Question about Acer Aspire 3000 Notebook
Powering up have built two out of one but doesn't power up is there an internal power supply that could have gotten burned up! and where is it.
    Champion:
  • 230 Answers
How can you build 2 laptops from 1 laptop ?
Posted on May 12, 2008
Konica Minolta biz.C-253 intermitent power shut off
what is a crowded power source????? a machine like that should have its own surge protector and proper plug connections
Aug 25, 2014 | Konica Minolta bizhub Office Equipment &...
Sharp tv
The MOST LIKELY problem is in your power supply inside that will require either a good deal of technical skills AND desoldering equipment, OR a ton of grey matter and a burning desire to learn something new, (in which case you're subjecting yourself to possible severe electrical shock). To go on, you'd need an ESR tester to check out the status of capacitors AFTER you've located the power supply internally. IF you've gotten this far, you CAN order exact replacements from Digi-Key in Thief River Falls, Minnesota. PLEASE pay attention to my word of caution about electrical shock, and I wish you well.
Jun 28, 2014 | Televison & Video
Macerator is not working
Replacing the Power Supply in HP Pavilion p6000 p6 1000 and p6 2000... BestBuy, MicroCenter, Amazon. Very cheaply priced, very functional. Even the generic brands. Hope this help.. have a great day. OH, make sure you at least match the current power supplies WATTs and it's connection. ? if your information is correct "power supply"
Feb 09, 2013 | HP Presario Computers & Internet
Have a 400 watt power supply just bought e6700 CPU should I Change power supply
You can never over kill on your power supply. I would get a power supply in the 600 or 700's range there just more reliable. I have built my computer and i have duel video cards and stuff but i went just a tad over for my power supply doesn't have to try all that much. If you buy a new one get one with a fan its much better.
Mar 11, 2012 | Intel Computers & Internet
My computer was knocked forward it went bang and then smelt of burning - I have been told that it might be the internal powe pack can you help?
If your desktop computer went bang from the back of the computer and the burnt smell comes from the fan grill of the power supply then the switch mode power supply definitely failed. The bang and burning smell was probably one or more of the capacitors that has exploded inside the power supply.
You can replace the switch mode power supply, make sure you purchase one that has the same total wattage or higher wattage.
There is a chance that when the power supply failed it may have caused a voltage spike that could have damaged some other components. You won't know until you replace the faulty power supply.
May 19, 2011 | Computers & Internet
Fan is making a clicking noise
which fan ?? the processor or the power supply fan.. if it is clicking the bearings in the fan may b going out or somthing has gotten inside the computer an the fan is hitting it.. But more likely the fan is going out if it is power supply replace it if it is the processor replace it before your processor overheats an burns up..
May 01, 2010 | Dell XPS 410 PC Desktop
Power supply not working?
To see if power supply works
unplug the psu from the motherboard and drives
then plug the power cord into psu and wall
the fan should come on letting you know that it works.
you can also get a multimeter and check each individual connector on the 20/24 pin connector to motherboard.
check the psu docs for the correct voltages to each pin
If you smelled smoke then chances are that something may have gotten toasted.
remove all expansion cards and try to turn on computer if nothing happens then the motherboard may have gotten toasted.
Check the motherboard and expansion cards along with memory for shorts and burn spots.
A+ Technician
Apr 02, 2009 | HP HEC HP485D 485W ORION HP485D ATX 12V...
Does item have a fuse? Burned out
i have the same one ...and i'm not seeing a fuse, there may be one internally
does the inverter have strong "burnt wire" smell if so it is probably fried.
Aug 16, 2008 | Vector VEC 024 400-Watt Power Inverter...
TV wont turn on due to power outage
I know it's been a while since you have sent this request, but if you havn't gotten any help or repaired the set by now, I'll try to help if I can. Your set has a seperate power supply board internally. The fuse could be burned out on that board. Also if you did in fact get a power surge, you may have a capacitor or a series of capacitors bad. Check the fuse first and if this is not the problem, I suggest you replace the power supply board as they are not real expensive. Good luck and I hope this has helped in some way
Ed Meshechek ( Radio Man )
NC Electronics
Mills, Wyoming
307-266-4675
Jun 01, 2008 | Olevia LT37HV 37 in. HD-Ready LCD...
Board power up failure
Well the say never answer a question with a question, so i will simply post 2 answers.
1. If you built the PC yourself, you may need to look at power requirements for this particular motherboard and perhaps transplant the board into a case with a larger power supply.
(ie: 300, 350 watt power supply or better )
2. If this is an older PC and someone else built it for you, you may need to consider that power supply units do burn out in time and may need to be replaced.
The power LED simply means there is power coming to the light itself, but may not be enough to sustain an entire motherboard and components etc.
This to me sounds very much like either the power supply is too small or burned out.
Jan 12, 2008 | ASUS P4VP-MX Motherboard
Acer Aspire 3000 Notebook Logo
14 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
