number from
your hand mixer for further assistance.
Mar 23, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
KitchenAid Architect Series II 29.7 Cu. Ft. Side-By-Side Refrigerator - Stainless-Steel Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
