Question about Dyson DC15 All Floors - The Ball Bagless Upright Cyclonic Vacuum
Im trying to get the filter out under the dust collecter
  • 41 Answers
Http://www.espares.co.uk/datastore/ProductManuals/350256.pdf
The above link shows how to remove the filter.
Posted on Sep 28, 2010
The motor still works but it doesn't collect the dust
did you check all hoses to see if they are clogged? there is a spot at the bottom of the vac where it sucks the dirt/dust into the bag. if there is anything clogged in the hoses it will not allow suction. plus you may want to check the filter if your vac has 1.
Apr 10, 2012 | Vacuums
My Eureka 5892 BVZ-1 vaccum has very little suction. I checked hoes and emptied cup, and made sure filter is not dusty.
There are probably three filters, one on the back of the dust collection bin, one under the dust collection bin, and one where the air exits the vacuum, check all three.
Gary
Mar 04, 2011 | Eureka 5892AVZ Bagless Upright Cyclonic...
Clogged sweeper filters changed and hose cleaned, but no dirt collecting in the bag. I am no sure what do do next
You have a rubber flap in the dust collection bin that may have been pulled out causing the collection bin to close when vacuum tries to pass through. Try pushing the flap back in to see if that's the cause of your vacuum loss. To test if this is the cause try turning the cleaner on and feel the outlet leading into the removable bin to see if there is any air flow. If there is no air flow, unplug the vac and run a coat hanger through the inlet tube to find and clear any obstructions. Then take the vacuum outdoors, plug it in and turn it on to clear any dust or debris left in the vacuum chamber.
Mar 15, 2010 | Eureka 5849A Boss Bagless Upright Cyclonic...
Electrolux Model 2100 vacuum won't work
hi from uk may i suggest you remove cover and the new dust collection bag then if you look in the bag compartment there is a gauze filter fitted usually grey in colour ? at opposite end of compartment where bag connects this gauze filter is the outlet from bag compartment that the air exhales when vac is operating ie as vac **** up dust into bag the bag has microscopic holes that allow sucked up air and dust to collect but keeps dust from passing into bag chamber but allows air to escape thro holes and so enter bag chamber then escapes via the gauze filter to outside of vac hope you follow this ?? now if this filter is blocked/never been cleaned/changed ? then the symptoms of indicator bag full light will come on you can remove and wash filter if it is gauze typ? dry and refit then try vacuuming ? or replace filter they are not expensive usually in pack of 3 in uk DO NOT RUN VAC WITHOUT THIS FILTER FITTED ! or you will have some dust in the room ? hope this helps?
Feb 27, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Hepa filter stopped on Hoover Windtunnel 2 Model #U8361-900
This has a simple solution IF you have a air compressor with a high pressure nozzle. Outside the house, first remove the Dust bin completely and lay the unit down with the dust bin area up. now start blowing the nozzle at the hepa filter, Alot of dust will come out. Now start to rotate the filter while blowing the dust out. The filter will move one way easier, When there is no more dust reinstall the dustbin and check the suction and the rotation of the filter.
Tony
Nov 17, 2009 | Vacuums
Roomba Discovery
did you replace the filter? when you remove the dust bin there is a small filter that needs to be cleaned, or replaced. You can buy a maintenance kit that replaces the brushes and filters as well, its good to replace them all regularly
Oct 02, 2008 | Roomba Robotic Floor Bagless Vacuum
Filter keeps clogging
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=719779
Generic problem for all Vacuums
Posted by ozandcaza on Jun 29, 2008
Report abuse
Dust etc collects in the filter above the dust container. The dust container remains empty. Hoover then over heats and cuts out. Collect in replaced new filters in Hoover but problem still remains.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. My question is how old is the Hoover vacuum? If it less than a year you should really see an Authorized Hoover vacuum cleaner dealer that the problem might be covered under a factory warranty. This should not be happening and it sound to me like there is a clog somewhere in the vacuum fill area that is causing it to do this to you and the vacuum. You are lucky that you have a thermal switch that does shut it off. If not and it is over the one year factory warranty then you should see a local vacuum cleaner dealer in your area or contact Hoover Cust Serv @ the website and or phone 3 listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 29, 2008 | Vacuums
Dyson DC15 All Floors - The Ball Bagless Upright Cyclonic Vacuum Logo
47 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
