Question about Black & Decker 14" Grass Hog Xp Trimmer/Edger
Spool retainer cap is broken. Need a new one.
    President:
  • Black & Decker Master
  • 1,545 Answers
You may be able to find one here:
http://www.ereplacementparts.com/
Please vote on this solution.
Posted on Sep 05, 2010
How do I get the spool retainer cap off
if it is a bump head then it has to go counter clockwise I believe . and YES they do tend to turn the engine if over tightened
Aug 18, 2015 | Ryobi 30cc 17" String Trimmer Zrry30530...
I NEED A SPOOL COVER WHERE CAN I GET IT ?
How to make a spool cap cover for an American Gardener YS24 (Weedeater XLT24) Trimmer
If you've tried to buy parts lately for your trimmer, you've noticed they are harder and harder to find. In fact, I was unable to find a spool cap cover, so I came up with this work-around.
Before you start this project, it's important to save any parts from the old spool cover-especially the top, if you can. The top is needed to make a spacer for the new cover that will still allow you to "bump" out the string.
I used a Craftsman 71-64215 replacement spool retainer to make my new spool cover cap. It fits the Craftsman C3 19.2 volt 74381 String Trimmer (CRAC06540 spool cap). I found this cap at a local Ace Hardware, but apparently it is also getting hard to find-I googled the Ace Hardware number to find it on the web-"7314644 cap." I bought a couple extra from HardwareDistributors.com. Note that the diameter of the cover at the tabs is the same diameter of the old cover-although the diameter of the cap is slightly larger.
Take the old cover, and using the tab from the old cover, mark a line on the new tabs the same width as the old. Make sure you center the old tab on the new tab so you will remove the same amount of plastic from each side of the new tab. I used a dremel tool with the cutoff wheels to cut the tabs on the new cap to the same size as the old cap.
If you look at the new cap, there is a round plastic circle ridge on the bottom of the cap. If you look closely you can see a slight indention, or discoloration on the top of the new cap matching the circle on the bottom. You need to cut the plastic out of the new cap matching the plastic circle. I used a dremel tool with a metal cylindrical grinder to do that.
Once you get everything cut, put the old cap into the new cap so that the spokes face down toward the similar spokes on the top of the spool. You may have to trim the old cap so it fits into the new cap.
Finally, snap everything together into your trimmer-don't forget the spring. Note that the new cap has about a 1/8 inch gap above the spool. However, this doesn't seem to affect the trimmer-and you can still "bump" the head to eject the string.
Apr 27, 2015 | American Gardener Get the lower price on...
How to use spool caps?
try a youtube video
Aug 20, 2014 | Sewing Machines
Need parts for American Gardner Yardstick model YS24. Specificly the line head assembly.
Sep 01, 2013 | Weedeater Garden
How to replace trimmer line ?
1. Remove the cap on the trimmer head, it unscrews.
2. The spool comes off, and on the inside of the spool there is a small hole, this is where you will start your trimmer line. It it will hold it in place while you wrap it. There is also arrows on the spool showing the direction that you need to wrap your spool.
3. Insert the line in the hole and start to wrap the line in the directions of the arrows, try to keep the line in rows, or else the line may bind and you will have to do it all over again.
4. Feed the line through the retainer and reinstall the spool by lining up the retainer and the slot on the outside portion on the trimmer head, the screw back on the trimmer head and you will be ready to trim.
Jun 29, 2011 | Toro Electric Trimmer
Trimmer head line loading instruction
Jun 29, 2011 | Husqvarna 28cc Gas Line Trimmer
How to remove spool from cap on a reflex plus strimmer
Usually these trimmer spools are retained with a threaded 'knob' with serrated edges. The problem usually is that the knob won't turn - or so it seems. You will have to hold the spool itself while attempting to turn the knob off - turn the knob counter-clockwise!! Remember - righty tighty, lefty loosie! I usually need to turn the knob with a large pair of alligator pliers to get its grip broken, then I can turn it off by hand. Good luck with it!
Jun 21, 2011 | Black & Decker Garden
Need info on putting line on troy bilt 4-cycle string trimmer. Need to know how to get spool off trimmer to replace trimming string on the spool.
Hold orange spool containing string while twisting the black plastic cap in the center, counterclockwise. This retaining cap is loosely spring loaded, so watch for the spring falling out. Once this locking cap is removed, the spool pulls right off.
Mar 27, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Power antenna broke and I need to replace it. How
Buy replacement antenna mast. Remove old one by unscrewing the retaining cap nut. Turn on the radio & let the antenna cable run all the way up while you pull on it to remove it.
Install the new antenna mast by turning the radio 'off' so the spool inside goes back to its beginning while you feed the cable of the new antenna down into the antenna mast hole.
Once the cable is all the way down, reinstall the retaining nut/cap and turn on the radio to allow the spool to run the antenna 'UP.'... cycle the radio ON and then OFF several times allowing the antenna to move all the way up and all the way down.
That's it!
Sep 28, 2009 | 2001 Hyundai Sonata
Step by Step spool filling on my NEW Black & Decker GH700
Check the bottom of the spool. See the pattern that looks like a circular saw blade. Ensure that the raised edges, do not have any broken/missing sections. Also, check that the pivot lever in the cap, moves freely and engages the space between the same, saw-blade-like edges in the spool correctly. If there are broken/missing sections of the spool, replace the spool with a good one.
Apr 29, 2009 | Black & Decker String Trimmer Cordless 12"...
Black & Decker 14" Grass Hog Xp Trimmer/Edger Logo
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
