Question about Pioneer VSX-27TX Receiver
My Pioneer VSX-27tx is stuck in standby mode, and won't turn on. Got any ideas?
4 Suggested Answers
  • 4234 Answers
SOURCE: Pioneer VSX-816
The blinking usually means that the unit is in "protect" mode. Check the output transistors for a shorted condition and replace.
Dan
Posted on Mar 18, 2008
SOURCE: Standby/ON keps blinking...Pioneer VSX-D812
JUST PRESS ADVANCED SURROUND & ENTER FOR LIKE 3 SECONDS.. THAT WILL RESET THE SYSTEM CHIP INSIDE.. :)
Posted on Apr 19, 2009
  • 30 Answers
SOURCE: Pioneer VSX-D411 receiver "Amp Error" message
Unfortunatelly your receiver has failed. The front panel is telling you one of the power modules is probably bad. Not an DIY type of repair. These parts are near $40.00, plus cost of replacing.
Look at options to replace your trusted receiver with a new one.
Good luck
Posted on Aug 02, 2009
Where can i find diagram for bad soldering for pioneer elite VSX-27TX stereo receiver?
You really should be an expert to do repairs on these recivers but if that is the case, you can get the maintenance manual here:
http://www.kallhovde.com/pioneer/tricomp/Audio/VSX/VSX-24_26_27_29_D908S_RRV2133.pdf
Jan 02, 2016 | Pioneer Audio Players & Recorders
PIONEER VSX-27TX RECIEVER
Hi!
you can locate the R9371 & R9374 beside or the same circuit of the IC 9374 Very near not far to IC 9374.
Nov 22, 2007 | Pioneer VSX-27TX Receiver
How do you troubleshoot a Pioneer VSX-1023 A/V receiver?
Try to do the factory reset on the Pioneer:
Switch the Pioneer into standby (turn it off).
1. Simultaneously press old the buttons on font panel for 5 seconds - BAND & STANDBY/ON
2. "Reset" on the front panel press
AUTO SURROUND/STREAM DIRECT
3. Then press ALC/STANDARD SURROUND
OR
Simultaneously pressing "down" and "on/off" for 5 seconds to reset the Pioneer
Mar 05, 2015 | Pioneer VSX-1023-K Receiver 7.1 Channels,...
I've got a vsx-920-k Pioneer receiver with s-11 Pioneer speakers and a s-21w Pioneer subwoofer. All of a sudden my sub stopped working and it seems like it's stuck in standby mode (blue light...
The manual is here...
http://www.pioneerprodj.eu/eur/products/42/99/S-21W/media.html
Flashing Blue is not defined in the manual.
Have you tried changing the Auto Standby switch to ON?
You can prove if the sub amp will respond to a known good input by TURNING ITS VOLUME DOWN tp start and just feeding it ANY RCA output from the receiver while playing, say, FM (to keep it simple). That way you would known in which direction the problem actually lies (internal or external).
Jul 05, 2011 | Pioneer VSX-C300 Receiver
PIONEER VSX-D606S WHEN POWERED STAYS IN STANDBY MODE- LIGHT IS ON, A CLICK IS HEARD BUT THAT IS ALL
Your unit staying in standby mode is an indication that its having a power problem. Remove its plug from the wall and fix it back into the wall, then turn it on again. If its still stuck in safe mode, then the power supply board in the unit is the cause of the problem.
The power supply board might be defective and maybe that's why the unit won't power up. Its receiving power but it cannot transfer the current to the necessary part of the unit because a capacitor, diode, etc may have been faulty. Until these bad components are replaced, the unit might not come on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Regards.....
Apr 17, 2011 | Pioneer VSX-D606S Receiver
Pioneer Elite vsx-27tx receiver with no bass!?
There may be a subwoofer mute function on your amp. The sub out is nothing more than a preamp output with a low frequency response. It is meant to be amplified by an external amp. Either check your powered subwoofer for operation or look through your operators manual for a sub mute function.
Feb 11, 2010 | Pioneer VSX-27TX Receiver
Pioneer VSX-918V-K Standby Light Flashes but will not turn on.
unplug it and press the power buton and then hold the power button, and while your holding the power button, plug it back in
hope it worked!!!
Jul 30, 2009 | Pioneer Audio Players & Recorders
Standby light on pioneer vsx-d308 receiver
I have the same problem. my sandby light is on but my receiver will not turn on! I checked my power going into the power supply board that was good. But i do not have power going to the transformer or the receptacle. And both of my fuses r good. check ur fuses and go from there . If u know how to get a power supply. please let me know.
Jun 14, 2008 | Pioneer VSX-D308 Receiver
No DTS sound / RESET
Hi I have a Pioneer VSX D908S which is basically the same amplifier as yours with the difference that the one I have has no THX certification, as a matter of fact the service manual is the same, and mine has the same problem. The prblem is located in the DSP board, if you are able to remove the bonett, you will see on the right side a metal cover, remove it, once you have removed it, look for a IC9374 it is located, -looking this board in front to you- almost at the left upper corner, this IC has the PDK042A on it, with a soldering iron resolder this circuit. This is common problem with this pioneer amplifiers, and this procedure not always works, the final solution is to buy the DSP board but it is expensive. Good luck! Miguel
Oct 05, 2007 | Pioneer VSX-27TX Receiver
Pioneer VSX-27TX Receiver Logo
247 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
