Question about Equinox (210120)
Takes 15 mins to fill tank
The gas filler keeps kicking off it takes 15 mins to fill the tank..
  • 66 Answers
This happened all the time with my van and then with my taxicab. the culprit is a combination of a slow angled fill tube in the car, and the new safety things on the gas pumps. What the attendant had me do is angle the pump so its not completely inside the hole, but just about the whole way so theres no suction, and making sure its still secure.
Posted on May 15, 2008
When pumping gas it kicks off and flapper is bent
There is an automatic valve in the filler neck of your fuel tank that is designed to keep gas from jumping back up the filler neck and out the fill fitting. If that valve is bad, you'll have a heck of a time filling the tank, as the nozzle is constantly kicking off and your fill rate is VERY slow. Probably best to take it to a dealer or your trusted mechanic. They might want to replace the flapper at the same time.
Jul 13, 2014 | 2001 Ford Taurus
Gas pump shuts off like its full many times while trying to refuel.
Usually a blockage in the filler tube or a vent problem.
You may have to take the filler tube off and inspect it. There should be a tube inside or outside the pipe to allow air pressure in the tank to equalize.
Jul 21, 2012 | 2002 Lincoln Continental
It takes 20 minutes to fill my gas tank. this has just started. The fuel keeps backing up in the filler neck and the pump keeps kicking off.
The tank venting system is malfunctioning -- likely an obstruction in it -- best bet is to take it to a shop for diagnosis & repair.
Charlie
Jan 09, 2011 | 2002 Buick LeSabre
Having difficulty filling the gas tank. The gas pump keep shutting off when filling the gas tank. It appears that the check valve in the gas tank fill pipe is not workinig properly thus restricting the...
not so much a common problem as it is just! a problem go to a local salvage yard and buy a new filler neck and install it!! its really simple just take the 4-5 screws out of the top filler housing and take a hose clamp off the vent house underneath and then wiggle/pull REALLY!! hard outwards on the neck till it comes out of the tank
Jan 22, 2010 | 2005 Dodge Caravan
Have a 2002 Sonata-everytime i put gas in - it will click off-even backing it out it will still keep clicking off. Takes a half hour to fill the tank.
dear friend -inside the filler neck is a butterfly which needs to be open when filling up,this happens when you insert the nozzle into the tank.shuold this flap be parcialy close the pump.will kick off.check for other restrictions aswell.
Jun 08, 2009 | Hyundai Motor 2004 Sonata
2004 Ford Taurus takes 15 min plus to fill fuel tank, help!
theres a problem with the pipe that goes from the gas tank to the gas cap.Look under neath and see if the hose is pinched or bent.Another cause could be who ever owned it before had the tank out and they messed up the hose when they put it back in but that is differently the problem..
Apr 01, 2009 | 2004 Ford Taurus
Car acted like the battery died/cannot fill gas tank.
Evaporator vent silenoid at rear by gas tank is most likely stopped up. Is the check engine light on? If so, take to Auto Zone and get them to scan it for free. Get codes only and post them.
Jun 05, 2017 | 2001 Hyundai Accent
Ford Windstar 2001 Gas filling problem
The fule tank vent tube is blocked/clogged. It's the little hole next to the filler hose that invites spiders that clog it up. Blow out the tube and it fixes the problem.
Nov 24, 2008 | 2001 Ford Windstar
Fill gas tank
have toyota or any machanic check the filer in the gas filler tube.
Nov 03, 2008 | 1998 Toyota Camry
Filling with gas
There is a fuel tank vent tube that runs down the filler tube to let the air out of the tank as you fill it, these tubes get kinked, replace the tube, this is part of the filler neck assembly so the whole thing must be changed out.
Nov 01, 2008 | 1999 Lexus ES 300
Equinox (210120) Logo
Top Equinox Computers & Internet Experts
David Payne
David Payne
Are you an Equinox Computer and Internet Expert? Answer questions, earn points and help others
