Goodman unit ck-36 1b replaced capacitor installed a amrad's 200 turbo ac worked for 1 week now ac is not working again please advise
    Problem Solver:
  • 8 Answers
Was the turbo 200 set to the correct microfarad rating?
Posted on Sep 06, 2010
  • 1darkman Sep 06, 2010
    not for sure a repair tech did it is there a way for me to find out what the Microfsrad rating is
Goodman ck36 1b a/c. Capacitor replaced 2 years ago. Unit is 13 years old and thermostat is Honeywell, also 13 years old. This summer there seems to be a 3-5 min delay (from when thermostat registers call)...
If you have a AC unit with electric or gas its doing what its supposed to do, let the pressures in the system equilize before starting again, If you have a heat pump its doing it there as well you just have not noticed. Anti cycling is a good thing, 4 to 5 minutes is normal.
Jul 05, 2011 | Goodman Heating & Cooling
I have an outside unit mfr Goodman, model # CKL-49-1. The blower motor isn't working. I'm able to hear it attempting to start. How do I check this motor to see if it's bad? Thanks
You have bad capacitor on your unit it may not look bad but chances are it is just get the microfarad rateing of the side of the cap. should be like 55.5 55 7.5 something like that. Also check your fan motor. last. I have changed hundreds of caps this year. Russ
Jul 16, 2009 | Goodman CKL36AR36 Air Conditioner
Goodman cpl-j42-1a a/c unit, fan on outside unit not working, inside there is cool (not cold) coming out of vent..
sounds like you have a bad fan motor in outdoor unit or a bad run capacitor ck cap first you can go 1 size larger than listed on motor data plate
Jun 10, 2010 | Goodman CKL42AR42 Air Conditioner
AC fan running backwards
Check to see if it has some wires for reversing the direction. Some have four wires you can switch around to change the direction. If not make sure the capacitor is connected to the start connection and not the run connection. The wires for reversing the direction should be orange and yellow or purple and yellow and will be shorter than the rest. Hope this helps. Let me know what you find.
May 20, 2010 | Goodman GPC1342H21A Air Conditioner
Outside unit will not come on
Check the starter capacitor, and di you remember to add oil?
Aug 27, 2009 | Goodman CLQ36AR49 Air Conditioner
I HAVE A GOODMAN CK-36-1A AC AND THE FAN IS NOT WORKING. WAS TOLD TO REPLACE THE CONDENSER CAPACITOR AND IF THAT DID NOT WORK REPLACE THE THE CODENSER FAN MOTOR. THE COMPRESSOR COMES ON BUT SHUT DOWN WHEN...
Goodman unit you can use a 1/4 hp or 1/3 hp cond. fan motor but it does sound like a cap. Replace cap first. Its very easy to do just open up panel and replace the silver bullet with terminals out the top. It will say on the side what size it is like 40uf 5uf or something like that. Thats most likely your problem. Russ
Aug 14, 2009 | Heating & Cooling
I need a fan motor for goodman AC compressor model #CK-42-1C Serial number 9905596387
depends on where you live there are supply houses that carry goodman products the motor is a 3 1/2 ton unit or bring the motor to motor shop they can cross reference that number to another motor that would work fine
Jun 30, 2009 | Heating & Cooling
We got an a/c central unit goodman modle ckl60-1 and a month a go it broke and the technician said that it needed a new capacitor and freon and about a week ago the unit broke again and the technician said...
When a compressor is has to start. 1. HAs it been off longer than five minutes. As a service tech when I run on to this problem I install a hard start kit and a time delay. The start kit helps the compressor to start under heavy load condtions. The timer helps the compressor to balance out before tryng to start. Have tech set at 5 minutes. I install hard start kits and time delays on all my change outs. Replace problem will go away. Thanks Rus
Jun 15, 2009 | Goodman CKL60AR60 Air Conditioner
Heating & Cooling Logo
101 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
