Question about Creative Labs Inspire 6600 Computer Speakers
Speakers Popping loudly occasionally. Died for several days. Now working again but still making sounds.
Ive had my Creative Inspire 6600 speaker system for several years and its always worked "fine". However in the last couple months the speakers started making popping noises until it finally died. One night I had no problems what so ever and after turning my computer, the next day the sound system simply didnt work. The sound card was fine, as I could plug head phones into the computer itself to listen to things.
A friend and I took it apart and found no obvious visual problems. (Shorts, burns, blown fuses etc). It still did not work. After about 2 weeks, I was able to get it to work again, but it is already starting to make that same popping noise again. My current temporary solution is to use it only for a few hours then unplug the system all together in hopes of prolonging its life.
Im hoping to get some sort of idea of replacing or any sort of fix to  this problem. I cannot afford to simply buy a new system, so Im hoping that I could get some help, please. If not I will be blamed for it breaking down.
  • 4 more comments
  • AKComputer May 13, 2008
    No Power after spotty performance - It seems mine had acted the same. I suspect the AC Adapter . I am trying to find a replacement.
  • Taiidan May 14, 2008
    I was thinking the same, thing is my friend said that he had never seen a 13.5 volt before, making him puzzled. I try to let it rest by unplugging it when not in use so I get some use out of it.
  • Taiidan Jun 02, 2008
    Finally died all together...
  • Taiidan Jun 06, 2008
    Mine will still work for... anywhere from 2 seconds to 10 minutes if I leave it unplugged for several days. It seems entirely random. Maybe mine is the 13.5 but somehow I doubt it. Thanks for trying.
  • Taiidan Jun 10, 2008
    I took the subwoofer apart too, however found nothing of the sort, however mine still works from time to time. It can just suddenly work, and I can use it, then a sudden "Pop!" and it all goes down again, for a few minutes or several days. This is so long as I keep it unplugged, Maybe ill check the sub woofer again.
  • Anonymous Mar 20, 2014
    The speakers were working perfectly until one day there was no sound. I thought I unplugged from power accidentaly so I removed power and plug it in again.They worked.To day same thing happened.Suddently no sound.When i take power out and plug it for a second sound comes out perfectly. Also if I turn volume up to max sound comes out.What makes them work, even for a second, when I plug in and out the power?
The problem is a burned transistor inside the subwoofer. It depends of country's transistor manufacturer. It is supposed to be of a low quality. It's not important for the scope. Mine is knocked down for a year. I saved the electronic schematic diagram and the transistor specs, but lost. I confirmed the cause opening the subwoofer and examine the board. The indicated transistor surrounded area is burned indeed. If anyone find the article in web, please, post here.
Posted on Jun 10, 2008
Mine is dead, tried a 13.5 volt diff. amp adapter to no avail. The internal fuse was fine also. Couldn't find any support from mfr.
Posted on Jun 02, 2008
  • 73 Answers
Ok, I have the 5300 model, that I won years back on the Creative site, and has being doing this to me too!, does the power led on the volume control dim when it does this? on yalls?, on mine it dims, comes back on, and sounds ok, then speakers pop, and crackle and start sounding really bad!, someone please help!, by the way, lucco... are your talking about the voltage regulator? the transistor? If I replace it, will it work again??? please someone help!!!, I have no $$ to buy new speakers! (good ones with 5.1!)
I have tried resoldering all joints (almost) thinking it could be cold solder joints!... hate to use headphones!@#@$@#%$%
Posted on Jun 27, 2009
Speaker level really low
you have to make sure you increased the volume on the computer itself.go to the control panel and click on sound,speech and audio devices.change the volume settings and speaker settings.this should bring about the desired result.
Jul 01, 2010 | Creative Labs Inspire 6600 Computer...
Creative Inspire 5200 system won't work
Hi. Check your speaker system with a different audio device like iPod or any MP3 Player using the same jacks. If the speaker system gives out sounds then nothing is wrong with it... if no sounds come out, then you know what I mean...
Try to replace the speaker of your sub-woofer... maybe that can fix it!
^_^
Jun 06, 2010 | Creative Labs Inspire 5200 Computer...
My creative speakers woofer is damege plz repair woofer.
sir I am using 2.1 creative inspire speakers system, at present no sound is coming in the speakers or woofer, what is the problem.
power is on and after connecting the speakers to woofer from pc no sound is coming. what is the problem. please help me. thanks rajanna
Jun 01, 2010 | Creative Labs Inspire 6600 Computer...
How can i play 5.1 speaker in windows7
Hi bud , Its not windows 7 you need to be worried about....First make sure you have a 5.1 Channel Sound Card , Something that looks like this http://site.high-techoffice.com/dxsc512.jpg
If you have that , Then your speakers will work perfect...
Also make sure you installed your Audio drivers..Windows 7 usualy does it automaticly...But just double check
Hope you come right bud
happy new year
Jan 07, 2010 | Creative Labs Inspire 6600 Computer...
Creative inspire 4.1 volume control got wet
sir i want creative 4.1 volume control wire please
pavanpralhad@gmail.com
Sep 30, 2009 | Creative Labs Inspire 4400 Computer...
Ive got creative inspire T7900 7.1 speaker system attached to my pc.one of the speaker connections in sub-woofer is faulty ? the sub-woofer seems to be a sealed unit so cant take panel off to have a look...
Is this connecting to a sound blaster audigy 2 zs or xfi soundcard? or a motherboard onboard soundcard/ aftermarket Other than creative?
If connected to the creative card odds are the wire is bad. get a new one
If connected to a generic the wires for the speakers are proprietary and you have to go get 3.5 to 3.5 stereo cables to hook it up
Sep 04, 2009 | Creative Labs Inspire T7900 Computer...
No sound from rear and center speakers Creative t6100
Go insto your speaker properties/configuration from the little speaker icon in your taskbar. Check to make sure you have it configures in a 5.1 format rather than stereo. If it is set in stereo change to 5.1 & hit the test icon. All speakers should now be working. Hope this helps.
Jun 08, 2009 | Creative Labs Inspire T6100 Computer...
Center & sub-woofer problem
The outputs may have died if this is the case you will need to get them fixed by a proffesional
Mar 15, 2007 | Creative Labs Inspire 5200 Computer...
Creative Labs Inspire 6600 Computer Speakers Logo
589 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
