Question about HP OfficeJet D135 All-In-One InkJet Printer
Print heads The error message says there is no Print Head in Magenta slot. Will damage the machine; replace the Magenta print head now. I know this is not true because I can see the Magenta Print Head. Is there any thing I can do except replace it? Bill Leggins 865-376-5721 surveyorbest@bellsouth.net
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 93 Answers
Follow the steps given in the below webpage. This may resolve the issue.
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=bpa02107&cc=us&lc=en&dlc=en
Posted on May 26, 2008
Doesn't print magenta?
It appears the magenta print head nozzles are blocked.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Apr 06, 2013 | Kodak ESP Office 6150 All-in-One Printer
Okidata B4600 error message #132 on two printers. What does this error mean. The printers will not go to off line.
Error 132:
LED Head Missing, Color:Magenta
When magenta LED head connection cannot be detected
Solution:
You should first try to restart the printer.
If that doesn't resolve the problem, the ribbon cable is probably disconnected from the print head.
The led print heads are four assemblies that hang down from the lid of the machine when you open it. Make sure they are properly connected.
Sep 14, 2011 | OKI B4600 Printer
My printer is not printing magenta. I have changed the cartridge (hp one), cleaned the print heads and
The magenta print head may be blocked. Try several deep cleaning of the print head to see if it can clear the blocked magenta print nozzles. Also check the magenta cartridge, make sure it is not empty.
If none of this works then the print head needs to be replaced.
NOTE the print head is not a cheap item, you may consider putting the money towards a new and better printer.
Nov 13, 2010 | Computers & Internet
Why Am I getting the error 41 message?How can I fix it. Can I fix it myself?
Hi there
Error 41 means there is a major problem with the printhead, usually
requires a print head replacement.
My advice is to take it to a
Brother service centre while if it is under warranty.
If it's out of warranty they are usually a throw away job, the heads cost as much as the printer.
Sorry I know what it feels like, just have a go and see what you can do, clean the heads and so on.
All the Best and good luck: Pineworks
Nov 11, 2009 | Brother MFC-3220C Plain Paper Inkjet Fax
Wrong ink in slot
my brother mfc 6490 has stopped printing yellow, i've done number cleans and changed cartridges with no luck. has anyone out there got a fix for this?
Sep 13, 2009 | Brother MFC 6490CW InkJet Printer
HP L7680 Print Head Problem
Sometimes the circuit strip that sits at the back of the printhead carriage is the problem due to moisture, ink soiling, etc...
To clean these you need some cotton buds (like you use to clean your ears) and gently clean the area at the back of the printhead carriage (where the printheads slot into).
This removes any ink, or moisture that could be causing a short circuit or similar.
Nov 07, 2008 | HP Officejet Pro L7680 All-In-One Printer
Does anyone know how to remove print head?
The print head nozzles is clogged but good. None of the cleaning the machine can do will clear it. Been there and trid that. Doesn't work. The clogs need to be dissolved with a specialty clog buster and probably will need to soak at least 24 hours, maybe more. Don't deep clean any more as you will put so much in in the absorbent blotters on the inside of the printer that you will trigger an error code and not be able to print until the absorbant pads are replaced by a service tech for about $100.
Aug 05, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Magenta won't print have done deep clean and head alignment cartridge new and functioning tested cartridge in blue slot and ink worked
It sounds like your print head my be blocked. On some printers they come with the cartridge, my canon has separate print head that can be replaced.
Apr 14, 2008 | Office Equipment & Supplies
Brother MFC 3220c machine error 41
I had the same problem with a Brother MFC3420C after replacing the print head with a new one the same error 41 occured 4 weeks later.
I finally fixed the problem (see photo's) and sent the parts back to Brother :-)
Don't buy Brother Inkjet technology its all ****!.
Their laser technology seems to be much more robust and reliable, have had a Brother HL-1440 since 2004 and its still running well.
http://www.flickr.com/photos/48446421@N05/sets/72157623635891898/
Jan 12, 2008 | Brother MFC-3220C Plain Paper Inkjet Fax
HP OfficeJet D135 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
