Question about Mtd 46" Dozer Blade, Fits All & Yard - Man Lawn & Garden
My blades will not disengage 600 series riding mower mtd
4 Suggested Answers
  • 636 Answers
SOURCE: craftsman riding mower blades won't disengage
Sounds like the shear bolt is broken, Do you have and owners manual to show you the location of shear bolt? They are easily replaced.
Posted on Aug 15, 2009
  • 143 Answers
SOURCE: mtd yard bug model - 198707 riding lawn mower blade belt size?
I dont know the belt size but if you go to mtd belts in Jackssmallengines.com you should find it. Stephen.
Posted on Aug 23, 2009
  • 33 Answers
SOURCE: MTD riding mower does not move forward or reverse.
this is a belt driven transmission. from the engine driven pulley going aft towards the xmission differential there is another smaller variable speed pulley, there is a long belt between these two, from the variable speed pulley there is a larger xmission pulley that sits kitty-corner to it with a belt between these two. This larger "xmission pulley" is what drives the differential and depending upon which gear you have selected, makes it go forward or reverse. Check that both belts between pulleys are on, check that pulley's hardware is completely secured (nuts tightened down) The heads of these pulley's are splined to align to the shaft(s) and if they aren't tight, they will just spin and not engage the transmission. If your battery is under the seat, remove it and you should be able to see and access the aft pulleys. If both belts are on and engaging the pulley's and the shaft is turning on the transmission pulley than you have transmission differential failure. Bet it's the belt off or pulley head loose. Good luck, hope this helps
Posted on Apr 14, 2010
Drive belt replacement on MTD riding mower 13ah660f120
Boy are you in for fun now and I suggest go ahead and replace both belts in the variable speed system while you got it apart.
Here is the service manual that cover the 600 series.
http://service.mtdproducts.com/Training_Education/770-10578.pdf
Apr 24, 2015 | Mtd Garden
Blades keep running in all gears on my mtd 420/38
Assuming you have put the blade drive lever into 'disengage' check the blade drive belt tension. With blade disengaged, belt should have significant slack. You may need to adjust the control cable, adjustment is usually on the mower deck; or you may have some debris on the deck preventing the pully to release belt tension
Jun 26, 2014 | Garden
Blades to disengage
On mower deck there is a pulley that engages the belt to turn blades. Find it, While tractor is shut off check that spring is on the bracket that moves pulley back when disengaged.If gone replace it. If its there, slide bracket back and forth to find out what it is catching on.
Jun 24, 2014 | Mtd Garden
I have a 38" deck yard machines(MTD) lawn tractor. When I raise the lever to disengage the blades, the blades still keep turning. Does anyone know how to fix this problem?
If they are slow to stop,thats ok if they don't ever stop thats an issue,the brake shoes that drag on the top of the blade spindles are worn out or not adjusted correctly !
May 14, 2014 | Mtd Garden
My riding lawnmower blades will not disengage or engage Now my lawn mower will not start
just replaced some pulleys on my craftsman 42 inch cut and now the blades are ingages all the time, but it will start
Jul 17, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a 1999 Yardmachine(MTD) model #13AS679G062, serial #1H287H2007-42 inch deck; when cold starting, the blades do not disengage, with the lift deck all the way up, clutch pedal depressed. I have...
Yes worn belts do stretch. On an MTD mower, like yours, there are blade brakes assemblies on either side of the mower where your feet rest. They stop the blade rotation when they make contact with the top of the deck pulley assembly. Part # 761-0168B Is the part # , you are looking for, you will need two of them.
Good Day.
Oct 09, 2009 | Garden
Mtd model series 790 mower wont move, belts are fine and transmission wont go in nuetral
mtd 1993 riding mower model 828 I was mowing then tractor stopped and wont go forward or backward It runs fine, and blades
seem fine. Drive belt looks fine.
Sep 17, 2009 | Mtd Garden
Cub Cadet-Blades won't stay engaged
sounds like either a saftey switch problem or a bad drive clutch on the pto. usuallly the mower shuts down,not the blades, they may have changed this though. my best guess would be a safety sensor try calling your local cub dealer and talking to the repair person he can shed light on the problem.
Jul 24, 2009 | Mtd Garden
Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
May 14, 2009 | Mtd Garden
Mtd 46" Dozer Blade, Fits All  & Yard - Man Lawn & Garden Logo
168 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
