Question about Mercury P4VM800M7 Motherboard
Power ok but processor is not heat - Mercury P4VM800M7 Motherboard
  • Mercury Master
  • 27,725 Answers
Clean your computer of dust using a fine air blower from a compressor specifically around your central processing unit making sure there is no moisture in the air line
as dust will cause a lot of static which will make a computer overheat and cause lots of problems
hope this helps
Posted on Sep 05, 2010
INTEL 865 MOTHERBOARD IS NOT DISPLAYING I HAD CHECKED ALL THE HARDWARE IT'S PROCESSOR IS NOT HEATING HOW CAN I SOLVE THIS PROBLEM.
this is ur hardware problem in this pic i am showing u an ic (adp 3188).if u can change that ic ur processor power supply will ok.sure
Mar 31, 2015 | Intel Computers & Internet
Blinking power button
try servicing the computer probably there is alot of moisture and dust inside, the cooling fan is failling and in the event the processor gets over heated. If it doesn't work try changing the processor fan, it should be ok
Sep 07, 2014 | Acer Computers & Internet
Hi, my mb intel 31pr prob power ok processor heat ok ram ok but no displye and no any beep?
Hi' try to pull out socket connection on HDD and press button to reboot , and it is usually boot when switched on ;but if not HDD gas a problem ,may it has to be reformat or some connections are need to insert properly ,
Aug 03, 2012 | Computers & Internet
Pc running but wont recognize screen I have tried other screens but same result ,replaced video card still nothing on screen what else should I do
remove your memory card and wipe it clean with a clean cloth and insert the memory in the slot dont forget to remove all the addon card ide or sata cable power to hard his and cd drive restart the computer see if the display is ok if not remove the processor fan and the processor clean it with clean cloth and fix the processor to the socket also clean the heat sink and apply a thin layer of heat sink solvent and fix the heat sink tightly to the socket if the display doesnt come change your processor which suits the socket
Dec 15, 2010 | ASUS P5GC-MX/1333 Motherboard
No display but power on ram ok cmos battery ok cpu fan and cpu ok
first check ur display cable for breakr if you have built in display disable it in bios and and if you have addon display card remove them insrert a new addon diplay card if you have display the display section in you motherboard is faulty or diplay add on card is faulty if it still dont work the clock and reset section in your motherboard is fulty to find the at the above section if you have a multimeter check the pci slot A15 means the pci pins facing the processor must have 5v if this is ok your motherboard is ok and the problem is with your display card
Oct 07, 2010 | Intel D845GVSR Motherboard
Optiplex GX280 - loud fan at start up and amber power light - does not boot and no light at the back
Apply pressure on the heat sink fan right before you press the power button and continue applying pressure. Watch your screen if you see it boot this means its a problem with your processor clamp that applies pressure to the processor. Try to remove the top part of the clamp. Shouldn't be too hard with some needle nose pliers. Then just replace the heat sink and fan with out that clamp.
May 27, 2010 | Dell OptiPlex GX280 PC Desktop
By voltage imbalance in processor it get very high heating so its going very temperature my sysetem hang out after running in 5min
if problem is high voltage so power supply change but you see both fans is ok, smps fan and processor fan.
no dust under processor heatsings.
Apr 23, 2010 | ASUS K8V-MX Motherboard
Lga motherboard no display, processor doesn't heat
if your processor does not heat up it's probably dead.. try running it without the fan and see if the heat sink still doesn't heat up
Sep 07, 2009 | ASUS P5V800-MX Motherboard
Boot problem
Sounds like your CPU fan may be failing (bearings seizing), and that is either causing the CPU to overheat and shut down, or the fan may be drawing excessive power and causing power droops.
Sep 03, 2008 | Computers & Internet
Power supply
angeldram3
as i think ur processor over heated. or processor can dos not work fine or heat sink not installed properly. remove heat sink, and use heat sink component (a whithe colour gel. u can buy it any computer accessories shop) use it top of ur processor then attached heat sink. and connect processor fan. before installing heat sink check processor fan. then cleare CMOS by removeing battery (because this problem also can happen wrong frequency setting in CMOS setting).
Jun 29, 2008 | Gateway Bestec ATX-300-12EB3 305w Power...
Mercury P4VM800M7 Motherboard Logo
Top Mercury Computers & Internet Experts
Mark Gough
Alun Cox
vsri9
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
