Question about Toshiba TZ50V51 50" Rear Projection Television
Toshiba projection tv
Tv shuts down blinking red light
  • 2 more comments
  • ebony_bear Nov 08, 2008
    BLINKING RED LIGHT
  • Anonymous Nov 11, 2008
    No picture,
  • ann333 Dec 27, 2008
    power light blinks and TV will not come on
  • RollinNoxioS Jan 09, 2009
    I have an older 42" rear projection Toshiba. Never had a problem until this past summer. It often shuts down and the power light flashes. Un-Plug it and Plug it back in and it comes on agian. This often happens up to 10 times in a row before it operates normally again. As it is older, I have no intention spending any money on repair if poossible. I think a little Solder and the "Toshiba shutdown circuits and power supply troubleshooter" mentioned would be perfect.
  • Toshiba Master
  • 8,617 Answers
Your set has a problem with the power supply causeing the set to shotdown. You can get a manual called Toshiba shutdown circuits and power supply troubleshooter that takes you step by step to diagnose your model its available at this link they email it to you almost instantly after purchase and they also provide free tech support in case you need further help. heres the link.
http://servicemanuals.vstore.ca/
Posted on May 12, 2008
5 Suggested Answers
ginko
  • 19396 Answers
SOURCE: toshiba 50HX81 projection 'tv- blinking red light
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
  • 1153 Answers
SOURCE: TV toshiba
What happen lost you?
Posted on Sep 13, 2007
  • 13 Answers
SOURCE: TV turns off and power light blinks unpluged andd still does it.
Likely to be the STK convergence chips causing a protection circuit to switch the TV off. Have you got any onscreen convergence problems (i.e, colour fringes)?
Posted on May 28, 2009
SOURCE: toshiba blinking red light
MI TELEVISON PARPADEA LA LUZ ROJA Y SE MANTIENE EN ESTADO DE HINBERNACIóN
Posted on Sep 28, 2008
Red light blinking
google to see several posts on projection tv red light blinking from several different manufactures (sony; toshiba; samsung; philips; you name it) and several models.
http://www.avsforum.com/forum/63-rear-projection-units/975795-toshiba-65h81-went-black-blinking-red-light-help.html
Apr 16, 2016 | Televison & Video
Toshiba 52hm94 when powered on continuously shuts on and off with blinking red and green light and static noise
that happened to my old LED tv it was the tubes that have gone go into currys and ask an expert thats how i found out what was wrong with mine
Aug 02, 2012 | Toshiba 52HM95 52" HDTV Projection...
May 27, 2009 | Toshiba 42H81 42" Rear Projection...
Panasonic PT53tw53-TV shuts down, red blinking light,
Replace diodes 6301,6116,6117. on G board.Diodes will sometimes read good but break down when under load.
Jan 06, 2009 | Sony KP-46WT520 46" Rear Projection...
Toshiba 50H71 projection tv
the convergence ICs have shorted and thats whats shutting down the set. Its an easy repair you have to replace both the Convergence ICs they are STK392-110 ICs you can get replacements at the following link and they provide free instalation instructions with pictures and also free tech support. Heres the link.
May 31, 2008 | Televison & Video
TV shuts down with Red Light blinking
Thats an easy set to trouble shoot, but you would need the manual called toshiba power supply and shutdown circuit troubleshooter. It takes you step by step on the items to check so you can easilly pinpoint the problem. You can get that manual at the following link, they email it right after purchase and they also provide free one on one tech support so you can get help with it if you need. Heres the link
May 10, 2008 | Toshiba TZ50V51 50" Rear Projection...
Toshiba 55hx70 projection tv problem
How many times does the light blink? It should blink a number of times, pause then blink the same amount then pause. Try to count the blinks then let me know. Also how long does it run before shutting down if any?
Jan 20, 2008 | Toshiba 55H70 55" Rear Projection...
Toshiba hometheater 50" rearprojection
http://www.casiasfamily.com/repairlog/tp50h15.html
see the link.
the problem are the convergence amps. Its a common problem for this model. Google the model # and you'll see several postings about the blinking light.
Dec 06, 2007 | Toshiba TP50H50 50" Rear Projection...
Tv shutting off
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sep 11, 2007 | Toshiba 50H81 50" Rear Projection...
Toshiba TZ50V51 50" Rear Projection Television Logo
309 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
