Question about BUSlink MUSICA MP3-PBD1G MP3 Player
Removing write protection from Flash pen drive
Running Win2KPro, when trying to copy files to a Memorex Flashdrive 303B USB device I get the Error Message that the disk is write protected and transfer of files is prohibited until the removal of the write protection from the disk. How is that done exactly?
  • 2 more comments
  • dj456
    dj456 Sep 20, 2008
    I saved photos to my PNY flash drive that was protected on my camera from deletion would that be the cause of my flash drive saying it is write protected? If so how can I remove the write-protection so I can add more data or delete old data?
  • Anonymous Sep 27, 2008
    PNY Attache flash drive,a CD of clipart was copied onto it and as a result so was write protection.Cant format or delete,any way round this problem?
  • ruppup Nov 08, 2008
    I am having transcend 8 GB pen drive, when i plug the pen drive in to my pc it prompt that "this device is write protected" I am able to copy or delete the files from pendrive. plz help me out. its very urgent
  • Nishi1 Jan 15, 2009
  • 3 Answers
Try this
1) In My Computer, right click on the drive letter of your pendrive and
2) Eject it.
3) Then pull the card out and stick it back in.
4) Try to write to the card. If it works, GREAT!
5) If it DIDN'T work, repeat steps 1 through 4.
or this software
or this
visit us for more info
Posted on Nov 19, 2008
Device media is write protected
To disable writing access to USB drives and make all USB drives has only read-only access, follow these steps:
  1. Run Registry Editor (regedit).
  2. Navigate to the following registry key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control
  3. Create a New Key named as StorageDevicePolicies.
  4. Highlight StorageDevicePolicies, and then create a New DWORD (32-bit) Value named as WriteProtect.
  5. Double click on WriteProtect, and set its value data to 1. write-protect-usb.jpg
Once set, all users on the computer is now blocked and prevented from copying, transferring or writing any files, documents and data to the USB disk drives, without the need to restart or reboot computer. Any attempt to download or copy files to USB drive will return the following error message:
The disk is write protected.
The media is write-protected.
Remove the write protection or use another disk.
usb-removable-disk-write-protected.jpg To revert and remove the blocked write access to USB drivers, just delete the StorageDevicePolicies registry key, or delete the WriteProtect registry entry, or change the value data for WriteProtect to 0.
For user who doesn't want to manually editing the registry, simply download the following registry registration files to enable or disable the write protection (block writing attempt) to USB removable drive. Double click the .reg file unpacked from the .zip archive to merge the registry key entries.
Download DisableWriteToUSB.reg
Download EnableWriteToUSB.reg
The trick works in Windows XP SP2 and SP3, Windows Vista, Windows Server 2003 and 2008.
Feb 27, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My Memorex USB flash drive is write protected
t seems that your flash drive has some bad sectors since normally that's the error message you get when that happens, try to format your drive under disk management.
Note: your files will be erased if you format your flash drive.
If formatting your flash drive does not solve your problem I will advise you to contact Memorex technical support for better assistance, you can contact them at 1-877-363-6673
May 19, 2010 | Memorex Mega TravelDrive 4 GB USB Hard...
Bought a new USB external floppy drive. Copied a
You may have a virus causing this...OR your computer USB MIGHT not be putting out the required 1/2 amp current. That you can fix by using a powered USB hub.
Dec 09, 2009 | Memorex Computers & Internet
Write Protected USB
hi Not only your pendirve your computer system is also affected by virus . please check your pendrive with any other computer .before you connected open your pendrive format your pendrive with any other computer. if it will not work you have go for any new pendirve. bye
Jun 16, 2009 | Disney High School Musical Mix Stick 2.0...
Transcend 16GB Pendrive - error while copying
If your drive is partitioned with FAT32 then it cannot copy larger files. You have to format it using NTFS.
Jan 27, 2009 | Transcend USA 120GB Storejet 2.5" SATA -...
How to Unprotect a Write Protect Flash Drive
how to unprotect a write protect my flash drive & i cant copy paste any of my files to my flash drive it gives an error
error drive not found
Oct 18, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How to remove write protected memory card
when i attach the card reader with system and when i store the software or any thing in memory card then msg show that(cannot copy because write protected error)
Aug 29, 2008 | Nokia 3230
Error message
I had the same problem with a USB drive and a SD card. Both were only recieving 170 files to the root folder before I got this error. The solution was to reformat each using using 'FAT32' as the file system. This basically is a more modern file system that allows more files and cam about after win95. It looks like some USB drives and SD card are origninally formted with basic 'FAT'.
To reformat right click on the drive in windows explorer and select 'Format...'.
Another option if you dont need all the files in the root flder is to create a subfolder however this was not an option for me as my digital photo frame would not handle this.
Aug 28, 2008 | Packard Bell iMedia 6826 (P481000502) PC...
How do you install and use a USB Flashdrive
just try this one. try to insert your flashdrive to a usb port where it is compatible then a message will appear saying open folders to view files then you can now copy and paste a pictures or songs on the pc or on ur flashdrve.
Feb 25, 2008 | Electronics - Others
3,159 people viewed this question
Top BUSlink Audio Players & Recorders Experts
Are you a BUSlink Audio Player and Recorder Expert? Answer questions, earn points and help others
