Question about Cameras
Can someone help out. I have a 058 model tripod, a good old work horse, I want to take the head off and replace it with a #268. the problem is, how do you remove the head? I have removed the 3 small screws from under the base, but nothing gives. What am I missing?? Thanks. Geoff.
  • thePonderosa Sep 05, 2010
    That done the trick. Many thanks. The old head has never been removed, bought the manfrotto 058 in the 1970's , I did not want to put force on it in fear of stripping any thread, locked the head down tight and put a little bit more effort into it, and bingo it came loose. Thank you, appreciate the help.
    Thanks.
    Geoff.
    Very helpful. Job well done, Thank you. Geoff.
  • 3,083 Answers
After you remove the 3 screws, you have to unscrew the head itself (it's threaded by a bolt in the middle). This video on YouTube shows the process:
http://www.youtube.com/watch?v=FvB-RhZ2Sds
This should work! Please rate this answer if it helped you, thanks!
Posted on Sep 05, 2010
Hi, I have just bought the 190CXPRO3 carbon fibre
Little confused here. Is the head the part you want to detach from an older set of legs? Do you want to remove center post from new legs or old legs. The base plate remains on the center post/ Aftre removing 3 set screws, and you want to remove the head from the baseplate and it will not turn, grap slip joint pliers or a pipe wrench, wrap the jaws with cloth ( to prevent marring of head or legs) and while holding head with wrench, have someone else turn legs
Apr 26, 2011 | Manfrotto (190XB,128RC) Tripod
I can't get the ball head off my tripod. I've loosened the set screws at the base, but the head won't budge.
You can try this:
spray lubricant between ball head and base, wrap the ball head with a heavy rag( to help prevent scratches, use a pip wrench on ball head while someone else holds legs ( or also wrap legs in cloth and hold in vise). DO THIS AT OWN RISK
Dec 04, 2010 | Manfrotto (Distributed by Bogen) 055XB...
The head of my dynex tripod is loose how can this be repaired?
There are some brands of tripods that are made for the retailer and the name is licensed, so the name brand does not support or stock repair parts. Especially if the tripod is an inexpensive one. Because of the model and make of you tripod, I would recommend you throw it out and buy another one. In my opinion Slik and Manfrotto are two very good ones. Slik for the lesser expensive and Manfrotto for the more durable, expensive, parts are almost always available unless is it really old tripod. Find some Manfrotto tripods at: www.BogenTripodParts.com
Sep 13, 2010 | Dynex 60" Universal Tripod
I have a Manfrotto 058 tripod. One leg wont hold weight & retracts under load. This model uses a quick release lever at the top of the leg to control the telescopic height of each leg. How can I repair...
If you notice, the legs locks are attached to bothe the upper part of the leg and the sloghtly smaller diameter lower. Take a socket (8mm I believe) and tighten the lower 2 nuts to the bottom of the leg lock.
Feb 12, 2010 | Bogen Communication Bogen Manfrotto 3030G...
The quick release tab is on the top but there is no plate for a camera to mount on to...guess it's lost. no serial number on the tripod. Brushed aluminum legs and it's got to be about 8 or 9 years old. Can...
Unfortunately not. It's a budget, no-name model with absolutely no back up support so you have no chance of buying a replacement quick release plate. The plates themselves are not standardised and are not only unique to each manufacturer but often not even standard within a single manufacturer's product range.
You'll only get the kind of support you're after from established brands such as Velbon, Slik, Benbo, Manfrotto to name just a few.
If the basic tripod is still solid though you can usually unscrew the head from the tripod and replace it from another one (doesn't usually have to be the same make/model) which has suffered leg damage. To remove the head on most models you tighten the locking screw which prevents the head from panning and then turn the head firmly counter-clockwise. The screw thread which holds the head assembly is usually a universal one.
If you have ALDI or LIDL stores in your country they regularly sell surprisingly good tripods with a no-quibble three year international warranty for around £10. They come complete with a carry bag and spare quick release plate. Neither company has any at the moment but they regularly reappear in their weekly specials listings.
I hope that you've found this posting to be of some help even though it's undoubtedly disappointing news. Please return the favour by rating my answer.
Oct 21, 2009 | AmbiCom V0552 Tripod
Head will not tighten on AF2100 Pistol grip
one of the treads in the tripodas head is broken try unscrewing the grip the other way to remove it, then examine the grip, if one of the threads on the part of the grip that screws in to the head, is broken then you might be able to get a new grip, and that might work, but there might also be damaged threads inside the tripod head, in which case you neet to replace the head if you can, but if you cant, then I do not think that you can repair that tripod
Aug 01, 2009 | Slik PRO 700 DX Tripod
Broken vinten tripod spreader
found these guys online and they sell the parts.
Steve Jean-Charles
The Vitec Group plc
Camera Dynamics Inc.
709 Executive Blvd.
Valley Cottage, NY 10989
USA
p. 845-268-0100 Ext: 147
f. 845-268-0113
e. steve.charles@vitecgroup.com
http://www.vitecgroup.com
Mar 28, 2008 | Vinten 3394-3 Lightweight Calibrated...
Cameras Logo
22 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
