The mouse touchpad,stopped working and now the mouse usb,has stopped working.
Toshiba PC laptop touch pad stopped working
Posted on Sep 09, 2010
    Problem Solver:
  • 16 Answers
Please chaeck the mouse pad lock mode or any light is glowing on top of the mouse touch pad?
Posted on Sep 05, 2010
Touchpad doesn't work
Step 1:
The touchpad of any laptop is always subject to heavy use.
Most touchpads are designed for their durability to sustain the daily wear and tear for the lifespan of the laptop.
However, there may be instances or accidents that cause the touchpads to malfunction or stop working entirely.
There are ways to troubleshoot such problems and there are also remedies to salvage the touchpad's functionality without heavy repair or replacement cost.
Determine What's Wrong
A laptop's touchpad basically provides the functionality of a mouse for a desktop PC, typically with two buttons located just below it acting as the left and right click buttons on a desktop computer. A touchpad may be damaged by excessive use or foreign substances such as water, dirt or food items. Hit the "Windows" button on the keyboard and then use the right-left keys (or hit 'C') to open "Control Panel." From there, again use the right-left keys to get to "Mouse" and then hit "Return." Use the right-left keys to toggle between the tabs and open each to investigate whether any boxes had been improperly clicked by accident that cause the touchpad to become unresponsive. But if any of these steps fail to remedy the problem, then the touchpad may need to be repaired or replaced. b> Repairing/Replacing Touchpad b> A touchpad assembly cost $100 or more and that's not including replacement installation. Hiring a specialist to replace a damaged touchpad, including parts and labor, may easily cost $200. Unless the laptop in question is worth well over $1,000 and the touchpad is deemed a necessity, such repairs are rarely worth the cost. Attempting to replace the touchpad without certain expertise in laptop assembly may be dangerous and/or destructive. Also, getting a replacement part that's not compatible with the laptop may have catastrophic results, including irreversible damage to the laptop. Long-Term and Better Solution b> The simplest, and best, solution to a malfunctioning touchpad is to replace its functionalities with an external mouse. Most PCs sold after 2000 come with USB ports and getting a USB mouse either a corded or a cordless one--will remedy the problem. A cordless USB mouse may be bought for as little as $10 and some of the better-designed ones allow the user to tuck the USB stick inside the mouse's belly when not in use. Even when a touchpad is working properly, a laptop user should be advised to plug in a mouse anyway whenever possible as touchpads are notoriously difficult to use and also leaves the user in an ergonomically incorrect position.
http://www.microsoft.com/ b> http://www.streetdirectory.com/travel_guide/116002/hardware/touchpad_keyboard_for_personal_computers__pc.html
Feb 19, 2013 | Computers & Internet
Thinkpad t510 4314 touchpad and mouse stop responding
It shows the fault of USB ports and in my point of view you need to replace with a new motherboard.
Hope it will be helpful.
Good Luck
Aug 19, 2012 | Lenovo ThinkPad T510 4314 - Core i5 520M...
My touchpad is not working for click(touch) operation. I feel that this started happening after plug in a USB mouse
When you plug in a USB mouse, the touchpad is usually automatically disabled. Look in your control panel under Mouse or Pointing devices. You will want to look at the settings to ensure that your touchpad turns back on after you unplug the mouse. If your touchpad is NOT returning to normal functionality after you unplug the mouse, try the "safely remove hardware" option (If you have windows). Look in the lower right corner of your screen. If you have a small green arrow icon that safes "safely remove hardware" when you put the mouse pointer over it, click on it. If the mouse shows up in the list, highlight it, and click Stop. You can then remove the mouse when Windows tells you it's safe to do so. This may then return full functionality of the touchpad. In some cases, the mousepad click functionality will be disabled if a USB mouse is plugged in. It can remain so if the system doesn't fully acknowledge that the mouse has been removed. That's why I'm suggesting to try the "Safely Remove Hardware" option first. If that doesn't work, there may be a physical problem with your touchpad and it will need to be serviced.
Dec 05, 2010 | Acer Computers & Internet
Asus 10065ha xp both touchpad and external mouse not working touchpad went first. then worked with external mouse. then only touchpad. now both not working.
Unplug your external mouse and restart your laptop. Check to see if the touchpad works, if it doesn't reinstall the driver. Unplug all other USB devices and plug your mouse back into a different USB port. It should be detected now. Cheers, Ravi Shanghavi
Aug 18, 2010 | ASUS Eee 4G Notebook
Touchpad stopped working on acer aspire 5517 Laptop
make sure the mouse pad switch is not turned off.
Mar 31, 2010 | Acer Aspire 5500 5570-2609 Laptop
Touchpad stopped working on my Acer Aspire 4730Z. What do I do?
Check the Acer site and download the latest driver for your touchpad. If you recently added a USB mouse check your settings and make sure that the mouse did not turn off your touchpad. That should take care of your problem.
Jul 26, 2009 | Computers & Internet
My mouse has stopped working on my acer laptop
Do you mean the touchpad or a USB mouse? if its a usb mouse try another usb port, is it wireless? if its wireless check the battery.
if its the touchpad it may be turned off, to turn it on hold down the blue FN button and look at the F1 to F12 keys, one of them has a touchpad icon and it will disable and enable the touch pad, don't worry if your not sure try them all if you wish. You will probably learn something new while your doing it :-)
Dec 28, 2008 | Computers & Internet
Toshiba satellite touchpad & keyboard stopped working
As I understand your keyboard is now working and your usb mouse. But the touchpad does not work.
Have you or someone opened up your laptop recently? If so it is possible the touchpad was not connected properly.
Can you please post the exact name of your laptop. I'll see what else I can figure out for you.
Oct 03, 2008 | Computers & Internet
Dell Inspiron 6000 Alps Touchpad not working
Try unistalling the touchpad driver, and reboot. The machine will find the touchpad and reinstall the driver automatically. These have a tenancy to glitch when using an external mouse, and this should clear it up. Let me know.
Aug 28, 2008 | Computers & Internet
Keyboard,sound,touchpad all not working keyboard, touchpad and all usb ports stopped working
kINDLY CONNECT A USB KEYBOARD AND/OR MOUSE TO TROUBLESHOOT THE NOTE BOOK IF USB KEYBOARD/ MOUSE (EXTERNAL NORMAL USB DESKTOP KEYBOARD MOUSE). THEN WE WILL BE ABLE TO TROUBLE SHOOT
Feb 29, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
655 people viewed this question
David Payne
David Payne
