Question about Kenmore 14249 Dishwasher
No current to waterlevel switch. switch is good.
  • 4,340 Answers
This would be a normal case, the switch is powered only during the fill stage, it is an interrupter.
Posted on Sep 05, 2010
Washer fills, agitates, will not drain or spin
check your lid switch ,or debriss in drain pump ,pump can not run will not spin untill machine waterlevel switch comes below a certain level of water pressure
Jan 22, 2013 | Hotpoint 3.2 Cu. Ft. Super Capacity Washer
Diagram of pressure switch
I hope this answers the info you need.
http://www.acmehowto.com/howto/appliance/washer/check/waterlevel.php
May 29, 2012 | Kenmore Elite Washing Machines
Water keeps running after it fills up, won't shut off
On the outside of washing machine tubs there is a rubber hose that goes from the tub to the level sensing unit in the control hood. I have seen these fall off. If it hasnt make sure that it is clear of debris and water. If all is ok here is a link that tells you how to check your level switch, http://www.acmehowto.com/howto/appliance/washer/check/waterlevel.php
Good Luck
Sep 26, 2011 | Kenmore Washing Machines
Dishwater will not fill...no water. Used to work okay Electric valve clogged? Are they cleanable?
Not cleanable.Must replace.But check them first. They don/'t fail very often. Also check the obvious.Someone might have shut water off. Check for voltage at the fill solonoid .If voltage available then replace. If no voltage , Check ,door switch and,waterlevel switch. If ok, look at timer or controller.
Was this helpful?
Aug 16, 2011 | Amana 24 in. ADB1200AW Built-In Dishwasher
My washer continues to dump water and over flows. Also wash cycle not working at all. Rinse and spin ok
You have a problem with your water level switch http://www.acmehowto.com/howto/appliance/washer/check/waterlevel.php
When your switch is not working, the washing cycle will not trigger to operate.
Check your water level switch for your model, look for model number under the hood of washing machine, at the sides of washing machine, or in the back..
Mar 10, 2011 | GE Washing Machines
After being switched on it doesn't get started.
You will need to check the voltage that is available in the inlet valve, the waterlevel sensors , the motor and the drain pump/valve to establish if the program controller is working.
If not the controller is faulty.
Sep 28, 2010 | LG WM-2277HW Front Load Washer
Washer is leaking from the bottom?
You hit the jackpot with this question. Could be almost anything and everything. Remember, water is everywhere in a washer. Could be the pump, or discharge hose, or interconnect hose , or outlet from the tub, or overflow(on some models), or waterlevel sensor tube, or fill valve, or washer hot/cold inlet connections, or aerator fill nozzle, or water level switch allowing water too hi, or, or, or, or....., well you get the idea. Good luck, Macgivor
Oct 11, 2009 | GE Washing Machines
Waterintake stops after approx. 35 sec.waterlevel is to low,detergent compartement will not open because of low waterlevel and also water will not heat, because heating element is not covered with water....
The machine fills by time only as you have already determined. The intake screen on the water valve is probably plugged up and cleaning it should solve your problem. You will have to turn off the supply to the dishwasher and disconnect the water feed line. Eric
Sep 15, 2009 | Dishwashers
Whirlpool Duet fills when off
It's Quite easy.
To test Inlet valve, follow the below guide :-
http://www.acmehowto.com/howto/appliance/washer/check/inletvalve.php
To test the Water level switch/Pressure switch, follow the below guide :-
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dishwasher
  1. could be a latch adjustment-- push gently on the doo when you hear the chatter. could also be something lodged in or near the level switch-located around the waterlevel--check manual
Aug 28, 2008 | KitchenAid Dishwashers
Kenmore 14249 Dishwasher Logo
35 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
