Question about Dolphin Maytronics Advantage
Our Dolphin Pro stops after only 10-15 seconds of running. We have tried disconnecting from the power and re-starting several times. it keeps doing the same thing.
    President:
  • Dolphin Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
For starters, try the tip I posted here on Fixya, found at: http://www.fixya.com/support/r3651526-dolphin_pool_cleaner_wont_start_up. If that is not enough, try our sites FAQ section on Dolphins at www.arrowpools.net. Select the FAQ button then from the drop-down select Dolphin.
If none of this helps your problem could be in the power supply, cable or motor unit. The motor unit is the most likely problem.
It is not recommended you open the cord end that connects to the motor unit as you are breaking the seal for the submersible electronics. For information about sending your unit in for repair use the dolphin form link on the bottom of our site
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Sep 05, 2010
Tip
Your Dolphin pool cleaner wont start up...
A common problem, especially with 'newer' Maytronics Dolphin brand pool cleaners is that you put the unit in the pool, or even try to turn it on after a cleaning cycle while it is still in the pool, and to that point it has worked fine. You turn the power supply on and nothing happens. You turn it off and back on and still nothing. You leave it, even over night, same thing. What do you do?
While I cannot tell you why it does this (we have a theory but can not confirm it) what usually works is to follow these steps...
1) Unplug everything. Unplug the power supply from the outlet and the Dolphin from the power supply.
2) Let the whole thing sit a couple of minutes (we want to allow any capacitors to discharge).
3) Be sure the Dolphin is out of the water and sitting upside-down on a level surface (Tracks pointing skyward).
4) Reconnect the Dolphin to the power supply and the power supply to the outlet.
5) With the Dolphin still out of the water, perform a self-test. Simply turn on the Dolphin. Within about 15 seconds it should begin to move. The tracks will spin in both directions with and without the impeller motor running at the same time. It is not unusual for the tracks to rotate at different speeds during this test. The test will last for 30 - 45 seconds or so. If it goes on indefinitely, turn it off and contact us for further direction.
6) Assuming the unit has now worked to this point, you should be able to put it back in the water and it will return to normal operation from this point on.
If it still won't run; it runs a few moments and quits the self-test; or runs continuously, contact us thru the Dolphin service form along the bottom of our home page at www.arrowpools.net.
on Dec 16, 2009 | Dolphin Maytronics Diagnostic Robot...
Hp officejet pro 8500 error messages
This seems to be Hardware issue. However we can give it a try.
Disconnect the power cord from back of the printer ( Do not turn off power ). Hold the Power and Cancel button and connect the cord and release the buttons after 2-3 seconds
Regards,
Sean
Apr 22, 2013 | HP Office Equipment & Supplies
I have a Dolphin Dx3 about 4 months old. It has been working great, but now when I press the button on the power pack to turn it On , the blue lights come on which means it is On , but the impellor only...
For units still covered under warranty you should first contact Maytronics for directions. They can sometimes troubleshoot the problem over the phone but if the issue is beyond simple phone support they can start the process of getting the unit repaired thru a warranty center which we are.
To contact Maytronics call 1-888-DOLPHIN or try their website at: www.maytronicsus.com. If directed to us in Michigan our site is found here: www.arrowpools.net.
John
Mar 30, 2011 | Dolphin Pool & Spa
Dolphin starts runs for a minute or so,no more then stops completely.Power is getting through all airways etc clear no blockages I can see. Solution? Problem occurs all the time,all parts are cleaned...
It is not recommended you open the cord end that connects to the motor unit as you are breaking the seal for the submersible electronics. For information about sending your unit in for repair use the dolphin form link on the bottom of our site.
John
Jan 16, 2011 | Dolphin Maytronics Diagnostic Robot...
Dolphin vacuum. Turn switch on and it turns about 2 times,stops for a few seconds, and then turns about 2 times. This goes on for 3 to 4 times then stops and does not turn again. What are some...
Your problem could be in the power supply, cable or motor unit. The motor unit is the most likely problem. For starters, try the tip I posted here on Fixya, found at: http://www.fixya.com/support/r3651526-dolphin_pool_cleaner_wont_start_up
John
Aug 06, 2010 | Dolphin Maytronics Advantage
My Dolphin will run for a couple of minutes then quit. The power supply light stays on but robot stops. When I try to turn the tracks one direction is free the other direction catches. I think one track...
We sell them. You should replace both at the same time top keep the tension equal on both sides. For pricing, please use the contact button found on our site at www.arrowpools.net or call us at 734-285-5700 7a - 6p EDT.
Jun 10, 2010 | Dolphin Maytronics Diagnostic Robot...
Kenmore microwave (2 y/o) will stop soon after you hit start.
A quick test. Switch off power then remove outer cover. Look for the transformer. remove the two wires connected to the primary side. Note, do not toutch anything else. power still sitting on the cap. With those two thin wires disconnected, make sure they are not toutching each other or leaning on the metal frame. Set a program that has been a problem and let it run. If it still stops and does what its not supposed to do, your board needs replacement.
Sep 16, 2009 | Kenmore 80412 Microwave Oven
The unit (6 years old) stops after a 30 sec. After rearming I can start again, and again, and again. Because the unit is no longer under guaranty, I disconnected the motor unit. By testing it (beside the...
Running it next to the pool is not very telling as it will shut itself off in that time anyway. Do you have access to another power supply to try with it? It is possible, though unlikely, it is the problem. It is more likely the motor pack and a new one is costly. If you would like parts or a quote on a motor replacement, use the dolphin contact portion of our website at www.arrowpools.net.
Sep 01, 2009 | Dolphin Maytronics Diagnostic Robot...
DOLPHIN DIAGNOSTIC AUTOMATIC POOL CLEANER STARTS AND STOPS
There may be moisture building up inside the motor housing. Try to Open it. http://www.i-love-my-aquabot-automatic-pool-cleaner.com/Maytronics-Dolphin-Repair.html
Then make sure no moisture accumulated in the circuits. Mine got the same problem.. after running trouble free for several years it suddenly stop running after the first few minutes..when i opened it a lot of moisture in the circuit. I tot it was toasted. so i took my hair blower and sealed it back and replace the moisture absober (it was soaked).. after first run it would run only the SELF TEST mode.. i tried several method to make it run all the way to the main program.. the solution.. start it and make sure it will not tilt in the first 10 minutes before you let i run sideways to the walls, this makes the program run back to normal.
Jun 28, 2009 | Smart Pool Inc Dolphin Diagnostic...
Dolphin Maytronics  Advantage Logo
181 people viewed this question
Top Dolphin Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Are you a Dolphin Pool and Spa Expert? Answer questions, earn points and help others
