Question about Starvision SP-7VGA11 Pixelon 7" Monitor Entertainment with Headrest Shroud
I need the power connections for installation.
How to install a power supply into a Gateway SX2801-01E
The form factor is your main obstacle. It needs to fit the case. Second there is the motherboard power. It could be 20 or 24 pin. From there you need the 4 or 8 pin CPU power. The rest are just adapters (with spares) for your hardware like MOLEX or SATA. These can have adapters to convert to and from. So, your only real concern is 2 connections, and even these can be converted with adapters.
Nov 27, 2012 | Computers & Internet
Can't install power supply
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Unplug all electronic cords connected to the computer.
At no time during the installation should any cords be connected to the computer.
Remove the screws holding the computer cover case, and remove the cover case.
Locate the computer power supply box, which looks like a large box out of which a bundle of wires run and connects to the power cord jack on the outside of the computer case.
Unplug the power cables from the internal devices connected to it.
Be careful not to damage any of the sensitive control boards or devices inside the computer, and be certain to remember write it down if you need to what devices will need reconnecting to the new power supply when you finish the installation.
Unscrew the power supply from the inside of the computer case and remove it.
Check the original power supply's red voltage switch for the correct setting.
It should read 120 or 240 if you live within the United States.
Confirm this setting as the correct voltage setting for your power outlets.
Make sure your new power supply gets set to the correct voltage setting before you install it.
If it cannot be set to the correct voltage, do not proceed with the installation or you may damage your computer.
Return the new power supply and buy one that is compatible with the voltage requirements.
Install the new power supply, reattach the screws that will hold it in the proper place inside the computer.
Reattach the power cables that come from the new power supply to the devices that were connected to the old power supply.
Make sure all of these connections are firmly in place before you turn the computer back on.
Reattach the computer power cables and all the cords connected to the computer during normal operation, but do not close the computer case yet.
Keep your hands clear of the inside of the computer case as you attach power cords and peripheral devices.
Turn the computer on and observe the performance of the computer without touching anything inside.
Do all the computer fans function normally?
Does the computer operate as well as or better than before?
If you feel that the computer behaves normally and you do not encounter any problems, turn the computer off, remove all the power cords and peripheral cables once more, and close the computer case.
Then reattach the power cords and peripheral cables and begin using the computer.
Check for errors if you encountered any problems starting the computer or if it would not start at all, unplug all the power cords and computer cables connected to the computer and look inside.
Make sure that you connected all the correct power cables inside the computer securely and did not miss any.
If you have confirmed this and the computer still doesn't start or operate normally, call your computer manufacturer or a professional computer repair shop for assistance completing the installation.
Most power supply units will fit
Like everything else in our high-tech world, power supplies come in myriad sizes and shapes
you should check all the electrical connections before you make a decision and make sure they are the same as the ones that you will need to run your computer also
Check the measurements inside the frame to make absolutely sure it will fit,
http://www.youtube.com/watch?v=mKw0bij8CDs
Hope this helps
Nov 13, 2012 | Insignia D400a PC Desktop
Do not know how to connect power supply
Be careful not to damage any of the sensitive control boards or devices inside the computer, and be certain to remember--write it down if you need to--what devices will need reconnecting to the new power supply when you finish the installation.
Unscrew the power supply from the inside of the computer case and remove it. Check the original power supply's red voltage switch for the correct setting.
http://www.youtube.com/watch?v=xvClS_M-09o&feature=watch_response_rev
watch video
hope this helps
Oct 10, 2012 | Computers & Internet
What kind of power cord does the hp scanjet 3970 need?\r\nalso the cord to conect to the computer. I have set it up on my HP laptop and it will not scan . I keep getting the message that I need to check if...
Let's compare bananas with bananas and apples with apples... if you have the unit ON with some lights and some activity going on, than the POWER CORD is just fine... you seam to refer of a communication problem (not a power problem) from the unit to the computer... normally for HP multi-function devices you have to install a USB cable and the software FIRST than connect the unit when the installer ask you to do so, FIRST UN-INSTALL all drivers & software you installed previously, reboot the computer with the unit OFF, connect the USB cable, than pop in the installation CD, go through the setup (accordingly) than when the installer ask you to connect the unit, turn it ON, than let the installer finish the configuration...
Hope this helped!
Mar 13, 2011 | HP scanjet 3970 digital flatbed scanner
This is my first build and all the connections are a bit confussing need picts of how to install cables to hardware
The following picture will definitely help you to install new power supply.
The 4 pin CPU power connector is using in most of the desktop motherboard. If your motherboard is gaming type or workstation board you need to connect 8pin CPU power connector. Molex connectors are using to power up DVD Drives and HDDs. In New model power supply instead of molex connector SATA Power connectors are coming.
Feb 12, 2011 | Thermaltake Toughpower XT TPX675M 675W ATX...
