Question about Raypak Free Hydraulic Lift Gate Delivery - No L...
I have a Raypack pool heater model number P-M406A-EN-X, that gives me a CFH then a SPK message. Sometimes I hear a clicking sound. Someone came to look at it yesterday and mentioned a wire to the spark plug being loose. I have to assume it's the same problem, however, I can't seem to do anything to the wire to fix the issue.
  • 3,083 Answers
Have you tried using a fine emory cloth to clean the ignition wire terminal? Sometimes oxidation builds up on them, and they play heck making contact. CFH is call for heat, and SPK is spark. Clean or replace the ignition wire good and see what happens. The clicking sound is probably the electronic ignition trying to spark.
Looked on the net, but couldn't find these codes, and noone reported any problems. It could be a temperature sensor- that is the cheapest thing to try first. If that doesn't fix it, it could be a faulty ignition unit.
Here is a good web blog of these systems, and may assist you:
http://blog.poolcenter.com/article.asp?articleid=6050
Good luck, thanks for using FixYa, and hope this helps.
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 05, 2010
Why do I get CFH but then no SPK?
CFH = Call For Heat
SPK = Ignitor is Sparking - attempting to ignite raw fuel
In a lot of cases, Pressure Switch opens up, CFH , is cancelled and therefor no ignition sequence.
try cleaning filter really good. If cartridge, may be time for an overnight soak.
May 21, 2015 | Raypak RP2100 DIGITAL POOL HEATER R265
Why does pool heater read SPK and won't light?
Sounds like your ignitor is shot. You may have to replace it.
Jul 24, 2014 | Rheem Water Heaters
Raypack 2100......cfh then spark after a few moments.....what appears to be :Lo.....what could this be
check gas pressure sounds like too small meter especially if furnace or dryer is running call gas company give them added value of all gas operated appliances
May 24, 2014 | Raypak RP2100 DIGITAL POOL HEATER R265
Raypak 2100 fault
It sounds like your ignitor may be out. Everything else is good in the safety loop and the heater wants to fire. The last step in the process is the ignition of the main burner. Are you hearing a ticking sound? If not the spark is not being produced.
Apr 12, 2014 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Rheem pool heater does not light.
It would be unusual for both the board and the igniter to go out at the same time. You should have a CFH code before SPK . That is Call For Heat and SParK. The clicking is the heater trying to fire up. It sounds like the igniter is doing its job. For some reason there is no gas getting to the pilot. That could be the board not telling the gas valve to open. It could also be the gas valve malfunctioning. You may want to have another tech take a look at it. It could just be dust or dirt in the pilot assembly.
Mar 19, 2014 | Pool & Spa
Rheem model p-m266a-en-c digital gas pool heater runs, shuts down
CFH is call for heat not sure what spk is, but will find out and let you know.
Jul 05, 2009 | Solar Rheem Gas Fired Pool & Spa Heater...
Raypak Free Hydraulic Lift Gate Delivery - No L... Logo
209 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
paulcarew
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
