Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Fisher&Paykel Dishwasher DD603- How to remove drawer
Hi, The suggestions we have read all seem to point in the same direction, but it appears we need to remove the drawer to access the sensor. Can you indicate how to remove the drawer? Thank you.
  • 770 Answers
On the sides of the drawer there are pins use a neddlenose pliers to pull them stright out then the drawer wil be released from the rails you will need to prees on the tabs at the sides to pull out you cant take it completely out due to the hoses attch.
Posted on May 20, 2008
5 Suggested Answers
  • 784 Answers
SOURCE: i need to know how to take the drawer out of a 2
When you pull out the drawer, pay attention to the bottom near the bottom front panel, you will see a little tab. this tab is at both sides of the drawer, press these tabs in and pull the drawer further a bit, you can see the tub move out a little further. Now lift the tube up and out ot the rails. Push the rail inside the dishwasher, then you will be able to put the drawer down on the floor. Don't try to pull the tube out so much since hoses are under the tube has a limited length.
Posted on Nov 16, 2009
Testimonial: "great. thx"
  • 3247 Answers
SOURCE: fisher paykel dishwasher DD603 drawer is open but locked
i think you have to press the key/ lock button until the symbol disappears. You will find the exact button for your model in your owners manual.
Posted on Dec 13, 2009
  • 33 Answers
SOURCE: FISHER PAYKEL DD603 DISHWASHER AND TOP DRAWER HAS
I know you did this but check your breaker. The other thing I would ask is has there been any storms dishwashers are the worst for power surges I see it all the time sucks but it normaly a 250 fix for a new control board
Posted on Apr 29, 2010
jyackle5
  • 8197 Answers
SOURCE: Fisher and Paykel dishwasher DD603 manual
You can get the manual below for free..
http://www.fisherpaykel.com/admin/pdfs/pdf_usecares/527971B_DD_user_guide_USw.pdf
Good Luck and please rate 4 thumbs for the free answer
Posted on May 15, 2010
I have a Fisher & Paykel dish drawer model number DD603 and it is not draining. Any tricks?
Hi
Dishwasher not pumping issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you’ll need to clean the drain filter and drain pump.
Please check the parts manual for your dishwasher, check the drain pump & drain filter's location from the link---
Fisher and Paykel Dishwasher DD603 Parts Manual
Please note that dishwashers don’t pump out the complete water such that heating element doesn’t overheat. Please post back for any further assistance.
Daniel
Aug 07, 2010 | Fisher and Paykel Dishwashers
How to remove the drawers of fisher paykel dishwasher dd603
Refer to page 7 step 2 for instruction on removing the drawer (tub).
http://www.fisherpaykel.com/admin/pdfs/pdf_installations/526607O_DD_Install_USw.pdf
I suppose you want to get to the flood switch at the base of the dishwasher and dry it out.
Make sure the mains power is turned off.
May 17, 2010 | Fisher and Paykel 23 in. DD603H SS...
Fisher paykel dishwasher DD603 drawer is open but locked
Nov 25, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
E-mail for Fisher Paykel DD603 manual
Josh, you will need to have a Tech out to look at it... F/P will not sell you parts to repair it. The F1 indicates that the flood switch has been tripped. There are many possible causes for this but probably the upper drawer link support has broken and is getting stuck between the lid and the drawer in which case you will need a new lid and link support.
May 05, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher & Paykel single drawer dishwasher F1 flashing.
F1 indicates a problem with the Flood sensor. I cleaned all the filters etc. removed the drawer viewed under the drawer, it was dry. There is nothing further I can do, so called the Appliances repair person and booked an appointment for him to determine if an outlet hose is blocked or has a hole in it or whatever. Thanks for all the suggestions Blokes. I'm technically challenged. Happy New Year
Dec 28, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel DD603 service manual
Check to see if the Child lock is on...Check your email
Aug 28, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dish drawer by fisher and paykel DD603 FPZW
flooded unit please remove drawer abnd dry board also read some of my other post on this problem
Jul 19, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
How can I fix my Fisher and Paykel DD 6031 Dishwasher? its leaking
I have Fisher & Paykle DW DD603-SS (5Y old)
The upper drawr started to leak H2O out and in to the bothom drawr???
What is the problem and also please what is the solution?
Thanks, JB
Jun 23, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
256 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
