Question about Microwave Ovens
Microwave stopped heating after being cleaned (could be co-incidence). Besides not heating appeared to run properly. Let sit for a day hoping something was wet and would dry, tried heating glass of water and heard a pop microwave and microwave completely off. Opened up unit and found 20A fuse blown. I am hoping by describing the events leading to fuse being blown that part that needs to be replaced is more readily identifiable (fuse & HV cap or HV rectifier or transformer or magnetron) Thanks MikeG
  • mikeg8 May 22, 2008
    replaced fuse and diode (diode was open)
    Microwave runs again but still not heat.
    Capacitor did not spark when discharged. However, it appearred ok when tested with ohm meter.
    none of transformer windings were shorted to ground.
    When trying to heat something, noticed that audible noise of microwave was different than when working. I'd say frequency of noise generated by microwave when attempting to heat something is lower.
  • mikeg8 Jun 05, 2008
    I ran microwave for 5 minutes plus and fuse did not blow again. Since fuse did not blow I ruled out transformer.
    I then replaced the magnatron and microwave still does not heat.
    Microwave still groans/hums loader when trying to cook.
    Next suggestion?? Replace both capacitor and high V transfromer??
    Thanks MikeG
  • Microwave Ovens Master
  • 9,098 Answers
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
But you might replace the fuse and do another quick heating test to see if it blows again. If so, you'll need to do some checks.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/xformer.html
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 12, 2008
  • William Miller
    William Miller May 22, 2008
    The diode was probably not open because normally when the diodes fail, they short.
    The oven will groan or hum loader when you try to cook, but a shorted high voltage diode alone will not blow the fuse.
    If the diode is tested with a common meter it will look open, since a much higher voltage is needed to forward bias (turn on) a high voltage diode. It will look open.
    I would put a cup of water in it and set it for about 5 minutes.
    Stay with it, then after it stops, see if you smell any electrical odors coming from the transformer or excessive heat from the magnetron.
    Also look for a cracked magnet on the magnetron. Excess heat can cause that, and it won't heat.
    It's best to do this test with the control panel pulled away or the outer cover off so you can check it faster after the cook cycle..
    I'd say one of either the mag or transformer is bad.
    If the fuse blows again, I'd suspect the transformer. Sometimes bared internal windings will not actually short until it is heated up. Expansion & contraction may cause them to touch and short it out, blowing the fuse.
    In some cases a bad mag will cause excessive current flow and a blown fuse, but further testing is needed.
    Let me know how it goes.
WHIRLPOOL ACCUWAVE MICROWAVE CONTINUES TO RUN BUT NO HEAT. WON'T STOP
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean, solder and reset the board. Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron. Check this link to know how a microwave works:
http://www.espares.co.uk/advice/microwave/a/5/1443/how-a-microwave-oven-works.html
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced. See link:
http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Now keeping clear of the microwave, switch on; use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Jan 25, 2013 | Whirlpool Accuwave Microwave Oven
Kenmore microwave oven doesn't heat food. I had
Jan 24, 2013 | Microwave Ovens
How come my microwave stopped working?
Seems this is only a coincidence and there is no possibility that items on top of the microwave could have caused this malfunctioning.
Jan 21, 2013 | Hamilton Beach Microwave Ovens
My Jenn-air Built-in Microwave will turn on and appears to work fine, but will not heat food. need a little help. Thanks
Jan 11, 2013 | Microwave Ovens
Carousel stopped turning
see this causes and fix it. God bless you
ough the carousel is usually driven by a small motor that's unrelated to the heating function of the microwave, the microwave cabinet needs to be opened to repair it. So we recommend that you seek the assistance of a qualified appliance repair technician. Inspect the plastic drive coupling that the tray sits on, as well as the ring-and-roller assembly, to make sure that they're working properly
Sep 24, 2012 | Tappan Microwave Ovens
Whirlpool Microwave, No Power
could be a damaged door saftey
Jun 14, 2009 | Whirlpool Microwave Ovens
Microwave doesn't heat anything
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Apr 19, 2009 | Frigidaire GLMV169D Microwave Oven
Panasonic Microwave NN-C980-B buzzing noise but it still works.
All:
I have a 2003 Sears Ultra Wave microwave 721.63682300 with a similar problem. A few months ago it started giving off short buzzes when turned on. That stopped but then I noticed that everything took twice as long to heat up. After quite a bit of teardown&inspection I found a circuit break in the inverter board leading to ZD704 diode (pictured). I will now try to find a replacement diode to see if replacing will fix it. Thanks for your postings.
Feb 15, 2009 | Panasonic NN-C980 Convection/Microwave...
Microwave runs and has functional control panel, but no heat.
The controler board, or the power supply for the magnetron has probably failed, or a safety switch is not working properly. It is also possible that the controler board is in a protect mode because of a defect.
The magnetron uses very high voltage at very high current. There is a very large capacitor in the power supply for filtering the DC for the magnetron. This area of the microwave oven is very dangerous to work on. The power supply can be lethal if proper procedure is not complied to when working on it.
I strongly suggest that you do NOT attempt to service this yourself, unless you have the proper training, test instruments, tools, and service manuals to work on it.
After servicing, the tech is supposed to verify the operating power level, and do an EM (ElectroMagnetic) radiation leakage test. This is important after servicing this type of appliance.
Take the microwave oven in for an estimate. From this you can make an intelligent decision if you are going to have it serviced or replace it.
Excellent article about microwave ovens:
http://www.betterhealth.vic.gov.au/bhcv2/bhcarticles.nsf/pages/Microwave_ovens_safety_issues?Open
Microwave Oven FAQ from GE:
http://www.geappliances.ca/faq/faq5.jsp
Jerry G.
Apr 14, 2008 | GE Spacemaker Over-the-Range Microwave
Microwave runs fine - heats nothing
The most common causes for a lack of heating are a bad door switch, a loose connection on the magnetron, a bad magnetron, bad connection on the control circuit board, a bad relay on the board, bad high voltage diode, or bad high voltage transformer. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk We are the ones who repair the displays and control boards, by the way.
Sep 10, 2007 | Sharp R-530ES Microwave Oven
Microwave Ovens Logo
417 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
