Question about RCA HD52W66 Projection Television
My tv dos not turn on is there a fuse to it - RCA HD52W66 Projection Television
My tv is not getting any power no lights turn on
try your tv in another part of the house and if it dos not work then the internal fuse may be gone
Feb 18, 2014 | Element Electronics Televison & Video
TV screen stays bleu and dos change to normal raster
Check for any loose soder terminals at the video output card. This card can be located on the neck of the picture tube, directly pluged into it.
Apr 11, 2012 | Televison & Video
Fuess
To locate and check the fuse unplug the set and remove the back cover---please follow the power cord into the set and you will find the line fuse connected to it.
Mar 19, 2012 | Accurian Televison & Video
Cmo se programa un contol remoto dedish para q haga una sola funcion
tengo 2 tv con 2 diferentes controles pero uno no funciona y mis dos tv tienen la misma programacion por decir el control #1 controla las dos y el control # 2 no tiene ningun mando hayer el 1 y2 trabajaban correctamente y podia ver dos diferentes programaciones
Feb 18, 2011 | DISH Network IR Remote Control
How do you turn dos off
You can't. Even if your using a Linux based operating system it has a form of Dos installed. Without does you don't have anything to tell the computer what to do.
Oct 29, 2010 | Computers & Internet
Prende dos dias y dos dias no prende asta que se enfria ojala y me pueda ayudar la tv es una sony trinitron de 32 pulgadas mod kv-32hs500
trata de resoldarle todas las resistencias y piezas que veas con soldadura fria.si hay piezas con soldadura fria ellas se mueven y no hacen contacto, los sony's padecen mucho de eso.espero esto te ayude.
Apr 23, 2010 | Sony FD Trinitron WEGA KV-32HS500 32" TV
No puedo programar mi control ONE FOR ALL URC 7642 B00
At first you need to press the button of the TV (VCR, CBL or DVD)
After that you need to push the MAGIC button until the light(LED) flash 2 times.
Then press 991
The next step is to press the button of the TV (VCR, CBL or DVD) again and then the POWER button (Repeat this step until the TV (VCR,CBL or DVD) turns off.
And then you need to press again the MAGIC button and that's all.
Sorry for my bad english.
1.- Apunte el ONE FOR ALL a su aparato y pulse la tecla del aparato que quiere programar (TV VCR CBL DVD)
2.- Pulse y mantenga presionada la tecla MAGIC hasta que la tecla del aparato destelle dos veces. (la tecla del aparato que está programando se encenderá una vez y seguidamente dos veces). Suelte.
3.- Pulse 991.
4.- Alterne entre la tecla del aparato (por ejemplo TV) y la tecla POWER hasta que su aparato se apague.
5.- Cuando su aparato se haya apagado, pulse MAGIC. La tecla del aparato destellará dos veces. Ya esta programado.
Oct 17, 2009 | Emerson EWD2203 DVD Player/VCR
27 inch symphonic
get in the tv menu and try to turn off your close captions,
Jul 03, 2008 | Symphonic ST427FF TV
Lcd tv
dos the porew light stay red or turn blue or not at all?
May 31, 2008 | Polaroid FLM-323B Television
RCA HD52W66 Projection Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
