Question about Refrigerators
I have a Goldstar GR-151SPF. I can't figure out how to set the control knob to make it warmer, because there are only numbers on it, and I've tried setting it to 2 for a couple days, then setting it to 9 for a couple days but everything is still a little frozen.
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: I have a Goldstar small
Hi and welcome to FixYa, I am Kelly,
Warmest settings are CCW and COLDER settings are clockwise on the control. Use the numbers as a reference point but... CCW = warmer Clockwise = COLDER
Thanks for choosing FixYa,
Kelly
Posted on Feb 25, 2011
Whirlpool refrigerator is freezing foods . need to reset temperature to default settings. how do I do it
If the temperature control is a knob turn it to a warmer number. If it's a digital control try a warmer setting. It's possible the digital control board has failed.
Nov 19, 2017 | Whirlpool Refrigerators
How can I turn up the fridge settings. It's not cold enough
you need to turn down the settings of a fridge --the lower the number on the control knob the colder the fridge
it is the freezer that the system is reversed where the lower the number the warmer the freezer
Sep 06, 2016 | Refrigerators
Frigidaire glass top stove dual element ony works on high no matter were knob is set
Hello Chad;
My name is Peter. I am a retired field service appliance technician.
It sounds like you have a bad Warmer Infinite Switch.
Once installed, the switch controls your gas range's warmer drawer element. When replacing your gas range's switch, consider replacing its knob (PartsDirect part number 316442403) if it shows significant wear.
To replace your gas range's warmer infinite switch, pull the knob off the switch and remove the screws securing it. Disconnect any wires running to the switch and take note of those connections. Remove the switch and put the new one into its place, reattaching the wires to the same terminals. Be sure to unplug your gas range before beginning the repair.
25433033-yqd4wkymfcifmtxqtu0sd2am-5-0.jpg Part #: 316095500 Cost: $32.00
It is located on the right hand side of your display panel. You have to remove the side panels screws and control panel back to access.
Feb 15, 2015 | Frigidaire Kitchen Ranges
Temperature
Hello R, thank you for your question! Generally speaking it is recommended that the temperature knob is set in the middle for both the refrigerator and freezer compartment for top mount refrigerators. The temperature can be adjusted by moving the knob in small increments, allowing the temperature to stabilize. If you desire a colder temperature, then turn the knob towards COLDER, or for warmer temperature, turn the knob towards COLD. Turning the refrigerator control will change temperatures in both compartments. For example, if the refrigerator control is turned to a colder setting, the freezer control may have to be adjusted to a warmer setting. Turning the freezer control will only change the freezer temperature. Hope this proves to be helpful!
Jul 22, 2013 | Refrigerators
What is the optimal setting for controller dial
If you asking where the humidity extraction knob should be set for optimal humidity extraction. It should be set just below Maximum. Im assuming you have a manually controlled unit, rather than one with an LED screen. If that's not the case lower the numbers using the air down button to 35%.
Hope this helps you and thanks for choosing FixYa.
Jul 25, 2011 | Goldstar DH304 Dehumidifier
I have a Goldstar small refrigerator GR-151SPF which is presently freezing the contents. Please tell me if high or low numbers make the frig colder. Thank you.
Kelly
Feb 25, 2011 | Goldstar Refrigerators
My food is freezing in the refrigerator section. It is a GE adora
yes try lowing your number on your t-stat knob. and also the other knob should control the amount of cold air coming from the freezer to the ref. u want to make freezer colder that makes ref. section warmer. and that help. try this ok. later gator.
Feb 17, 2011 | GE Adora (DSF25KGTBG) Side by Side...
What is the lowest setting on the temp on a Hotpoint Ctf18ga
Hello Dustin,
Typically the lower the Letter or Number is the warmer setting for the freezer or fridge section. If you want to make them colder, move the control setting ONE (1) increment at a time, in any 24 hour time period (up or down) and allow the fridge to adjust before making another change in the settings.
Again, A is warmer than B, and 1 is warmer than 2, and so on. So going to a higher letter or number, will make the unit colder.
Just remember it will take at least 24 hours for your unit to adjust and compensate for the changes, so only make them gradually, so you can tell if you've reached the desired cooling settings for both the fridge and the freezer. Typically, most manufacturers recommend that the starting position be in the middle of the dial and that you adjust them up or down from there.
I hope you find this Very Helpful and best regards!
Dec 24, 2009 | Refrigerators
Refrigerators Logo
434 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
