posted by Perfect1 on May 12, 2008
where do the pugs ins in the back of the tv go I cant turn on my tv because on of my plugs becasme unplugged and I dont know where it goes back in?
Solution #1
posted on Jun 04, 2008
This is a very difficult question to answer without knowing more info, but here goes:
Check the power cable, there should be only place to plug it into. This may be one of several styles depending on your model, usually a 3 prong female (just like your PC's power cable) connector, or a single pin female connector (looks male but has a hole in the center) will connect to the back of the monitor.
If you get power, but no image: VGA connections will use a large blue connector with 15 round pins, 3 rows of 5. DVI will be a large white connector with slotted pins, with varying amounts of pins depending on the type of cable (analog, digital, or both). HDMI will be a small connector that resembles a large USB connector. You may also be using a composite or component cable, which will be color coded to the ports on the monitor.
All styles of connectors will physically only connect to the corresponding port. Check all connections and make sure they are all secure and connected to the correct locations on the monitor. Doing this should resolve your issue.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Hannspree HANNS·G HW191D LCD Monitor
Email this problem
Email this problem
This Problem Also Relates To:
HP Pavilion F1503 15 in. Flat Panel LCD Monitor
HP vs19 (Silver) 19" LCD Monitor
HP vs15 (Gray, Metallic) 15 in. Flat Panel LCD Monitor
HP 22" Widescreen Flat-Panel TFT-LCD HD Monitor
HP HP / Hewlett-Packard RY117AA w2408 24" Widescreen LCD - VGA/DVI-D with USB Hub LCD Monitor
Philips 107E56 (Black) 17" CRT Monitor
Philips 190B6CB/27 19IN LCD BLK
Can you Help with these Monitors problems?
Hannspree HANNS·G HW191D (Silver, Black) LCD...
monitor won't stay on
My hanns g 19" lcd monitor... Answer This...
I tried to increase the sound...
There's no freakin directions... Answer This...
Repair Service
Find Monitor Repairman Near You:
