Question about Eureka 2961AVZ Bagless Upright Vacuum
How do I get the lower part off to clean the part for the floor
  • 33 Answers
The hood comes off with 2 screws on top of hood, behind the word Altima, out to left & right side.
Posted on Sep 05, 2010
How do I adjust height for carpet brush on DC28 Dyson animal?
Hi Laura, it's Jack at Dyson
DC28's selector pad (located by the red on/off switch) allows you to select the correct height setting for the particular flooring you're cleaning. Patented Dyson Airmuscle technology will then raise or lower the rotating brush bar within the cleaner head to the correct level for optimum performance, or shut it off for cleaning bare floors or delicate rugs.
I hope this helps, but if you have any further questions or if you're having difficulty with your DC28, you're welcome to get in touch directly. You can reach our experts by emailing askdysonUS@dyson.com
Mar 01, 2015 | Dyson Vacuums
My bissel lift off deep clean wont spray water or solution on floor? any tips
the spray nozzles are probably plugged they are like the ones on your car.unscrew the lower part of the head unit should see them there.
Jan 01, 2015 | Bissell Vacuum, Lift Off Deep Cleaner
Floor piece will not rise and lower to clean floor
Most mechanical problems with vacuum cleaners are caused by ingress of dirt causing seizure of moving parts.
Aug 17, 2014 | Vacuums
Can't lower handle on Hoover u6432-900 so can't clean floo
usually theres a plastic pedal you would step on to release the handle.... first thing i would try is pushing up (foreward) on the handle and try pressing the pedal .if the pedal wont push down at all then something might have gotten jammed down in it..... at which point you'd have to do a bit of fiddling around with it to see whats keeping it jammed up.....also... there could be something stuck in there thats keeping the handle from being able to move down.... as for the self propelled part.... it probably wont work untilthe handle is lowered... hope this helps
Nov 12, 2013 | Vacuums
My ez1 Monster Floor Steamer - green light goes off when I lower the handle and stops steaming
It could be calcium deposits in the tank. Clean it with white vinegar. Good luck!
Nov 10, 2012 | Euroflex Ez1 Monster Floor Steamer -...
The vacuum seems to have lost a lot of suction power and it is only a month old. Seems like there is a clog or something, all filters are cleaned and after a vacuuming session, nothing is in the...
sounds like there is blockage in the suction hose -- lay the machine down and remove the lower floor plate and clean out the hose area where it bends down to the floor unit ( use a wire coat hanger to fish out the blockage ). also check the main hose for any obstructions.
c...
Feb 17, 2011 | Bissell Cleanview Helix Deluxe Bagless...
Henry brushes seem to catch in the carpet when pulling-will the brushes soften and make it easier to use as it makes the head bounce of the floor a bit when pulling making it harder work to vacuum?
There is a "see-saw" type switch on top of the cleaning head (the part that you push across the floor). This raises and lowers the brushes according to the type of floor you are vacuuming. Move this switch to the other postion and you will find that it runs over the carpet more smoothly.
Nov 05, 2010 | Henry Vacuums
I have a Harmony vacuum and need it only for bare floors. The attachment I have seems to be too rough on the floors. I just need a simple attachment with soft bristles for a bare floor that will fit this...
Take the lower portion of your wand to a vac shop and ask for a universal fit wide floor brush with NATURAL bristle. The soft bristle is much better quality and will clean deeper into grooves in your wood floor or and tiled area.
Dec 26, 2009 | Electrolux Harmony Canister Vacuum -...
Troubleshoot floormate spinscrub 800 floor cleaner
The brushes are not designed to scub the floor, they only lightly touch the floor. Make sure the front nozzle is put on correcdtly. Make sure your filter is dry and clean. I wet filter will give poor suction down to the nozzel. Down load the manuel at Hoover.com. The model is located on the back of the unit. H3000, or H3010
May 24, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
I cannot figure out how to use my cleaner floor mate
At the risk of giving a simplistic answer, let me go through the steps I go through every time I use mine:
1) Plug it into the wall
2) Take out the upper "hopper" and fill it up to the fill line with hot water
3) Put in the capful of cleaning solution (about 2 oz.)
4) Gently swish it back and forth, then put back into upper unit until it clicks into place
5) For best results, set the vacuum on Dry and vacuum the house first, then clean the lower "hopper"
6) Set the vacuum to Wet, put the scrub brushes on, depress the trigger and do overlapping strokes, a section at a time I depress the trigger on the push stroke, then release it for the pull stroke. I clean a section, then turn off the scrub brushes and go over it again without the scrub brush or touching the trigger (trying to pick up as much water as possible).
On average, when refilling the water/cleaner solution for the top hopper, empty and clean the lower hopper. When the floors are finished, completely clean that lower hopper or it will smell!
Hope this helps...
Jul 18, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Eureka 2961AVZ Bagless Upright Vacuum Logo
20 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
