NEED INSTRUCTIONS/documentation for: TP2782C Have acquired a Magnavox 27" color remote control picture in picture TV with the MODEL # TP2782 C104 on the label in back of TV, S/N: 49976786 August 1995 date of manufacture, along with the remote control that came with it that I cannot make out the model # on the paper label inside, but assembled in Mexico w/MAGNAVOX on outside. 3-AA batteries--w/VCR ability--Smart Picture-Smart Sound--PIP, written on front of remote. Very simple, older style. Problem being: This Model# NOT one of your choices on your website! PLEASE advise!! THANKS!!!
SOURCE: Adjusting colors on a magnavox 46" projection TV
Replace the CRT fluid. It grows algea in the blue and green only. 9.99 from MCM electronics.
Posted on Nov 16, 2007
SD Tech
  • 14553 Answers
SOURCE: I have a 60
You have one of two problems based on your description.
1.) Go to a channel that is in black and white and turn the color on the set all the way off.
Examine the screen and picture from several feet back----if the picture is mostly red and looks somewhat yellow in the main part of the screen you have a GLYCOL problem.
These sets have on each picture tube a sealed unit full of Glycol to cool the face of each tube (set has a red, green, blue picture tube)
If you find the yellow/orange look with the color off you most likely have bad Glycol in the blue picture tube---it never happens to the red--bacteria gets into the glycol and eventually there is no picture coming from (in most cases) the blue tube.
Loss of blue will leave you with Red and Green--mix those two and you usually get a orange/red affect.
There is a way to also confirm this with your eyes--it involves getting the back cover off of the set and holding a small mirror (with the set turned on--you have to be careful not to touch anything)
If you look in each lens you should see a fine picture--one red, one green and one blue--if as I suspect the blue tube is contaminated it will not have a picture and will look like a blue floodlight.
IF THIS IS NOT YOUR PROBLEM--GO into the customer menu and select convergence--what you are looking for is will red and blue adjust or not--are they skewed and will not move.
If this is the case you have a convergence problem--I can tell you what is involved to fix in either case.
Let me know what you find--I am here to help people.
If this information has helped you, rate this solution as I do this here for free.
SD TECH
Posted on Nov 08, 2009
milkburp
  • 416 Answers
SOURCE: I have a Philips Magnavox projection tv Model
You have a high voltage regulation problem. Most often this is caused by a failing FBT (fly back transformer).
Posted on Mar 14, 2010
Testimonial: "a little more information would have been helpful."
info2ukg
  • 11 Answers
SOURCE: i went sharp tv lc13s4 remote control service code
See the left side of tuner on pcb, you have got a micro switch. push the switch n get service menu.
Posted on Oct 27, 2012
AJIN G
  • 6694 Answers
SOURCE: I'm using oon remote control model number onb13avoo4 I need the code to control a zinwell 950a converter box
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily....
http://electro-medical.blogspot.com/
Posted on Jan 06, 2017
Philips Magnavox 27MS343S 27" TV picture stretched or zoomed !
Take of the back and there is buttons inside, try turning them.
Nov 25, 2013 | Philips Magnavox 27MS343S 27" TV
Need a replacement remote control. also tv is stuck on child lock
Hello
If the tV is strucked at child lock, you must have its original remote control to unlock it. Just contact the nearest Maganvox authorised service center for details.
Mar 01, 2012 | Philips Magnavox 27MS343S 27" TV
I need a remote for my television
This link will assist you with getting a remote that will work with this television.
http://www.replacementremotes.com/PHILIPS/Buy-996500015582-Remote-Control.html
Mar 29, 2011 | Philips Magnavox 27MS343S 27" TV
I have a 27" magnavox tv and it's on standby and i don't have the remote to turn it on is there any way i can get it to turn back on without the remote or can i get a a universal remote or anything please...
if there is any buttons on tv some tvs have cover over then on frount or side of any press ch.up or ch.down
is no buttons can be seen you can find remote on chylse hyde and son web site (CHS) tou will need make and model of tv
hope this helps
MERRY CHRISTMAS
Dec 14, 2009 | Philips Magnavox 27MS343S 27" TV
I have a philips universal rremote model #SRU3007/27 & need codes
The Magnavox TV codes I have are:.....002, 009, 109, 118, 209, 309, 402, 408, 502, 508, 510, 807, 914, 917
Jan 03, 2009 | Philips Magnavox Learning Universal Remote
Cannot get 27" magnavox closed caption
I called the Magnavox tech support - put the TV on channel 2,
hit the cc button repeatedly and problem solved.
thanks for contacting me.
Jun 25, 2008 | Philips Magnavox 27MS343S 27" TV
Zenith remote codes
0711 is the Magnavox universal; if this fails, we will need the exact model number of both the remote control and the TV - ifyou do not have both model #'s do not bother posting back
Jun 09, 2008 | Philips Magnavox 27MS343S 27" TV
Need the instructions and Code to Program universal remote control PHILIPS (Magnavox) and Magnavox TV.
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
Feb 03, 2008 | Philips Magnavox Learning Universal Remote
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
Electro Med Services...
