Question about Sharp EL-1801P Calculator
Where can I get a new ink roller for EL-1801PIII
  • 14 Answers
Here it is
part#
IR40T
http://www.gorillapaper.com/ink-roller-ir40t-b-r.html
Posted on Nov 05, 2010
How to ink new roller for shart EL1197Hii
EL-1197 Calculator Manual - you
pdfstream.manualsonline.com/.../90aef457-2ed5-4a03...
Translate this page de la calculatrice SHARP, veuillez prendre les ... Insert the new ribbon. 6. ..... AC adapters, ribbons, correction tapes, ink rollers, cables, printwheel, or paper.
Jan 24, 2016 | Office Equipment & Supplies
Replace ink cartridge
INK ROLLER REPLACEMENT
If printing is blurry even when the ink roller is in the proper
position, replace the roller.
Ink roller: Type EA-732R
WARNING
APPLYING INK TO WORN INK ROLLER OR USE OF
UNAPPROVED INK ROLLER MAY CAUSE SERIOUS
DAMAGE TO PRINTER.
1) Turn the power off.
2) Remove the printer cover. (Fig. 1)
3) Remove the ink roller by turning it counterclockwise and
pulling it upward. (Fig. 2)
4) Install the new ink roller and press it in the correct position.
Make sure that the ink roller is securely in place. (Fig. 3)
5) Put back the printer cover.
Jun 08, 2012 | Sharp EL-1611P Calculator
I have a Sharp EL-1801P that is low on ink. Can I add ink to the roller or do I need to buy a new roller?
Ink roller: Type EA-772R
WARNING: APPLYING INK TO WORN INK ROLLER OR USE OF
UNAPPROVED INK ROLLER MAY CAUSE SERIOUS DAMAGE TO PRINTER.
1) Set the power switch to OFF.
3) Hold the top of the ink roller and remove the roller by pulling
it toward you and then upward. (Fig. 2)
4) Install the new ink roller in the correct position. Make sure
that the roller is securely in place. (Fig. 3)
Feb 08, 2011 | Sharp EL-1801P Calculator
I need to install new roller ink for the Sharp EL 1192G, doesn't seem like the red is working correctly.
M=500 and S=100 in a normal distribution, what percentage of the subjects have scores between 400 and 600
Mar 01, 2010 | Sharp EL-1192BL Calculator
How to set date and time on sharp el-1801pIII
User guide is here ...
http://safemanuals.com/user-guide-instructions-owner-manual/SHARP/EL-1801PIII-_E
Instructions are halfway down column 1.
Basically, you use the reset button on the back, then enter the relevant fields, delimiting as with a period <.>
I think their illustration explains it better than I can in words!
Feb 28, 2010 | Sharp EL-1801P Calculator
How do I print a date format with sharp el 1801PIII?
To print the current date press once the Clock/Calendar key and then press once the Non Add/ Subtotal key (# key)
To print out any other date (or codes and other numbers that are not part of a calculation) just type it and then press the Non Add/ Subtotal key (# key). The date/number will be printed preceded by the # sign.
You may also want to download the SHARP EPL-1801PIII Operation Manual
Jun 04, 2009 | Sharp EL-1801P Calculator
How do I set the date on Sharp EL-1801Piii
Adjusting the tiome is just like adjusting the date, owith the only difference that you just enter two values (hours and minutes):
1. Move the Grand Total/ Rate Setting mode selector to the "Rate Set" "position
2. Enter the time in the orde of hour, minutes (use a point to separate the two values) and then presse the [Clock/Calendar] button to complete the entry.
You may also want to download the SHARP EL-1801PIII OPERATION MANUAL
May 15, 2009 | Sharp EL-1801P Calculator
How to change ink roller on Sharp Calculator EL-1611H
pulling it upward.
Apr 19, 2009 | Office Equipment & Supplies
Sharp EL-1801P Calculator Logo
131 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
