Question about Stanley Bostitch N88rh Framing Nailer Driver Piston 158582
The nail gun has a nail hung up in the discharge chamber. I dont know how to get it out. Please help. Any suggestions?
  • 4,340 Answers
Yes, disconnect the air, then disassemble the front part of the gun. this area commonly has jamb issues, nowdays they are quick release, for clearing access.
Posted on Sep 05, 2010
Testimonial: "Great tip! thanks!"
  • sillyjillybo Sep 05, 2010
    Trying to figure out where the quick release is. Cant find it.
My Pro 8000 stapler has about 20 staples jamed I need to how to unjam thew booklet does not show this
Clearing the Nail and
Staple Chamber
If, while using your Cobra
staple
and nail gun, it becomes necessary to
clear a jam from the staple chamber or
track, follow these instructions:
With the bottom of the gun
facing away from your face and
body, open the staple chamber by
squeezing and pulling the plastic
track release straight down away
from the base of the gun and
sliding the track back.(Fig 1)
(Note: the jammed staple or nail
may cause the track to be harder
to slide out than usual. Once the
staple or nail has been cleared,
the track will resume its normal,
free operation) Loose staples or
nails will be expelled from the
chamber.
Clear any remaining staples or
nails from the track and chamber
area.
Reload the Cobra staple and nail
gun and continue using.
May 17, 2017 | Staples Tools & Hardware - Others
When i tried to use the nail gun, it only produce a little pop and no nail came out
Try spraying Carburator cleaner to clean out the air chamber on the gun, and where the nail comes out
Sep 26, 2015 | Air Tools & Compressors
How do I unjam a porter cable BN200SB nail gun
I suggest that you make sure that there is no air he tool so, remove the air supply. Then if you remove the cover from the nose (Making sure that you also take out all the unused nails first) it should allow access to the front nose plate. If you remove this, it will allow you to carefully remove the nail. While you're at it, check that the driver blade tip doesn't have any burring or damage to it. If so, you might need to fettle it back into shape or, replace it?
Sep 14, 2014 | Porter Cable Tools & Hardware - Others
Nails skipping
Usually caused by debris in the small air passage from inside of gun to feeder piston. Easy to check. Remove the head and pull out the cylinder. Debris in the chamber is usually small pieces of oring or the lower bumper is coming apart. This debris will enter passage to feeder which is visible at bottom of chamber. If debris is found, clean chamber, passage, and feeder chamber. Debris will lodge on the oring between the body and nose. Clean and replace parts as needed. If the gun was found to be clean inside, suspect weak or missing feeder spring/s. Good luck/
Oct 29, 2013 | Stanley Bostitch Nail Gun
Nail gun won't discharge a nail
Open the front and see if the nails are feeding through. If the piston is down push it up, close the front and try again.
Nov 21, 2012 | Tools & Hardware - Others
I have a Max cn70 nail gun. When trying to fire the gun, air seeps from the trigger assembly and will not fire. Help!
Hello, sounds like a nail is jammed in the chamber. Happens frequently. What you do first is disconnect the gun and empty any nails. Then, with a screwdriver or a big nail hit the ram driver back down . Reconnect and test by depressing safety latch and pulling trigger. Repeat. Hope this helps. -ROB
Feb 10, 2011 | Air Tools & Compressors
Paslode nail guns won't shoot
piston is probably jammed
This happens sometimes try holding it up against a board with the trigger depressed and then inset the battery.
The goal is to try to force the firing sequence to get the piston back to the right position with corded units this is simply done by attaching the air hose with the trigger pulled this causes air to rush into the gun chamber pushing the piston back and firing a nail out.
The cause of this is a misfire or jammed nail that stopped the piston in the wrong location so air will not build in the chamber correctly.
Hope that helps
Feb 18, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
My gun fires but only loads the nail 20-30% of the time. I tried taking it apart but don't know where to look for the problem. Please help!
The problem will reside in the nail chamber. Most likely you have junk there or a scored feed area. Check the plunger and feed area for dirt and/or scoring to determine what exactly is holding up your advancing of strip nails.
Jan 04, 2010 | Hitachi Nr83a- Strip Nailer-driver Blade...
Paslode nail gun wont fir nails model 5350/903 air compresser type
paslode is a very good gun and I use them daily. release the clip from the front and it will expose the channel that the nail travels through. Make sure there is no broken pieces of nail in it. you can also check on the trigger and make sure it pushes the pin in all the way. I dont know if you have the grey or orange one in it but it doesnt matter, the get worn over time and if it is bad, one pin will let you replace it. if none of these ideas help, take the top of the gun off(a few hex screws)and expose the top of the cylinder head and look for holes around that piston. if it has one there will be excessive discharges of air out the top of the gun
Dec 13, 2009 | Tools & Hardware - Others
I have paslode finishing nail gun , i cleaned it, not working now
The smoking is normal for a few times after cleaning ,but you might have put to much oil drops in chamber and piston chamber is getting a "vapor lock". Try recleaning with degreaser. Also have you forgotten to set the depth gauge at front of nose.
Please Rate jj505 Thanks
Mar 23, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
Stanley Bostitch N88rh Framing Nailer Driver Piston 158582 Logo
243 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
