Question about Garmin nuvi 255W GPS Receiver
IS THERE A PROBLEM WITH THE BATTERY - Garmin nuvi 255W GPS Receiver
    President:
  • 563 Answers
Battery life according to Garmin is about four hours with the rechargeable Lithium battery. During the use, it last anywhere from three hours and fifteen minutes to three and half hours.It does happened that sometimes the batter die and won't let the GPS to function properly.
Posted on Sep 05, 2010
Apc hi800sq
follow this steps and fix it. God bless you
Plug the battery backup into a working electrical outlet. If the battery backup turns on when the power button is pressed, then the problem may be that the previous electrical outlet is faulty. Proceed to step three. If the battery backup doesn't turn on, proceed to step two.
  • 2 Reset the circuit breaker on the battery backup. APC battery backups have a labeled circuit breaker button located on the unit near the phone line, fax line, USB, network and coaxial cable inputs. Press the button to reset the circuit breaker. Power on the battery backup by pressing the power button. If the battery backup powers on, proceed to step three. If the battery backup doesn't turn on, proceed to step six.
  • Read more: http://www.ehow.com/how_7266444_troubleshoot-apc-battery-backup.html#ixzz2lwOvPO75
  • 3 Determine if the battery backup is charged and providing battery power. With the battery backup on and plugged into a working electrical outlet, plug a computer monitor into one of the battery backup outlets labeled "battery backup plus surge protection" on the battery backup. (APC power supplies have some outlets that provide only surge protection while the other outlets provide surge protection plus battery backup.) Turn the monitor on. Unplug the battery backup power cord from the wall outlet. If the monitor remains on, the battery is holding a charge, supplying electrical power and the battery backup is working properly. If the monitor goes off, proceed to step four.
  • 4 Charge the battery. Plug the battery backup into an electrical outlet and allow the battery to charge for 16 hours. This will fully charge the battery.
  • 5 Test battery charge. Once the battery is fully charged, repeat step three. If the monitor stays on when power is interrupted to the battery backup, the issue is solved and the problem resulted from an incompletely charged battery. If the monitor turns off when power is interrupted, the battery within the battery backup is faulty and needs to be replaced.
  • 6 Replace the battery backup unit. The unit itself is faulty. If the battery backup is under warranty, contact APC to request a replacement.
  • Nov 28, 2013 | Computers & Internet
    Battery light
    On this issue i suggest you to get the battery and its connections checked.
    Either battery is got weak or the problem is related to loose battery connections.Some times battery connectors gets dirty and cause no connection issue.So disconnect battery terminals,clean them and reconnect and check ,if that is helping.
    Also if the battery is got very old,then try with new battery.
    For more detailed help,related to these issue,i suggest you to click the help links provided below:-----
    Battery light stays steady ON? http://technoanswers.blogspot.in/2012/02/ford-ranger-battery-light-stays-steady.html
    Battery Light and ABS Light on Dash http://whoisbyme.blogspot.in/2012/07/battery-light-and-abs-light-on-dash.html
    Battery Warning Light Flashing on Dash? http://whatisbyme.blogspot.in/2012/05/2007-toyota-rav4-battery-warning-light.html
    Service Battery Warning Light On Dash? http://whoisbyme.blogspot.in/2012/06/service-battery-warning-light-on-dash.html
    How to Inspect Car battery? http://repairhelpcenter.blogspot.com/2011/12/how-to-inspect-car-battery.html--------- How to Test Car Battery? http://repairhelpcenter.blogspot.com/2011/12/how-to-test-car-battery.html--------- Car Battery Servicing? http://repairhelpcenter.blogspot.com/2011/12/car-battery-servicing.html--------- How to Replace Car Battery? http://repairhelpcenter.blogspot.com/2011/12/how-to-replace-car-battery.html-------- How to Inspect Car battery Terminals? http://repairhelpcenter.blogspot.com/2011/12/how-to-inspect-car-battery-terminals.html-------- How to clean car Battery terminals? http://repairhelpcenter.blogspot.com/2011/12/how-to-clean-car-battery-terminals.html---------- How to Replace Broken Car Battery Cables? http://repairhelpcenter.blogspot.com/2011/12/how-to-replace-broken-car-battery.html
    These details will help.
