Question about Bissell Vacuums
Had to replace bissell pro heat pump wondering if I put the hoses in proper palce
  • jj8418 Sep 05, 2010
    never mind I had the hoses right after all jj8418
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Posted on Sep 06, 2010
Hose diagram for a bissel pro heat 2x complete pet
This is tricky... I'll suggest that you put the hoses back on EXACTLY where you took them off from. If this does not work, save all the parts, a competent technician will be able to reassemble your unit for about twice the cost of buying a new one.
Mar 18, 2016 | Bissell 8930M Upright Steam Cleaner
My Bissell pro heat 2x 9200 won't put out water HELP!!!
Hey Brenda! I can understand how frustrating it can be when you're ready to clean your carpets and no spray.
Here's a link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
Jan 15, 2013 | Vacuums
I can not get machine to distribute the water out
see the videos from bissell and proceed according :http://www.bissell.com/how-to-videos/ others help
normally you must check : tank full, maybe full need to emptied, or blockage, repair. Test the pump-motor for blockage too, and repair.+hose blockage too.
God bless you
Jul 15, 2012 | Bissell Vacuums
I have a bissell pro heat water wont come out
The pump may spin but the vanes inside could be broken or worn enough that they are unable to push water through the pump system. I am repairing a Bissell Model 8920 Pro-Heat 2X that has this very same problem.
I tested all the hoses to verify that they were not plugged. I then hooked the water and cleaner tub from the rear directly to the pump and held it above the pump assembly and water barely went through it with gravity feed and the pump was visibly spinning. The pump assembly can be acquired from AE Carters for $10.00.
I do not give any guarantee that this is the only problem.
Ron Goodrich
May 16, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Clean solution leaking out the bottom
open it up again and check the pump there is probably a hose leaking ,did you put the clamps back on the hoses
Apr 14, 2009 | Bissell 1400 Little Green Pro Canister...
No spray
pump part number is 2107181, the diverter valve # 2136988. You can Bissell and they can tell you who may have parts near you, or you maybe able to order thru Bissell.com. Before you took it apart, were you getting water to spray out of the hose. If you were the the heater is plugged and won't allow water to spray out the bottom.
Feb 26, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
No spray
You can to bissell.com and order them thru them, or they can tell you where the nearest place is for parts by putting in your zip code.
Feb 23, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bisssell pro heat 2X
The hose should wrap around on the back by the cord. The holder is made to hold the hose as well as the cord.
Jan 05, 2008 | Vacuums
Vacuums Logo
46 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