Hi i buy all pc parts but i can't fit it how can i fit it?
Step 1: Installing the motherboardp1010185.jpgMake sure you have all the components in place and a nice, clean and big enough place to work with.
Put your antic-static wrist ******** to prevent your components from getting affected. Make sure your hands are clean before starting. First we will be installing the motherboard which is a piece of cake to install.
  • Open the side doors of the cabinet
  • Lay the cabinet on its side
  • Put the motherboard in place
  • Drive in all the required screws
Tip: Most motherboards come with an antistatic bag. It is advisable to put the motherboard on it for some time and then remove it from the antistatic bag before placing it in the cabinet.
Step 2: Installing the CPUCPU is the heart of a computer so make sure you handle it properly and do not drop it or mishandle it. Also try not to touch the pins frequently so that they do not get dirty. Get hold of your motherboard and CPU manual. You need to place the CPU on the dotted white patch of the motherboard in a particular fashion for it to fit properly. There is a golden mark on the CPU to help you assist. Consult both your motherboard and CPU manual to see which position it fits exactly or you could also use try all the 4 positions.
  • Lift the CPU lever on the motherboard
  • Place the CPU properly on the motherboard
  • Pull down the lever to secure the CPU in place
Warning: Do not try to push the CPU into the motherboard!
Got the thermal compound? Now is the time to use it. Take small amount of it and carefully apply it on the top surface of the processor. Be careful not to put it on the neighboring parts of the motherboard. If you do so clean it immediately using the cloth.
Tip: Thermal compounds should be changed once every six months for optimal performance.
Step 3: Installing the heat sink0181.jpgAfter installing the processor we proceed to installing the heat sink. There are different kinds of heat sinks that are bundled with the processor and each has a different way of installation. Look into your CPU manual for instructions on how to install it properly.
  • Place the heat sink on the processor
  • Put the jacks in place
  • Secure the heat sink with the lever
After this you will need to connect the cable of the heat sink on the motherboard. Again look into the motherboard manual on where to connect it and then connect it to the right port to get your heat sink in operational mode.
Step 4: Installing the RAMinstallingram.gifInstalling the RAM is also an easy job. The newer RAMs ie. DDR RAMs are easy to install as you don't have to worry about placing which side where into the slot. The older ones, SDRAMs are plagued by this problem.
If you want to use dual channel configuration then consult your manual on which slots to use to achieve that result.
  • Push down the RAM into the slot
  • Make sure the both the clips hold the RAM properly
Step 5: Installing the power supplypsu1.jpgWe will now install the power supply as the components we install after this will require power cables to be connected to them. There is not much to be done to install a PSU.
  • Place the PSU into the cabinet
  • Put the screws in place tightly
Tip: Some PSU have extra accessories that come bundled with it. Consult your PSU manual to see how to install them.
Step 6: Installing the video card 110665-2107p146-5b.jpgFirst you will need to find out whether your video card is AGP or PCI-E. AGP graphics cards have become redundant and are being phased out of the market quickly. So if you bought a spanking new card it will certainly be a PCI-E.
  • Remove the back plate on the cabinet corresponding to the graphics card
  • Push the card into the slot
  • Secure the card with a screw
  • Plug in the power connection from PSU (if required)
High-end graphics cards need dedicated power supply and if your graphics card needs one then connect the appropriate wire from PSU into the graphics card.
Step 7: Installing the hard disk042b.jpgHard disk is another fragile component of the computer and needs to handled carefully.
  • Place the hard drive into the bay
  • Secure the drive with screws
  • Connect the power cable from PSU
  • Connect the data cable from motherboard into the drive
If your hard drive is a SATA one then connect one end of SATA cable into the motherboard and other into the SATA port on the hard disk. If your hard disk is PATA type then use the IDE cable instead of the SATA cable.ide-sata.jpgTip: If your PSU does not support SATA power supply then you will need to get an converter which will convert your standard IDE power connector to a SATA power connector.
Step 8: Installing optical driveThe installation an optical drive is exactly similar to an hard drive.027.jpg
  • Place the optical drive into the bay
  • Drive in the screws
  • Connect the power cable and data cable
Tip: When installing multiple optical drives take care of jumper settings. Make sure you make one as primary and other slave by using the jumper. This is not applicable if the drives are SATA drives.
Step 9: Connecting various cablesFirst we will finish setting up internal components and then get on to the external ones. You will need to consult your motherboard manual for finding the appropriate port for connecting various cables at the right places on the motherboard.
  • Connect the large ATX power connector to the power supply port on your motherboard041a.jpg
  • Next get hold of the smaller square power connector which supplies power to the processor and connect it to the appropriate port by taking help from your motherboard manual
  • Connect the cabinet cables for power,reset button in the appropriate port of the motherboard
  • Connect the front USB/audio panel cable in the motherboard
  • Plug the cable of cabinet fans
You are done with installing the internal components of the PC. Close the side doors of the cabinet and get it upright and place it on your computer table. Get the rest of the PC components like monitor, keyboard, mouse, speakers etc. which we will connect now.
