Question about Carrier Heating & Cooling
I have a carrier 38ckc026 and a two zone thermostat system. both thermostat displays are blank & a/c doesnt work - what should i look for before calling an hvac repairman?
  • Carrier Master
  • 43,501 Answers
The 24v transformer blew or if you are lucky there is a fuse in the line before the transformer...
Check in the air handler to make sure the cover is on right... then check for power to the air handler, then check ofr a fuse on the circuit board, finally check the transformer...
The problem lies in one of those things...
heatman101
Posted on Sep 05, 2010
Carrier Comfort Zone II Thermostat is blank and the 3 companion thermostats are all showing Error Code C1. What does that mean?
Hi Anonymous,
For all wall mounted and Artcool split system codes
Error code = C1 or CH1
Flashing Light = 1
Fault = Indoor temperature sensor open or closedcircuit.
Display = Indoor.
Indoor Operation = ON
Error code = C2 or CH2
Flashing Light = 2
Fault = Outdoor temperature sensor open orclosed circuit.
Display = Indoor Outdoor.
Feb 14, 2015 | Carrier Heating & Cooling
Our Carrier Comfort Zone II thermostat, which has 2 zone readouts, currently shows a temperature of 00, as in zero zero, on one zone. That is the main zone for our home. Zone 2, for spare bedrooms, etc....
This .pdf file may be of help to you:
www.brivis.com.au/.../Carrier%20Comfort%20Zone%20II%20Owner's%20Guide.pdf
Perhaps you could get some help from Carrier Support here:
http://www.residential.carrier.com/support/index.shtml
I noticed they have an option of talking to an engineer, and perhaps they could explain how to reset or set the unit.
Hope this helps.
Sep 25, 2010 | Heating & Cooling
Carrier infinity a/c thermostat screens are blank - no power
There is a fuse in the control panel, and depending how they wired it may be a inline fuse. also there is a fuse in the airhandler also they both should be a 5 amp auto fuse.
Jul 18, 2010 | Heating & Cooling
Carrier a/c thermostat was working fine, then display went blank!
if it has no batt I would ck transformer for 24to26 volts no voltage replece transformer be sure trans has 115 volts to it trans should be in furnace section
Jun 09, 2010 | Carrier 38CKC030 Air Conditioner
The Carrier comfort zone thermostst displays the
Go to panal and reset control. Small reset button on control board. Let me know if it clears.James
Oct 12, 2009 | Carrier 38CKC042 Air Conditioner
Blank readings on Carrier Comfort 3 zone thermostat
The stat that works is called the main and the other two are called slave stats. The stats must be set to heat or cool the same as the main. If you want one room to cool and one to heat , sorry. Need to upgrade to auto changeover. Is this AC actally a Heat pump?
Jul 01, 2009 | Carrier 38CKC042 Air Conditioner
Zoned system one zone not working
I hit the reset button on the main unit and that reset all the sensors. It was so easy but when I called Carrier's customer service line they told me there was nothing they could recommend. Not very good customer service. Avoid Carrier brand if possible.
Jan 22, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier 38TXA030 not working
That sounds like a very efficient system Gratz. You can try a reset by throwing the breakers off and back on and check all your micro fuses on boards and zone controllers. GL!
Jun 11, 2008 | Heating & Cooling
Heating & Cooling Logo
220 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
