Question about Dishwashers
My jenn - air dishwasher (installed 3 yrs ago) is leaving residue in the dishes & glasses. Is there a pump or filter that needs to be cleaned and can I reasonably do that myself?
  • Dishwashers Master
  • 43,501 Answers
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Sep 07, 2010
Dishwasher is going on 3.5 yrs old, it worked well for the 1st year but for the last year & half it has been leaving gritty residue on all the dishes. To the point, dishes are being hand washed to...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101//
Mar 22, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
My Jenn- Air dishwasher (2 years old) used to clean great but now it is leaving a white film on the dishes and there is often residue left in the glasses as if it is rinsing with the dirty water. I can't...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Dishwasher Residue and Film on Dishes
heatman101
Nov 20, 2010 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
#1 Dishes and glasses are not clean. Glasses come out with *** film. #2 Cascade gel soap residue in cup dispenser and on dishes close to it. #3 Not drying glassware in upper rack. #4 Black ***...
heatman101
Jul 14, 2010 | Kenmore 24 in. 17602 / 17604 / 17609...
Dishes and glasses not getting clean. Visaul inspection; it lloks fine. Removed filter and bottom perforated filter panle and cleaned off mineral-like residue. ran test program: result flashing lights for...
heatman101
Jul 03, 2010 | Bosch 23 in. SHU3307UC Built-in Dishwasher
Dishes not getting clean. I use Jet Dry &
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Oct 21, 2009 | Kenmore 24 in. 17039 Built-in Dishwasher
It is not cleaning dishes, it leaves food residue on dishes and deposits small bits to other dishes especially on glasses.
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Jul 15, 2009 | Jenn-Air 24 in. JDB1080AWS Built-in...
Food residue on all dishes
The filter systems on the Maytag line of dishwashers which includes Jenn Air is very fine. In most causes the pump needs to be torn down and washed in a sink and a shop vac is also a great tool I use to clean the rest of the pump out that will actually stay in the dishwasher. The spray arms also need to be cleaned in the sink. Check your drain line under your sink as well and make sure that the drain line coming from the dishwasher has a high arch or bend that is higher than the base of the sink. This will prevent sink water from backing up in the dishwasher which can be nasty. Also make sure to run your hot water to the sink before starting a cycle to assure hot fills and the water temp. is best if set at 130 degrees on your water heater instead of 120 or 125 degrees. I hope this is helpful. This kind of problem can be agrivating to solve at times. Scott (North Caolina)
Apr 20, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher does not clean dishes and leaves spots on everything!!
You need 2 things. Slightly hotter water and a rinse agent. If you don't heat dry your dishes, crack the door 3 or 4 inches after it's done, to let the steam out.
Mar 04, 2009 | KitchenAid KUDK03ITBK Built-in Dishwasher
Dishwashers Logo
80 people viewed this question
Top Dishwashers Experts