  • If mouse/keyboard are PS/2 then connect them to PS/2 ports or else use the USB port
  • Connect the speaker cable in the audio port
  • Plug in the power cable from PSU into the UPS
  • Also plug in the power cable of the monitor
You are now done with setting up your PC. Power on and see your rig boot to glory.
Step 10: Installing the OS and driversWe are done with the hardware part. Now get your favorite OS disks ready and the CD that came with your motherboard.
  • Set the first boot device to CD/DVD drive in BIOS
  • Pop in the OS disk
  • Reboot the PC
  • Install the OS
  • Install drivers from motherboard CD (applicable only to Windows OS)
Voila! You have your PC up and running. Enjoy your journey with your self assembled rig!
Jargon Buster
  • CPU - Central Processing Unit
  • RAM - Random Memory Access
  • DDR -Double Data Rate
  • SDRAM - Synchronous Dynamic Random Access Memory
  • PSU -Power Supply Unit
  • AGP - Accelerated Graphics Port
  • PCI-E - Peripheral Component Interconnect- Express
  • SATA - Serial Advanced Technology Attachment
  • PATA -Parallel Advanced Technology Attachment
  • IDE - Integrated Drive Electronics
  • ATX - Advanced Technology Extended
  • USB - Universal System Bus
  • VGA - Video Graphics Array
  • PS/2 - Personal System/2
  • OS - Operating System
Nov 13, 2010 | Computers & Internet
I need to know how to take the power steering off a 1997 dodge caravan?
Power Steering Pump-Let me know if you need to take the power steering gear off: Removal & Installation 2.4L Engine To Remove:
  1. Disconnect and isolate the negative battery cable.
    • Remove as much fluid as possible from the power steering fluid reservoir using a siphon pump.
    • Remove the drive belt from the power steering pump.
    • Loosen the nut securing the front power steering pump bracket to the aluminum bracket.
    • Raise and safely support the vehicle.
    • Place a drain pan under the vehicle to catch the power steering fluid.
    • Disconnect the connector from the oxygen sensor at the rear engine mount bracket. NOTE: The exhaust system needs to be moved to allow room for power steering pump removal.
    • Remove the bolts and nuts securing the catalytic converter to the exhaust manifold.
    • Disconnect the exhaust system hangers from the brackets. Move the exhaust system rearward and left as far as possible.
    • Raise the heat sleeve to expose the clamp and then disconnect the fluid return hose from the steel tube. Allow the fluid to drain.
    • Remove the accessory drive splash shield.
    • Remove the supply hose coming from the reservoir from the power steering pump. Drain the fluid from the hose.
    • Disconnect the pressure hose from the pump. Drain off excess fluid from the hose.
    • Remove the return hose from the pump. Allow the fluid to drain from the tube.
    • Remove the nut from the rear of the pump to the cast mounting bracket.
    • Loosen the three bolts securing the pump to the front mounting bracket. Then remove the nut and remaining bolt.
    • Remove the power steering pump and the front bracket from the cast bracket on the engine as an assembly through the exhaust tunnel.
    • Remove the three bolts attaching the front bracket to the power steering pump and separate the power steering pump from the front bracket.
To Install:
  1. Install the power steering pump through the exhaust tunnel of the vehicle.
  2. Loosely install the nut on the rear of the pump to hold the pump to the bracket.
  3. Install the front bracket on the pump and install the three bolts loosely.
  4. Install the nut and bolt securing the bracket to the cast bracket.
  5. Tighten the three front bracket-to-pump bolts to 40 ft. lb. (54 Nm).
  6. Connect the pressure hose to the power steering pump. Make sure to inspect the o-ring and replace as needed. Tighten the fitting to 275 in. lb. (31 Nm).
  7. Connect the low pressure return hose to the power steering pump.
  8. Connect the supply hose from the reservoir to the pump. Make sure the hose is not near drive belt.
  9. Install the drive belt and splash shield.
  10. Connect the fluid return hose to the steel tube on the cradle and cover with the heat shield sleeve.
  11. Properly position the protective heat sleeve over the return hose. Secure the heat sleeve with a tie strap to the hose to keep it in place.
  12. Install the exhaust system.
  13. Connect the oxygen sensor wiring connector to the vehicle wiring harness.
  14. Lower the vehicle.
  15. Connect the negative battery cable.
  16. Fill and bleed the power steering system.
  17. Check for leaks.
3.0L Engine To Remove:
  2. Remove as much fluid as possible from the power steering fluid reservoir using a siphon pump.
  3. Remove the drive belt from the power steering pump.
  4. Raise and safely support the vehicle.
  5. Place a drain pan under the vehicle to catch the power steering fluid.
  6. Disconnect the connector from the oxygen sensor at the sensor wiring harness grommet on the floor pan. NOTE: The exhaust system needs to be moved to allow room for power steering pump removal.
