Question about Canon Optura Pi Mini DV Digital Camcorder
I have Canon optura Pi (I think since 2001). Now periodically I have a problem - sometimes focus goes down and picture become blur. Later on focus returns.
4 Suggested Answers
  • 15 Answers
SOURCE: blurred pictures
Batteries don't play a role in it. Maybe it has slow focus. Try to push the shooting button to only half of its full push, wait a while until it focuses an then shoot by full press on the shoot button. You can also check if you have not switched on macro settings (flower in frame). If you do, turn it off.
Posted on May 30, 2008
fotobean
  • 103 Answers
SOURCE: I have a canon ixus
Believe it to be a camera fault. Reason: zoom feature makes the lens extend for telephoto work, therefore, the autofocus feature should be working at any distance you set the lens for and your shots should be clear. Could be an autofocus problem or the lens and CCD are misaligned at the telephoto position. Have the camera checked by a qualified repairperson. Get an estimate first. You may want to ask this question at the Canon website also.
Posted on Sep 01, 2008
  • 11967 Answers
SOURCE: My canon 1100 powershot camera
Have you checked for a fingerprint on the lens?
Posted on Aug 30, 2010
When TV is inititally turned on the picture is perfect. After a few minutes or more, the picture becomes blurred. On a scale of 1-10 (10 best) the view is about a 6-7. What can I expect? What are the...
That sounds like the focus is going out of specification due to a dry solder joint or bad connection.
Checking the EHT distribution box for a bad connection could be fruitfull.
Use utmost care as lethal voltages are at this point!
If the picture recovers slowly it could be a tube base problem.
I don't think it will be much other than the Focus voltage is going up and down.
Jan 02, 2011 | Toshiba Televison & Video
Canon Optura Pi Mini DV Digital Camcorder. The metal compartment holding the tape won't open. Battery is charged, everything else works. Cannot remove the tape.
Tape mechanism malfunctions can be due to many factors. A bad gear is the most likely cause and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be diagnosed by a qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Sep 01, 2010 | Canon Optura Pi Mini DV Digital Camcorder
Optura Xi no longer reads audio or video
Dear Movie maker,
Well seeing you did have only drop-outs in sound, but did get a picture, now you have nothing.
This does look like you have moved quite a bit of the dirt within camera pic/sound heads, I did say moved (not removed) because these dry cleaning things we use today do only move dirt not get shut of it.
I think you should put that cleaner in camera again, and give it a really good run through, let me know how that goes okay?
Jun 05, 2010 | Canon Optura Xi Mini DV Digital Camcorder
Optura Pi Mini DV Digital Camcorder: I connected to AC and recharged, turned on and got...
yes i think; if you can find a good tech he should be able to make the mechanism alignement and clean out debris could be in the mechanism but he can charge you more because its as been open..
and clean the mode switch all that can be done with out parts replacing beleive me i know! because i fix a lot of camera and cam corder
hope that will help you..
regards Alan...
May 18, 2010 | Canon Optura Pi Mini DV Digital Camcorder
Eject mechanism not functioning
Once when this happened to me, I took it to a repair shop and they said it just needed to be cleaned. (Optura PI tape won't eject)
    Dec 28, 2009 | Canon Optura Pi Mini DV Digital Camcorder
    Borders bowed inward,blurred red,blue, & green
    the next time it is not working go into the customer menu with remote and call up the convergence grid and look---there---if convergence is way off and or comes and goes---this set uses 2 Stk-392-570 ic's and it is quite common to see them become intermittant.
    Aug 03, 2009 | Mitsubishi WS-65809 65" Rear Projection...
    Blurred pictures
    May 30, 2008 | Canon PowerShot A530 Digital Camera
    Canon Optura Pi Mini DV Camcorder
    you can use software to capture it on your computer and burn a DVD, or there are services that will do it for you for a reasonable price. Windows Movie maker will do it if you can load it on your computer. If you are not familiar with the technology then just use one of the services. Most large cities have them or you can us an online service.
    Jan 22, 2018 | Canon Optura Pi Mini DV Digital Camcorder
    Sony E530 focus (?) problem
    I think it can solve with this way:
    Press Menu on the front panel of the monitor. Then press OK button and go down and go to COLOR : PRESET. Press OK and go down. Press IMAGE RESTORATION.
    My E530 monitor is more clearly, now.
    L.E.
    Sep 23, 2007 | Sony Multiscan E530 (White) 21" CRT...
    Optura Pi is eating tapes
    hi from what i understand by "eat" is that the coil is popped out what it means is that the coil leader is misplaced and letting it to run free out of place this can be fixed by you if you will find what had gone wrong in that path (broken pin, cog etc...) and glue it back or fix the missing element in place good luck
    Apr 27, 2006 | Canon Optura Pi Mini DV Digital Camcorder
    Canon Optura Pi Mini DV Digital Camcorder Logo
    Top Canon Video Cameras Experts
    Pieter Vleeshouwers
    Pieter Vleeshouwers
    Steve Mason
    Are you a Canon Video Camera Expert? Answer questions, earn points and help others
