Question about Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1
I have a 23 hp Briggs vanguard engine-V Twin Model 380447/type 76-E1 code 4241. The engine is less than two mowing seasons. The engine will not turn over properly and I have used another start I have and it does the same. I had the origionsal starter rebuilt and it does the same. I do not feel it is the engine. When I go on line and search for a new starter I see the Briggs starters are listed as one starter for a 8 through 23 hp engine. Is there a heavy duty starter or a starter just for the 23 hp. I am niot good at on line stuff....gary gws@gulfwidesafety.com
  • 4 Answers
It will probally be your valve setting might be off so pull the valve covers off and try setting your valve lash
Heres the factory settings
.006 on Intake
.008 on Exhaust
Posted on Oct 26, 2010
I have a 16hp v twin on a prusserwasher that bogs down under load
Check for intake leaks. restricted fuel line. air cleaner anf fuel filter.
Jun 14, 2013 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs and stratton vanguard 16 hp v-twin starter replacement
It most Likely is located under the engine cover..it mount just below the flywheel. Good luck
Apr 11, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Have a 23 Vanguard on a mud boat and when engine damp from dew or fog, engine turns over but will not start. When engine dries, starts right up.
Your coil may be getting damp or wet..try using a plastic bag over the coil..or use some spray that will keep the damness out..good luck..
Jan 04, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
18 hp vanguard 165lbs and 180 lbs compression have to hand turn engine past compression or starter wont turn engine over
if its hard to get the engine to turn past the compression release then pull your valve coversand try setting your valve lash
.006 on intake
.008 on exhaust
Oct 25, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Trying to find starter for 12.5 vangard v twin motor. my model number is 9108304 on starter but can't find anything the same.
anytime you deal with small engine parts you MUST be armed with the engine model number, code and type. on late briggs these are on one of the valve covers.
Feb 08, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
After about 30 to 40 minutes of use (varies, the
I have a 7 year-old craftsman mower with a 22 HP Briggs engine that has the same issue. After about an hour, the mower acts as if it is starving for fuel and then stalls. Then after about 5 minutes of sitting, it will run for a little while longer.
If your engine is similar to mine, then its carb has a fuel shut off solenoid which shuts off fuel to the Main Jet when Voltage is removed to prevent backfiring when the key is shut off.
Unfortunately, this solenoid can also cause the carb to starve for fuel when not working properly. In my case, when I cleaned the solenoid and the solenoid's connections, the tractor had no problem after that.
Hope that helps,
Steve
Jul 25, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Engine appears to run normaly until PTO is egaged,then it backfires and quits. Engine is an 18 HP Vanguard twin, model 350777.
Check you float in the carb I had one a few years back and it was partualy plugged cleaned it out and everthing worked fine. Also is the PTO binding up or bearings going bad putting an excessive load on the motor.
Jul 04, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Oil in air breather
sounds like you have too much oil in the engine (should normally be around 500-600ml when there is too much oil, it gets past the piston rings and pushes it through to the head.
May 20, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1 Logo
2,393 people viewed this question
Top Briggs & Stratton Tools & Hardware - Others Experts
Bill Boyd
Daryl Gleaton
obsteiner
Are you a Briggs & Stratton Tool and Hardware - Other Expert? Answer questions, earn points and help others
