Question about Radica Big Screen Handheld Solitaire
How to shut off timer - Radica Big Screen Handheld Solitaire
    Problem Solver:
  • 5 Answers
The second button from the left side will turn off the timer
Posted on Nov 26, 2010
Can timer be shut off early
I have extensive files on timers.
Your timer is not identified by those numbers.
Copy following link to view diehl timer resources:
http://waterheatertimer.org/Woods-timers-and-manuals.html#dial
Add a comment and describe timer in detail for possible identification
Jun 07, 2013 | Diehl Hardware & Accessories
Changed timer/whirlpool model leq9508kq1/dryer runs in accudry mode, wont shut off,what is wrong?
if it wont shut off this is a timer problem contacts fused closed,are you sure this is a new timer?(some are remanufactured)
Feb 12, 2013 | Whirlpool GEW9250 Electric Dryer
Dryer timer won't shut off at end of cycle. Dryer runs, but no heat. It is a Whirlpool model number LGR4634JQ2.
Since you say that the dryer runs but have no heat, plus the timer won't shut off the odds are the timer is bad. The timer would tell the burner when to be on and when to shut down.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=265840&diagram_id=28265980#d28265980
21 partimage.aspx?imgid=z3bqljbfahrfndg1njc5my9mufcvc290b2hwdhjhcc8%3d
Enlarge Photo
Timer
Part Number: AP3037407 made by WHIRLPOOL $91.55 In Stock
Order now and it will ship Today
Jun 09, 2011 | Dryers
My maytag dependable care plus electric dryer doesn't shut off
Does the timer move when it's almost ready to shut off if not most likely need a timer. Can you turn it by hand to finish the cycle and shut it off. If not must be timer.
Hope this helps
Apr 24, 2010 | Maytag MDG7600AW Gas Dryer
Maytag Neptune washer shutting off in mid cycle
It must be the timer that is causing the control board or "computer", as you call it, to shut the cycle down, especially when the machine shuts off at almost exactly the same point in the cycle. The control board energizes the timer motor and monitors changes in the timer inputs. It will open the power supply line relay and shut off the machine if the timer inputs do not change within 5 minutes of continuously energizing the timer motor. It means the timer motor is stuck or the timer internal cam is broken at the point where the machine shuts off. Replace the timer (part #22002867) to fix the problem.
Disconnect power to the washer and remove the three screws securing the console's rear cover plate across the console's rear top edge.
The console has six locking feet that secure it to the top cover. Gently rock the top of the console forward then push the bottom of the console toward the back of the machine to release the locking feet from the slots on the top cover. Once the locking feet are released, remove the timer knob by pulling it off the console; lift the console then flip it forward onto the top cover to access the timer.
Disconnect the timer wiring harness then remove the timer mounting screw.
Lift the timer locking tab near the end cap and slide the timer toward the end cap to release the timer retaining tabs from the slots in the console. Lift the timer off the console then install the new timer.
Align the three tabs of the timer with the slots on the console then insert the tabs into the slots.
Lift the locking tab slightly then slide the timer back into position until the locking tab can engage with the slot provided in the console. Secure the timer with the mounting screw then reconnect the wiring harness.
Reinstall the console by lining up its six locking feet with the slots on the top cover. Insert the locking feet into the slots then rock back the console into position. Secure the console's rear cover plate across the console's rear top edge with three securing screws.
Mar 09, 2010 | Maytag Neptune MAH5500B Front Load Washer
Can not shut entire timer off.
To disconnect a box timer so it does not run or control the circuit, then remove wires from terminals.
If you simply want to override timer now and then, then remove trippers from timer dial. Then use manual override switch to set timer ON or OFF.
If you remove wires from terminals, and want circuit to operate, then as a general rule, you connect black wires together and connect white wire together. However you did not specify which timer you have and timers and circuits vary, so it would be wise to test the wires.
May 10, 2009 | Paragon 4001-00 24-hr Timer Control 120v...
Kenmore dryer timer never shuts off.
REPL/ YOU BROKEN LID SWITCH ,, IS ON OPEN POSITION REASON FOR NO T SHUTTING DOWN////
Nov 28, 2008 | Kenmore 27032
Roper dryer won't shut off
The timer motor isn't moving the timer. You'll need to replace the timer. Turning the timer **** to off should stop the machine.
Exception: If the shutting the door automatically starts the motor, then the start switch/relay is probably shorted.
Mar 10, 2008 | Roper REX4634KQ Electric Dryer
Radica Big Screen Handheld Solitaire Logo
47 people viewed this question
Top Radica Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Radica Toy Expert? Answer questions, earn points and help others