  7. Remove the bolts and nuts securing the catalytic converter to the exhaust manifold.
  8. Disconnect the exhaust system hangers from the brackets. Move the exhaust system rearward and left as far as possible.
  9. Raise the heat sleeve to expose the clamp and then disconnect the fluid return hose from the steel tube. Allow the fluid to drain.
  10. Remove the accessory drive splash shield.
  11. Remove the supply hose coming from the reservoir from the power steering pump. Drain the fluid from the hose.
  12. Disconnect the pressure hose from the pump. Drain off excess fluid from the hose.
  13. Remove the two bolts securing the pump to the alternator/power steering pump/belt tensioner bracket.
  14. Remove the pump from the bracket and remove it from the vehicle through the exhaust tunnel on the floor pan.
To Install:
  2. Install the pump on the bracket with the two mounting bolts. Tighten the two bolts to 40 ft. lb. (54 Nm).
  3. Install the pump rear support bracket. Tighten the nut and bolts to 40 ft. lb. (54 Nm).
  4. Connect the pressure hose to the power steering pump. Make sure to inspect the o-ring and replace as needed. Tighten the fitting to 275 in. lb. (31 Nm).
  5. Connect the low pressure return hose to the power steering pump.
  6. Connect the supply hose from the reservoir to the pump. Make sure the hose is not near drive belt.
  7. Install the drive belt and splash shield.
  8. Connect the fluid return hose to the steel tube on the cradle and cover with the heat shield sleeve.
  9. Properly position the protective heat sleeve over the return hose. Secure the heat sleeve with a tie strap to the hose to keep it in place.
  10. Install the exhaust system.
  11. Connect the oxygen sensor wiring connector to the vehicle wiring harness.
  12. Lower the vehicle.
  13. Connect the negative battery cable.
  14. Fill and bleed the power steering system.
  15. Check for leaks.
3.3L & 3.8L Engines To Remove:
  3. Raise and safely support the vehicle.
  4. Disconnect the connector from the oxygen sensor at the sensor wiring harness grommet on the floor pan. NOTE: The exhaust system needs to be moved to allow room for power steering pump removal.
  5. Remove the bolts and nuts securing the catalytic converter to the exhaust manifold.
  6. Disconnect the exhaust system hangers from the brackets. Move the exhaust system rearward and left as far as possible.
  7. Place a drain pan under the vehicle to catch the power steering fluid.
  8. Raise the heat sleeve to expose the clamp and then disconnect the fluid return hose from the steel tube on the cradle. Allow the fluid to drain into the pan.
  9. Remove the accessory drive splash shield.
  10. Remove the drive belt from the power steering pump.
  13. Disconnect the return hose from the pump. Drain the fluid into the drain pan.
  14. Remove the power steering pump rear support bracket.
  15. Remove the three bolts securing the pump to the alternator/power steering pump/belt tensioner bracket.
  16. Remove the pump from the bracket and remove it from the vehicle through the exhaust tunnel on the floor pan.
To Install:
  2. Install the pump on the bracket with the three mounting bolts. Tighten the bolts to 40 ft. lb. (54 Nm).
  3. Install the pump rear support bracket. Tighten the fasteners to 40 ft. lb. (54 Nm).
Oct 13, 2010 | 1997 Dodge Caravan
Connector problem...
The card doesn't need a power connection. I would download the driver first, then install the card. If the driver will not install this way, install the card first.
Aug 13, 2009 | ATI RADEON 9250, (256 MB) PCI Graphic...
Need plain install instructions
Let me see if I can help
Power coming in from the live circuit ( Main Power ) needs to connect to The A Terminal and #1 Terminal and the ground point.
Power connection out to the equipment you want times connects to the A terminal and then the #2 Terminal and then the same ground point.
The #1 and #2 Terminals are your break point switch, so when the timer is one power is applied to the #2 terminal, when off, no power to the #2 terminal.
Hope that helps some.
Feb 15, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
Car stereo wiring installation
red wire connect to accessories or constant power 12volt
black wire connect to earth /ground/ metal
yellow for clock and memory connect to permanent power
blue wire connect to amplifier
2x rc connect to amplifier
8x speaker wires connect to 4 speakers
just ask if you need more help glenn..........
Nov 22, 2008 | 2005 Mitsubishi Lancer
Car Audio & Video Logo
32 people viewed this question
Top Starvision Car Audio & Video Experts
xxxxxx xxx
Are you a Starvision Car Audio and Video Expert? Answer questions, earn points and help others
