Question about Dirt Devil Vacuums
Dirt devil Spinnergy will run for about 10min and then shut off after about 10min it will start again
    Guru:
  • 642 Answers
Your vacuum's heat protection is activating. The cleaner will work untill heat build-up causes the thermal protection to cut power to the motor. Once cooled down the thermal protection will once again allow the motor to work. Open the vacuum and clean all filters. Also check for lint and hair around the motor shaft and brush shaft. Download your manual here for detailed description on filter cleaning :
http://www.dirtdevil.com/manuals/?id=2fd0fbf8-50d0-4b49-a9fd-e784c6096acf
Posted on Sep 05, 2010
Dirt devil easylite 7.2 v does not hold charge. Can you suggest any fix? Thanks
Sorry to say that the batteries seem to be worn out. Usually this is caused by using it for to short a time each time you use it. Batteries develop a 'memory' after several short time uses, and can only be charged the time it 'Thinks' is a full charge. You can try running it until it almost stops. Then let it sit for about an hour turned off, then turn it on again, and run it till it almost stops. After doing that put it on the charger for 8 hours. Then run it until it almost stops again. then charge it again. That process sometimes breaks the memory problem. If not, you need new batteries- or a new dirt devil.
Jul 02, 2017 | Dirt Devil Vacuums
My dirt devil breeze turbo shut off while I was vacuuming. I've checked 3 outlets and nothing happened
It may have overheated from a restriction or clog. If so it will come back on after it cools down.
Mar 01, 2015 | Dirt Devil Breeze Turbo Upright Vacuum
Do my Dirt Devil have a restart button it just stop running
Hi! No the vacuum doesn't have a restart button, but it does have a thermal protector that will shut the vacuum down when it is overheated. If your dirt cup was too full this will activate the thermal protector sensor. Clogs and dirty filters can cause this as well. We recommend emptying the dirt cup, tapping out the filter and checking the hose for clogs. The vacuum will come back on usually within 45 minutes to an hour. Hope this helps. If you need further assistance don't hesitate to reach out to us here on Fixya, Facebook.com/dirtdevil or Twitter @DirtDevil
Sep 20, 2014 | Dirt Devil Featherlite Bagless Vacuum...
Why does the dirt devil breeze turbo shuts off
Hi there! The vacuum is equipped with a thermal protector sensor that will automatically shut the motor down if it reaches a certain temperature. This is usually caused by either a clog or a filter that needs to be cleaned or replaced. Make sure you check both the hoses for clogs and clean all filters properly. If a filter is really dirty it may be time to replace it. Hope this was helpful!
Apr 24, 2014 | Dirt Devil Vacuums
My dirt devil keeps shutting off randomly
It's overheating. Empty the cup and replace the filters. There's a breaker that opens up and turns it off when it gets too hot. When it cools down it closes back up and it will run again. It'll argue with you til the end of time or until you fix the problem.
Good Luck
Jan 13, 2013 | Dirt Devil M085805 Upright Vacuum
I have a dirt devil upright vision and when I am sweeping it will shut off like it had overheated or something. I will unplug it and let it sit for a few minutes and it will start back up and then after a...
Hi Cassidy. You are probably right about the motor overheating. The usual cause for overheating is a clog some where on the bottom of the machine. Check for anything that could be blocking the dirt fro going into the bag. Hope this helps Chris
Feb 20, 2011 | Dirt Devil Vacuums
Dirt Devil R088100. Cloth Was Sucked Into Hole Below Dirt Holder
Brad, Hopefully it is the belt that you smell burning. I would start by removing the underneath side of the vacuum head. Normally just a few screws that are meant to be remove for general maintanence and circumstances such as this. After removing the screws this should reveal the dirty side of life to you. You may need to remove the roller brush, and inspect the ends to make sure the brush rolls freely while holding the ends. If not the ends may need to be cleaned of hair and strings: ends should pop of and a shaft runs through the middle connecting them. Clean and replace. Move on up the path the dirt travels. The neck where the head and vacuum come together is the next jamming point, if this is where the cloth is lodged chances are the motor may have over heated due to clogging. Your vacuum may have a automatic shut off. You will need to contact Dirt Devil to see if there is a reset for the motor. There are propellers / fan blades at the end of the neck just before the motor housing. This is most likely where the clothe has logged itself causing the brushes on the electric motor to emit the burning smell, if you can remove all obstructions and the unit still does not turn on, check with dirt devil about the reset, Hope this helps.
May 25, 2010 | Dirt Devil Featherlite Bagless Vacuum...
My dirt devil bagged upright(swivel glide) wont turn on..light on
  • its clogged that is what the light shows is that if your vacuum is clogged then that light will come on and it will shut off, i have the same vacuum and mine does not come on cause its not clogged
Mar 09, 2010 | Dirt Devil SwivelGlide Bagged Upright...
Vacuums Logo
66 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
