Question about Samsung SyncMaster 740N 17" LCD Monitor
It takes a couple of minutes at least for my Samsung SyncMaster 914v to come on after the computer is asleep. You can hear the click through the speakers when you move the mouse but takes forever for the monitor to come on. Sometimes I just reboot
  • hiscoxfamily Sep 05, 2010
    Thanks for the suggestion....I am pretty handy....Is it something i can replace my self....If so where do i get electrolytic capacitors.
    Thanks rick
  • 10,594 Answers
This symptom appears when electrolytic capacitors in power supply output section become weak/ leaky.
Replace leaky/ dried up capacitors in power supply of monitor this will solve your problem.
Thanks.
Posted on Sep 05, 2010
  • Shahid Electronics
    Shahid Electronics Sep 05, 2010
    If you can solder parts in circuit board then yes, you can do it.
    Radio Shake or local tv spare part shop would have replacement capacitors, note down capacitors value and get replacement of same to install in power supply board.
What adaptor do i need to connect a new Mac Mini with HDMI input to an older SyncMaster 914v?
I assume you mean HDMI output. You'd need a 'HDMI Female to VGA Male' adapter or a 'HDMI Male to VGA Male' cable.
Such as:
http://www.sourcingmap.com/17m-golden-plated-hdmi-vga-male-adapter-converter-cable-p-61779.html?currency=GBP&utm_source=google&utm_medium=froogle&utm_campaign=ukfroogle
I've no idea if that site is reputable or not, just did a search on Google.
Jan 20, 2011 | Samsung SyncMaster 914V 19" Flat Panel LCD...
Green power light is on....flashes lowly......black screen
It is a hardware problem so pls checked it from service center.
Oct 14, 2010 | Samsung SyncMaster 914V 19" LCD Monitor
Samsung syncmaster 914v monitor problem. Right side of display is darker image. Can see dots like a newspaper print or looking through a screen. When display is black it almost appears like an image is...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 15, 2010 | Samsung SyncMaster 914V 19" LCD Monitor
Samsung syncmaster 914v monitor problem. right side of display is darker image. can see dots like a newspaper print or looking through a screen. when display is black it almost appears like an image is...
This is likely the LCD panel itself - you are describing a left/right image error that can be only created by the left/right division by the LCD driver wrapped around the outside of the LCD panel.
If your monitor uses a separate circuit board to drive the LCD, it could be this driver board.
Either way, it will require an LCD panel - $$$
Mar 29, 2010 | Samsung SyncMaster 914V 19" LCD Monitor
My samsung syncmaster 914v isnt working when i plug it in and turn it on all it does is flicker every like 10 seconds
Ok, a few basic things to check/try.
  1. What colour is the power LED, does it change when the screen flickers?
  2. Is the power cable firmly seated.
  3. Is the monitor cable firmly seated.
  4. Try another power lead.
  5. Take a look at the plugs on the monitor lead, does it look like there are any bent/broken pins.
  6. Again, try another monitor lead.
  7. Try connecting the monitor to another pc.
If none of these have any effect, you'll need to take it in somewhere to get it looked at.
Feb 25, 2010 | Samsung SyncMaster 914V 19" Flat Panel LCD...
My computer monitor work fine to it gets hot an then it cut off an blinks when u cut it back on
This is 2006 monitor, it is time to inspect the power supply for bad caps with bulging top, post back what you see so we can guide you further, see example of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 16, 2010 | Samsung SyncMaster 914V 19" LCD Monitor
Samsung 914v 19" LCD pixels went out
hi,
your lcd micron tube in the panel had already worn out.
got to replace the panel
Jan 31, 2010 | Samsung SyncMaster 914V 19" LCD Monitor
Unlocking Monitor
just hold the menu button on the monitor for 10 sec or more and it will unlock it
Sep 15, 2008 | Samsung SyncMaster 914V 19" Flat Panel LCD...
Samsung SyncMaster 740N 17" LCD Monitor Logo
96 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
