Question about SkyScan 86742 Digital Atomic Wall Clock
Model #84061 For no reason the time set shows 1-1- 1:26 AM Tues. To-days date is 9-5-10 Sunday
Time is set but day is on sunday, bottom dial is on1 how fix
Usually the pin you pull out to set time also sets dates. See if the pin pulls out to 2 different lengths. Most of them you pull all the way out for setting time and 1/2 way out for date. Hope this helps.
Feb 01, 2014 | FMD White Womens Watch
I can't set the day on my police watch, it is stuck on Sunday only the model #13595j
The date on this watch is shown by the hand on the dial with Sunday written on it. If you read the date dial starting from the top on Sunday there are 6 lines on the face indicating the other 6 days of the week. Therefore your watch is currently showing it is Friday. The "SUN" always shows because it is not like a normal watch. It is the hand on the dial that shows the day.
To change the hand on the day dial you must wind the main knob (LHS) clockwise to move it. To advance it 1 day you must wind the clock around the face twice ie 24hrs and the day pointer will move forward one day. Do this till you get the pointer onto the correct day.
Hope this helps!
Dec 04, 2012 | Watches
On my KADIO KD-3805 I can set the time and date which is the 9 of the 11 but I cannot get Sunday it will only bring up Wednesday I have tried to use the up and down button it will not bring up sunday just...
After fixing time when you press mode button year will come say 2002 . you have to press up or down to set correct year (say 2011). then the month will blink which is to set and therafter the date. The Day (say Tues) will automatically appear.
Sep 11, 2011 | Watches
Pulsar watch, how do you set the day of the week and month?
mcdevito75 here, The stem has 2 positions, first adjust the day or month by going thru the 24 hour cycle with the stem. once set, slip a finger nail just ubder the stem and lift carefully this should allow you to change the DATE adjust to 1 date before the date you need, now pull the stem out to adjust date and time of day turn sten the complete 24 hour cycle to achieve the correct date and time of day. Now your watches day and date are set and will change to the next day date on time, around Mid nite 1 --2 AM.
Jul 08, 2010 | Seiko Watches
The day of week is wrong on my partner-18D (lucent avaya phone)
Dial Feature 00
Left Intercom Button Twice
Dial #102
Dial 1 for Sunday, 2 for Mon, 3 for Tues, etc
Dial Feature 00 to save your changes
Nov 19, 2009 | Avaya 700340193 Corded Phone
My office has the Prostar 816 phone and the manual is not detailed at all.. I needed to know how to change the time (due to time change) Our manual says #55 etc etc... Help me please!
To change the time on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down, enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming2.gif)
2) enter in #55 the screen should say YYMMDDWHHMM
3) enter in the year, month, day, day of the week, hours and minutes(the day of the week values are 1= mon. 2= tues. etc.)
press # when finished.
Nov 12, 2009 | Samsung Prostar 824 Keyset Telephone
How do i program dates and times on the panasonic kx-t7730
You have to change from extension 101. Once you are on extension 101 then you need to press program then 0. enter date backwards ie(081104) then day (1=mon 2=tues 3=wed 4=thur 5=fri ect.) then enter time ie(0300 for 3:00) then 0 for am or 1 for pm. so it would go like this
Press program then 0
Enter (example for Tues. Nov. 11,2008 3:00 pm) would be
081104 2 0300 1
then press store then program again and it's set.
Nov 12, 2009 | Panasonic KX-T7730 Corded Phone
Setting day and date - the day and date change at the wrong tome of day
To sync the correct 12 hour with your day you need to set the date to the day before (if today is Wed 21, then make sure the day window reads Tues 20). Then spin the analog hands until the the date window turns to Wed 21. At this point your watch is reading 12 AM (midnight). Then keep turning to set the correct time. If it is 9 am then stop the hands the first time you hit the 9 marker. If it is 9pm, then keep turning until the SECOND TIME your hour hand meets the 9 marker. This is now set for 9 pm. The day (Mon thru Sun) sometimes needs to be set seperately from the day; it may take a couple of tries but use the directions above and patience and you will achieve your goal.
That's how you do it. If you need more clarification let me know.
Oct 20, 2009 | Seiko Watches
I have an automatic watch that shows the day of the week, I can't set it so that it changes from day to day correctly. I've changed it to correct day right after midnight and by the end of the day, it's...
hi,
first you kepp the day and date set yesterday's , for example today is 31st and monday so you set 30th and sunday , now keep rolling time by key till day and date has complitaly changed,remind that do not roll anty clock, it may be damages to your watch,now when you get change day and date its a midnight of 31st and monday, now set the time and get started ,
Aug 30, 2009 | Invicta Corduba Leather 3809 Watch for...
SkyScan 86742 Digital Atomic Wall Clock Logo
111 people viewed this question
Top SkyScan Home Experts
nejones57
nejones57
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a SkyScan Home Expert? Answer questions, earn points and help others
