Question about Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower
I have my starter spring back into my pully but i can't figure out how to put it in the mower and everything else
How do u remove recoil spring assembly that is held in place by a roll pin on a 4hp Briggs and stratten
I suspect you asked this question because your recoil starter rope has broken , so first let me say be extreemly carefull the coiled spring on top of rope pully has a lot of tension to it , it can and will hurt you if it gets out of the pocket it sets in, what ive allways done is to NOT remove the pully at all but hold it with a large C clamp i put this on right after i get about 6 good turns to tighen the spring then i apply clamp , use a razor knife to cut ball off end of old rope and pull out using pliers thread new rope from outside rope guide to into the rope pully and knot if off in original hole (use a lighter to part melt rope end) measure off about 5 feet of rope and tie starter handle on there then its simple just slowly let clamp pressure off the pulley will pull rope in to cover automaticly done !!!
Aug 24, 2014 | Mtd 22" Yard Machine Push Mower
Starter pins
the pins are spring loaded if they fell out then the pully is bad when you get the pully starter you get rope and new pins pay attention how you take it out you have to put it back the same way you took it out
Apr 20, 2014 | Garden
Recoil starter repair
It sounds like the spring has come loose or broken. Remove head and see if you can twist by hand. If it feels like it's tightening then spring is ok. Let it go then remove cord with knife and turn winder back until tight. Feed string pully through and knot the end.Release inside of pully and it should work.If this dont work it will need a new spring.
Jun 25, 2013 | Cub Cadet Garden
How do I put the drive belt back on my yard man automatic riding lawn mower?
The v side of the belt goes in the v of the pullies and the flat side of the belt rides on the flat pullies. It looks like the flat idle pully is bent out of alinement. The one showing in video with no belt on it that is the last pully the belt runs on before returning to engine. The belt comes from the engine to a spring loaded flat pully, to v pully on right of mower ,to v pully on left, to flat idle pully // that looks to be bent // then back to engine. Put belt on all pullies saving the spring loaded pully for last.
Apr 09, 2013 | Garden
How to rewind the pull start spring on my murray push mower
you have to do with the sring through the pull start hole wind it clock wise it will attach to the pully and wind it up if you have a spring cartige you have to wind by hand and put it in the catrige wind in the direction of spring
Jun 13, 2012 | Briggs & Stratton Garden
Pull start cord got pinched. Dumb me took off
Yes you can put the spring back in but it takes patience. Wind the spring inside the pully first. Then install the cord on the outside of the pully. Make sure you wind both in correct direction. You probably should replace the cord while you have it apart. The parts would be listed by the engine brand and model number, not by MTD. Probably a Briggs & Stratton engine? You can go to their web site :www.briggsandstratton.com to get part numbers. Or you can try a place like www.jackssmallengines.com
Jul 18, 2010 | Mtd 22" Yard Machine Push Mower
Petrol Lawn Mower starter cord and spring problem
remove the shroud Ithe cover over the flywheel) and remove the old rope. now rewind the spring in the opposite direction of the string hole until the spring is tight. Then clamp it down so i won't unwind and reinstall a new rope (the same size) into the notch in the pully and tye a knot. then release the clamp and let the cord wind onto the pully(make sure the cord gose through the hole in the shroud. then replace the handle and reinstall the shroud back onto the engine..Good Luck
Apr 04, 2010 | Garden
How do i essemble a pull starter on a troy built snow thrower
to just put the rope in take starter cover off look inside the cover and turn thr pully to the left counter clock wise turn till it turns no more line up the two hole one from the pully and one on the starter cover where the rope was originaly put the rope in thr hole and tie a knot this is called preload has to have tention on thr pully to pull the string back but if thr spring is broke its another process
Frazier
Nov 01, 2009 | Troy Bilt 5.5hp Self Propelled Mower
How do I fix the starter pully
IF YOU TAKE THE TOP OFF AND TAKE TO A SHOP LET THEM DO IT SO YOU DONT GET HURT THAY WILL BITE YA
Sep 28, 2009 | Garden
Missing springs on deck pullies need diagram of deck for springs
Go to www.managemyhome.com and download the owners manual.
After that I would go to www.searspartsdirect.com and look at the pictures of your mower deck (again you need the model #). Once you figure out what you  need then all you have to do is order then from sears.
May 20, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower Logo
151 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
