posted by falco4 on May 12, 2008
I can't get my Sony DAV-HDX275 out of progressive scan. All I get is a blue screen, so I can't get to any of the menus to turn it off. I have tried what it said to do on the sony website and that didn't do anything.
Comment by falco4, posted on May 13, 2008
Thank you so much! I was about to bring it back to the store and now I don't have to!
Best Solution
posted on May 12, 2008
Based on your description, it seems that you set the DVD to progressive scan output, but have it hooked up to a TV (CRT) that cannot accept this signal. Because the TV can't accept the signal, you can't view the DVD menu to change the setting back to interlaced.
On the back panel you have "Component Video Out" for output via component cables, but there is also a yellow RCA connection labeled "Video Out". This is a "composite video" connection which does not support progressive scan. Try disconnecting the component cables and connect the composite video to a TV. The DVD will likely (hopefully) send a compatible signal (480i) through this connection, which will give you access to the menu.
Rating Locked! (?) falco4 has rated this solution as FixYa!
Suggest a new solution for this problem
Post a New problem for Sony BRAVIA DAV-HDX267W Theater
Email this problem
Email this problem
Can you Help with these Home Theater Systems problems?
Sony BRAVIA DAV-HDX267W Theater System with...
Cannot hear audio when connect...
I can see the video clearly... Answer This...
Center, L, R
Center, L, R
I just unpacked my Sony Bravia... Answer This...
Change region or make it free...
DVD HomeTheatre System Answer This...
flashing sequence lights
maybe not a... Answer This...
Sony BRAVIA DAV-HDX265 Changing...
I need to change the region... Answer This...
Repair Service
Find Home Theater Sys. Repairman Near You:
