Question about Electrolux Epic 6500 Vacuum
My vacuum is not working after cleaning a lot of dust. It starts w/o the hose but when i plug the hose it turns off on its own
  • Electrolux Master
  • 43,501 Answers
Take something and run it through the hose...your hose is clogged up...and yeah it has to be bigger then a wire... a wire will often push right through a clogg of dust...
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright Vacuum not working
heatman101
Posted on Sep 06, 2010
Shark professional nv355 wont turn on
could be the motor thermostat. Make sure the unit is clean. No dust build up in the filters etc. Then here are the motor reset steps.
Motor Thermostat needs resetting
In order to reset the Motor Thermostat:
  1. Move the Power Button to the "O-Off" position
  2. Unplug the vacuum
  3. Check for a clogged hose or filter; unclog the hose and replace the filter
  4. Wait 45 minutes for the vacuum to cool; then plug the vacuum
  5. Turn the power switch to the "I-On" position to start the vacuum
  6. If the vacuum still does not start, contact Customer Service at 1-800-798-7398
Jan 10, 2018 | Shark Vacuums
The vacuum has a lack of suction compared to when we bought it 6 months ago
Clean all filters and if there is a hose it could be partially plugged as well. Take hose off and shove something like a dry water hose through it.There is usually a filter back of the dirt bag as well. If it has been used to vac up drywall dust the dust bag will plug up before its filled as the dust is so fine it will plug up every thing on the vac. Really clean every thing and it will work better.
Apr 12, 2015 | Vacuums
Riccar 8995 no suction
If it's been over a year since you've replaced the belt that is the first place to start. Stretch belts lose elasticity and will still turn the brush roll but when the brush roll is lowered to the carpet it may not turn fast enough to pick up properly. If you have good suction at the end of the hose check to make sure there is not an obstruction in the tube where the hose goes into the bottom of the vacuum to the brush roll. Make sure your filters are replaced at least once per year and the bag is not full or has a lot of fine powder dust in it which can clog the bag.
Jun 13, 2014 | Riccar 8955 Upright Vacuum
Miele upright vacuum makes loud noise and dust comes out at bottom
It sounds to me like one of the hoses is plugged, probably the one that comes from the brushroll. That would make the dust and dirt come back out the front and would not let the vac pick up like normal. Clear the plug and you're machine should start cleaning better again.
Nov 09, 2013 | Miele Vacuums
LOST SUCTION what now ?
If it has suction at the tools and lots of it, you're not plugged. If there's low suction on the tools you're on the right track. Follow the airways back and you'll find the plug. Also check the base where the dirt goes 90 degrees that's almost always where a plug is going to start. A new belt might do it if the cloud you're talking about is rubber dust and rubber smell. Take the bottom plate off and look for plugs/a stretched belt there. It's really tough without seeing it to help. They can have bad motors from the factory as well which can make for smoke and burnt electrical smell.
The vac Dr
Jan 12, 2013 | Hoover Whole House Bagless Upright,...
I have a Bissell DigiPro canister vacuum and it has no suction. It is only 4 months old. What would the problem be?
Probably a clog in the hose. Disconnect the hose at both ends. Drop a coin in one end and allow it to fall through and out the other end. If it doesn't, the hose is blocked. Plug the end of the hose into the blower of the vacuum and turn it on. Make sure the other end of the hose is in a plastic bag. This should clear the clog.
Also, check the power nozzle behind the brush. Something may have gotten caught in the elbow near where the wand plugs in.
A full bag will also cause this, or if there's a lot of fine dust in your area, clogged pores in the bag will act the same as a full bag.
Jan 20, 2011 | Bissell 6900 DigiPro Bagged Canister...
Carpet setting: the brush drive does not work with the carpet setting. Is there a way to remove the bottom to determine if something is caught in the system?
To determine if you have a clog, first remove the attachment hose like you were going to put an attachment on. With the vacuum in the upright position, turn the vacuum on and place your hand over the hose. Do you feel a strong suction? If not remove the hose attachment by turning the locking ring at the end of the hose on the back of the vacuum counterclockwise, then remove the hose. Stretch the hose to it's fullest length several times. I would do this over some plastic or outside to keep the dust down.
Once you have done this replace the hose turning the locking ring clockwise to lock it in place, give the hose a little tug to make sure it's attached and locked.
Again, with the hose free from the agitator turn the vacuum on and fee for a good suction.
If you still don't have one then you likely have a plugged filter.
You will need to remove the dust bin.44d2af9.jpgOnce the dust bin is removed, over you trash can empty it by pressing the dustbin door release downwards. Now rotate the dustbin lid counterclockwise to remove the primary filter. With the lid removed grasp the filter and turn counterclockwise to remove the filter.
Pull the filter out over a trash can. Once out inspect it, if it's dirty you should wash the filter in warm water until the water is clear. When finish let the filter air dry for 24 hours before reinserting it.
Upon reinserting the filter, turn it clockwise to lock it in place, install the filter cover with a clockwise rotation to lock it in place and reinstall the dust bin.
Now plug the vacuum back in and again with the hose removed from the agitator or brush and ready to install an attachment then the vacuum on and you should have a solid suction.
These vacuums are really prone to poor suction if the filter get dirty. Because they have washable filters, you should take time about one a month to clean the filters.
Thanks Dorrian
Aug 13, 2010 | Kenmore Progressive Bagless Upright with...
IT DOES NOT WORK AT ALL
Try letting unit cool. If container was full it may have overheated. Also should clean filters while cooling down. If this does not work then its time for the shop. Most likely the cord.
Oct 09, 2009 | Panasonic Vacuums
Main vacuum suction won't turn off
try cleaning out hoses,if that dont work turn it on its side if the roller doesnt spin u need to change belt if it does take the bottom cover and try cleaning out the hole under roller
Nov 22, 2007 | Eureka Altima Upright Vacuum Model 2996AVS...
Vacuums Logo
50 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