    Thanks.
    Oct 06, 2012 | Cars & Trucks
    How to change the battery
    Remove the battery box compartment cover. Disconnect the positive and negative battery leads. Undo the battery holding down clamp screws and remove the battery clamp, now you can lift out the battery.
    Place the new battery in the battery box and secure the battery hold down clamp. Connect the battery leads to the battery, the red lead to the battery's positive terminal and the black negative lead to the battery'e negative terminal, then replace the battery box cover.
    Mar 16, 2012 | 2002 Suzuki LS 650 Savage
    I want to put 4 batteries together 4x 12v 7AH. and how many volts and AH would that be.
    It depends on how you connect the batteries. If you connect the negative of battery one to the positive of battery 2, the negative of battery 2 to the positive of battery 3 the negative of battery 3 to the positive of battery 4 then the positive of battery 1 and the negative of battery 4 will give you 48v 7AH. (This is known as connecting in series.)
    If you connect the four positives together. Connect the 4 negatives together it will give you 12v 28 AH. (This is known as parallel connection.)
    If you connect the negative of battery 1 to the positive of battery 2. Connect the negative of battery 3 to the positive of battery 4. Connect the positive of battery 1 to the positive of battery 3 and the negative of battery 2 to the negative of battery 4. You'll get 24v 14AH from the connection of the positive of battery 1 and battery 3, and the negative of battery 2 to battery 4. (This is known as series parallel connection)
    Jul 19, 2011 | Electric Cycling
    I have 4 x 12v batteries 7ah each. if i put these 4 batteries together . how many volt and AH would this be. please reply . thank you
    I need a new battery for my 1986 Oldsmobile ninety-eight regancy sedan. fully loaded. what type of battery would i need?
    Attributes Battery BCI # : 75
    Battery CA @ 32 Degrees F : 775
    Battery CCA @ 0 Degrees F : 630
    Battery Height : 7 1/4"
    Battery Length : 9 3/4"
    Battery Posts Type : Side Post
    Battery Reserve Capacity : 90
    Battery Voltage : 12 volt
    Battery Weight : 33 lbs.
    Battery Width : 7"
    Wet or Dry : Wet
    A lead acid battery with the fallowing specs
    group 75
    Battery Width : 7"
    Wet or Dry : Wet
    Battery Width : 7"
    Wet or Dry : Wet
    Battery BCI # : 75
    Battery Width : 7"
    Wet or Dry : Wet
    Feb 27, 2011 | 1986 Oldsmobile Regency
    Battery size for a 2003 chevy tracker
    Here is the information on the battery size from NAPA. The CA(cranking amps) and CCA(cold cranking amps) can be changed within a certain amount but the dementions should stay the same as well as it being a top post battery.
    Battery CA @ 32 Degrees F : 780
    Battery CCA @ 0 Degrees F : 625
    Battery Height : 8"
    Battery Length : 9 1/16"
    Battery Load Test Amps : 312.5
    Battery Posts Type : Top Mount
    Battery Reserve Capacity : 95
    Battery Weight : 32.5
    Battery Width : 6 13/16"
    Nov 16, 2010 | 2003 Chevrolet Tracker
    Nikon D40x indicate battary low
    Rechargeable Lithium-ion 7.4V 1000mAh Nikon D40x battery for sale,20% off! Full one year warranty! For more info visit: http://www.nikon-coolpix-replacement-battery.com/d40x.htm
    May 13, 2009 | Nikon D40x Digital Camera
    Garmin nuvi 255W GPS Receiver Logo
    Top Garmin GPS Experts
    SHARCNET-USA
    SHARCNET-USA
    Steve
    Are you a Garmin GPS Expert? Answer questions, earn points and help others
