Question about Craftsman 29cc 4Cycle Straight Shaft Weedwacker Gas Trimmer ()
Fuel line diagram for a craftsman weedwacker model number 358.798420
  • 246 Answers
SOURCE: I need to know the gas mixture ratio for a craftsman weedwacker
Hello mcguilmd:
>>All Two Stroke Engines will use a 50 to 1 Ratio using Today's Two Stroke Oils. I once had an Old Chainsaw probably from the 1950s, maybe Earlier 70s that had a sticker on it that said to use a 25 to 1 Fuel/Oil Ratio, but that would have been using Two Stroke Oils of the Time Period the Chainsaw was Manufactured. I was having a Problem with Oil Coming Out of the Muffler and Started Decreasing the Oil in the Gas. I Reduced the Oil Until it was a t a 45:1 Ratio and Decided to be Safe, I would Use a 40:1 Ratio Mix. In that Chainsaw I used 50 to 1 Ratio with no problems. Today's Two Stroke Oils compared to Yesteryears are more Efficient at Lubricating. It is like comparing Today's Synthetic Motor Oil to Motor Oils of Decades ago. All the Equipment I use in Landscaping, anything from a Weed Eater, Leaf Blower, Chainsaw, Hedge Trimmer, use 40 to 1 ratio, and I use all types of makes and models, Stihl, Homelite, Husqvarna, Shindaiwa, and Echo, Sears. I mix up a 5 Gallon Fuel can and use it in all of the Equipment for my Customers and for my Landscaping. I like my Fuel/Oil Ratio a Little Heavy, so I use a 40:1 Ratio. The Following was Copied and Pasted here from and MTD E-mail to me when I Asked for the OEMs Suggested Mixture for this Unit. The mixture, as described by the engine manufacturer, is a 50:1 ratio when using the approved types of 2-cycle engine oils.
50:1 ratio is a mix consisting of 2.5 ounces of 2-cycle oil per 1 gallon of gasoline.
The 2-cycle oil used should be approved and have one or more of the following specification titles: NMMA TC-WII, TC-W3, JASO FB, or JASO FC. NOTE: If unsure of the 2-cycle oil specifications, or the oil is not approved, use a 32:1 fuel to oil ratio. This ratio consists of 4 ounces of oil per one gallon of fuel.
NOTE: Always mix 2-cycle fuel oil and fuel in an approved gasoline safe container prior to filling the engine. Make sure to use a separate gas can for this 2-cycle fuel mixture and label it accordingly. Keep in mind that the fuel capacity of these engines normally is less than a gallon, therefore you will have to use this extra oil mixture for multiple fuel fills. Adding a fuel stabilizer will also help to increase the shelf life of fuel.
>>I Suggest Using a 40:1 Ratio and if Oil Starts Coming Out the Muffler then go to a 50:1 Ratio.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 14, 2009
SOURCE: I have Craftsman 17" Weedwacker and need fuel lines
Hey jncsurf, I had to buy fuel lines last week. I called the local sears parts store, and gave them the model number. They had a rather generic bag with the correct diameter lines. Just cut to the approximate length.
But now I have a problem: I didn't note which lines went where when I pulled the lines off. Could you tell me where does the line from the primer bulb go: top or bottom barb on the carb? Thanx.
Posted on Jun 22, 2009
SOURCE: Craftsman gas 25cc weedwacker starts, runs a few secs, then dies
The gas take up line is disconnected or is broken. I have the same problem and need to find a diagram to fux it.
Posted on Aug 28, 2009
smartr10U
  • 1305 Answers
SOURCE: Missing T piece from primer bulb to carburator
Sears has replacement parts and so do the OSH stores. If there's no store close, check with a local lawnmower shop and I'm sure they've got lots of replacement parts.
Posted on May 31, 2010
  • 3 Answers
SOURCE: Craftsman model 358.791042, gasoline weedwacker wont stay running
The high speed needle valve needs adjusting and it takes a special splined tool to adjust it. I currently am trying to find where I can purchase the tool to adjust the high and low carburator screws.
Posted on Aug 18, 2010
How to repair rope pull in craftsman weedwacker gas trimmer model No. 316.791940"?"
If you go to searspartsdirect.com an enter the model number for your weedwacker if will show you a diagram of how to remove the rope pull. Hope this helps.
Sep 26, 2016 | Craftsman Garden
Craftsman weedwacker model 316711970
If you go to searsparts.com and put in your model number it will show you a drawing of your weed wacker. Not sure of what you are looking for. Hope this helps.
Jul 09, 2015 | Craftsman 29cc 4Cycle Straight Shaft...
Craftsman owner manuals
If you go to searspartsdirect.com and put the model number in it will show you a diagram and on the page is a offering for the owners manual.
Jun 26, 2014 | Craftsman 29cc 4Cycle Straight Shaft...
Fuel line diagram for craftsman 32cc weedwacker weed eater
digrama for weed wacker 32cc modelo 368791156
Aug 23, 2012 | Garden
I installed a new carburator on a craftsman 25cc weedwacker model 358796600 and it wont't start
You might want to Google the model number for a service manual or contact a sears service parts center for help.
Jun 17, 2012 | Craftsman 25cc Gas Line Trimmer
How do I upload the manual? I want to see how to load the line
Hi and welcome to FixYa, I am Kelly.
Craftsman manuals are avalable for all models on this site:
http://www.managemylife.com/mmh/owner_manuals
You must have your model number
Note the model numbers on this page:
http://www.managemylife.com/mmh/owner_manuals/search/product_type.Line%20Trimmers:Weedwackers,%20Gas?query=27cc+Craftsman+trimmer
Once you enter your model number you click on "Get Manual" and then save as to your computer.
Thanks for choosing FixYa,
Kelly
Aug 07, 2011 | Craftsman 27cc 2Cycle Full Crank Curved...
Jun 22, 2009 | Craftsman 25cc Gas Line Trimmer
May 17, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 29cc 4Cycle Straight Shaft Weedwacker Gas Trimmer () Logo
241 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
