Question about Haier HMSE03WAWW (33 cu ft) Compact Refrigerator
I have a Haier HMSE03WAWW Compact Refrigerator and it was running fine for about a year. All of a sudden it stopped running. I unplugged it for a day and plugged it back in and it started running. Got a little chilled and then stopped again. I need help as to why it won't stay on.
  • Haier Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 05, 2010
My mini fridge stopped working while I was at work
RF-6850-16 Start Relay
Is the compressor again getting hot once you turn the temperature down? Will the refrigerator cool if you turn the temperature to as cold as it can get? Reason I ask is I am trying to decide if it is the thermostat or a defective staryt relay. Even at the cost of parts I would be careful and sure of what you are going to do here. Haier is not well know for quality products or customer support and there are other brands names out there that will support customers much better than Haier. Not trying to say bad things about your refrigerator I just hate to see when people invest into something and then get left holding something that Haier will not help with and does to all of their customer. Thanks Sea Breeze
I have lost valuable customers because of Haiers lack of customer support.
May 29, 2013 | Haier HMSE03WAWW (33 cu ft) Compact...
Had the compact refrigerator for about 4 years now,then it suddenly stopped working.all I hear is a click sound about every ten minutes. Mode; # ASE27W, need assistance......HELP!! I Love my compact refer.
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. The relay is a small usually black cube shaped electrical part plugged into the compressor or wired to it nearby. It may appear burnt or rattle when shaken if it's bad. The two connections should show continuity with an amp meter. If it's good then it's most likely the compressor causing the problem.
May 25, 2011 | Haier Refrigerators
My Haier compact refrigerator, Model # AES27, stopped running. I unplugged it and then plugged it back in and only hear a humming sound for like 10 seconds and then nothing.
These are noted for bad controller boards. It is located under the back cover. Look under the cover and see if the control circuit board is blackened or smells burned. You can get parts at this link:
http://www.repairclinic.com/Haier-Parts?gclid=CMajgvvFpqYCFYdi2godeBsFmA
Jan 06, 2011 | Haier HSB03 Compact Refrigerator
Will not run have only had for 2 years and just suddenly stopped running
heatman101
Sep 04, 2010 | Haier HSB03 Compact Refrigerator
Cools but constantly runs
you hit the nail on the head there,,,its the thermostat its dead!
change it they often stick in the on poshion when they stop working to save any food inside of the fridge
Jul 12, 2010 | Haier HSB03 Compact Refrigerator
New fridge
Hi!!! sorry to inform you , but you have a seal system problem.Them haier frigs have problems with the seal system..You i\either have a restriction or a leak in the evaporator..
Jan 14, 2009 | Refrigerators
Compressor on Haier hmse03waww mini-frige shuts off after 10-20 minutes and is hot to the touch.
If the temperature in the refrigerator is correct then this is proper function for the compressor. It should run until the desired temperature is reached then shut off. The compressor also gets really warm. If the compressor is shutting off prior to the correct temperarure being reached then you may have a compressor problem. If the compressor is bad and our of warranty, it is time for a new refrigerator. If it is still under a warranty, call for factory service. Good luck, and I hope this helps.
Mike
Sep 29, 2008 | Haier Refrigerators
Haier HMSE03WAWW (33 cu ft) Compact Refrigerator Logo
369 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
