Question about Denon DVM-4800 Multi-disc DVD Player
My Denon DVM-4800 Multi-disc DVD Player is not working. Will not eject, play or do anything at all. It is displaying 11 1. Any suggestions?
techman
  • 3130 Answers
SOURCE: Need help! DVD tray won't open
soundsa as though there is a draw drive problem and that could be a motor or as simple as a belt?? are you sure tjhat the eject button works properly as I found out on these denons that the eject switch or push button wont make contact with the switch behind it because the Printed cuircut board shifted??
Posted on Apr 03, 2006
Benimur
  • 6966 Answers
SOURCE: Denon 2910 CD player malfunctions
There has been a number of reports of similar issues with Denon models that utilizes the 'PureProgressive technology'. Some of the issues and tried corrective measures are -
1. It would appear that in certain occasion, performing a "region free hack" disables the 'PureProgressive technology' and one solution tried is to set the unit to NTSC and not multi or PAL;
2. disable/turn-off digital output;
3. some has reported significant improvement when a firmware upgrade was performed;
4. use DVI instead of of other outputs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 13, 2008
  • 70 Answers
SOURCE: Denon dvd player freezes in
sounds like its stoping during layer switch, if the player is old its needs to be cleaned. its best to clean it once every 20hrs or so. if you do not have a disk cleaner you should go buy one first. if the player is new return it and get the best dvd player you can buy for any amount the toshiba xde. this player is phenomenal, the best you will be amazed. no i dont work for toshiba but ever since they started making hd dvd players(i know they stopped)there players have become the best. trust me if you dont think so just return it. no harm done. if you want a blu-ray get ps3 I dont like them either but i have to admit after buying (for movies only)my third blu-ray player it is by far the best one. almost as good as the toshiba on standard dvd playback but not quite. good luck.
Posted on Oct 02, 2008
  • 4 Answers
you could try this http://www.fixya.com/support/t244156-denon_2910_cd_player_malfunctions or clean the lens
Posted on Jun 14, 2009
SOURCE: DVD player won't read disc anymore
i had the same problem.
is the player done? or is there a fix?
Posted on Jun 27, 2010
My Denon DVM-1800 says no disc what do I do?
I have had the same thing happen with my blu-ray. I have tried cleaning the disc; the lens, occasionally with success. flashing the bios. also known as update of the system [can be done online {if equipped} of mine also has a usb port {download the correct file to a USB drive and re-power DVD with the drive in place}]. if these things don't work try manufacturer tech support. I had mine replaced because it wpould NOT flash. good luck.
Apr 07, 2012 | Denon DVM-1800 DVD Player
My denon dvd player plays for about 30 seconds then starts over <can anyone help
purchase a dvd lazer cleaning disc from your local electronics supply compant and run it through the player several times this will fix the problem so long as the lazer is not fully burned out
best of luck
Nov 30, 2010 | Denon DVM-1805 DVD Player
Screen message that the disc may not be compatible for playing and same when I put cleaning disc in. Both work in another player
Sound like the laser needs replacing. You can find a disassembly guide in google if you're game. It's fairly easy, but important to be gentle with internal cables. The laser replacement should be on ebay or such. Make sure it's the right model number. any questions, email.
Nov 24, 2010 | Denon DVM-1815 Multi-disc DVD Player
1815 denon won't load dvds but will load cds
Hi...
Buy a DVD cleaner disk ( radio shack or walmart or best buy)
Run it a couple times
Aug 26, 2010 | Denon DVM-1815 Multi-disc DVD Player
Denon dvm 715 says load
probaly laser pickup assembly i am troubleshooting a DVM 715 now and i see no output from laser when it is loading be careful not to look directly into laser use a white sheet of paper to reflect beam on
Jun 01, 2010 | Denon DVM-715 Multi-disc DVD Player
Denon AVR 4802 Receiver w/ Denon DVM 4800 DVD player - video fail
no the problem is at the plasma you will have to change the setting back to the scale range that will accept the signals from the Denon, see Plasma's manual for instructions
Jan 27, 2009 | Denon AVR-4802 Receiver
Replacement pickup lens assembly
try to replace the data bus(ribbon) running from the pickup lens to the motherboard, that may the problem before replacing the lens ,NOTE that lens faulty is not easy.
name ;emanuel mollel
mobile;255757566502
TANZANIA, IT student
May 07, 2008 | Denon DVM-2815 Multi-disc DVD Player
Apr 02, 2006 | Denon DVM-1800 DVD Player
Denon DVM-4800 Multi-disc DVD Player Logo
Top Denon Televison & Video Experts
Jonathon summesfield
 Grubhead
Grubhead
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
