Question about Roper Washing Machines
Bad belt - Roper Washing Machines
  • Roper Master
  • 8,220 Answers
My serpentine belt fell off and i noticed a bolt that has backed out which caused the belt to come off what do i do to keep the belt from falling off again
Most common cause of belt loss is either a bad tensioner pulley or a bad idler pulley. I had a van with the same issue and after the mechanic replaced them along with the belt, no more problems. Could also be a bad device that is driven by the belt like an airconditioner compressor.
Sep 03, 2015 | Cars & Trucks
My belts are rubbing my timing chain cover into
cam timing belt.
can be caused by may things, here is the list.
1: bad belt, internal strands snapped cause run off.
ever roll a belt in hands, (see new box, it says that)
2: cogs, not aligned, (bad head job? , lost alignment pins)
its only 2 ways but lots of ways to get there.
including running the old used belt backwards,
does a new Gates belt to that ,. or is a no name china clone belt.
The Gates, will run true,and last longest
the idler , bad, and canted can do it too. (bearings shot in it)
http://www.fixkick.com/t-belt/drift.html
Dec 26, 2013 | 1997 Geo Tracker 2 Door
I have a howling sound when i start my car. open the hood sound likes its coming from where the belt is. is it time to change
depends on which belt... quick check is to buy a smal spray can of ''belt dressing'' at a auto parts store.... if after spraying the belts it continues, it can be a bad belt tensioning device, or bad / worn vbelts, or maybe a water pump bearing. if it is the belt to the alternator, it could be a bad bearing in the alternator, ac compressor, or even the power steering belt, tension device... a lot of variables....
Nov 19, 2011 | 2000 Buick LeSabre
My engine upon starting squeals and gets louder when i accelerate, every once in s blue moon it will stop for a few mins or quiet down????? help
There are only 4 things that will cause a belt to squeal.
1. A bad/worn-out belt
2. A bad or misaligned pully or pulley bearing
3. A bad belt tensioner. (pulley, arm, pivot, or spring)
4. Malfunctioning or bad component (alternator, power steering pump, A/C compressor, etc.)
Remove the belt and check ALL pullies to make sure that they rotate smoothly and do not have any horizontal play in them (indicating worn-out bearings). Make sure that the tensioner pully swings freely and does not bind in its travel at any point and that it is properly aligned with the other pullies. A good way to check for proper alignment is to look at the belt position on the pullies with the engine running. If the belt is running on the edge of the pullies instead of in the center, it is usually caused by a bad belt tensioner or a bad bearing on one of the other pullies.
Check the belt for chunks missing, torn or cracked ribs or shiny "glazed" edges, ribs, or back.
Jul 22, 2011 | Mercury Mountaineer Cars & Trucks
Washing machine wont will wash but wont do anything else
Hello,Sounds like you have a broken belt or a bad motor. The easiest way to tell if the belt is bad is to reach inside the drum and turn it. If it turns very easily, you probably have a bad belt or something has caused the belt to jump off, such a s a loose pulley or bad bearing. If it feels like there is a good amount of resistance, or a kind of "winding up" noise, then the belt is still on and you likely have a bad motor. Also, you could just scoot the machine out, unplug it, and remove the back cover a look inside to see if the belt is still on the pulleys.
Thanks
May 21, 2010 | Washing Machines
The serpentine belt broke replaced it and i broke
a bad belt tensioner leaving too much slack in belt causes it to break.
Apr 01, 2009 | 1997 Volvo 850
Chirping Noise
you need to change the water pump
Dec 28, 2008 | 2002 Chevrolet Avalanche
Altenator belt breaking
Is this a single serpentine belt system or a V belt with 2 or more belts running the accessories? There is an alignment issue, another bad accessorie or bad bearing (quite possibley the new alt) or as mentioned a bad idler ( if a serpentine belt setup)
Sep 23, 2008 | 2004 Kia Optima
NEW BELT SQUEATS BADLY.
Make sure the belt is the correct length for your vehicle.. match to old one if possible. Double check belt routing to make sure its correct. Check for proper tension on the belt as well, common for tensioner pulleys to go bad after a belt replacement because of the excessive pressure used to release old belt. Hope this helps.
Aug 24, 2008 | 1999 Plymouth Voyager
Washing Machines Logo
20 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
