Question about Luhr Jensen Little Chief 9800
My little chief burner is not working, this happened before and I fixed it by putting the element in the oven. I can't remember what temp and how long in the oven. do you know the solution?
2 Suggested Answers
sean1dave
  • 7 Answers
SOURCE: need a heating element for little chief smoker
Any sporting goods store should be able to provide you with one. In Spokane Washington replacement parts can be found at White Elephant. I had to replace my element and found one there for around 14.00.
I got mine at Store 2 but am sure that #1 also has them. I have attached a link. In no way am I advertizing a particular store, rather I am giving you a link to someplace I know carries the replacement parts.
http://www.whiteelephantstores.com/
Addresses and phone numbers as well as contact info is listed in their website. Good luck.
Posted on Mar 07, 2011
I am having a problem with my Frigidaire Oven
sounds like you're on the right track. Should work just fine after you replace the element. If it doesn't, order the electronic oven control and the overlay. without the overlay, you won't know what buttons to push
Nov 17, 2015 | Frigidaire Kitchen Ranges
On my Ge electric oven, sometimes it starts but after 3-4 seconds it shuts down and the true temp light flashes, but most of the time when I push the bake button the true temp light just flashes.
Oven comes on and off intermittently or heats very little:
If the timer feature is activating and you have not touched the timer button at all, this would have to be a failed Electronic Oven Control. The timer button is either shorting at times or closing on its own from heat or moisture. The Electronic Oven Control would need to be replaced to repair the problem.
Or Why does it take the oven so long to bake?
When the food is taking way too long to bake, it's probably a weak bake ignitor. Replacing the ignitor usually fixes this problem, but you probably want to verify that the ignitor is the problem before replacing it.
Sometimes the oven thermostat or oven sensor can be calibrated wrong, or it may be faulty. If your particular range has an oven that uses an electronic thermostat, and the oven temperature is off by tens of degrees, you probably have to replace it.
On most units that have a mechanical thermostat, you can actually remove the thermostat knob, and adjust the knob to more accurately represent the actual setting of the thermostat. On many models, there's a screw on the back of the knob with a small calibration plate or ring. You can loosen this screw and adjust the calibration plate. Remember to tighten the screw again. If yours isn't adjustable, and the temperature is off by a large amount, you should just replace the thermostat.
Or Oven safety valve needs to be checked with multi meter ohms / voltage
ALSO Test the Burner Heating Element
The stove's burner heating element is a coil of metal sheathed in an insulator. Electrical current travels through the element. Resistance to the passing of electrical current causes the element to heat up. A precise temperature cannot be set for a burner, instead it is turned on and off repeatedly by the control to the achieve an average temperature. When it is set to a low temperature, the element is cycled on and off more frequently. For high temperatures, the heating element is energized longer with fewer on and off cycles. Some burners have two elements, with the second only being used only for high heat settings.
Before testing the heating element, unplug the appliance or shut off the power at thefuseboxorbreaker panelto avoid an electrical shock hazard.
When a burner does not heat at all, or only heats up to a lower than expected temperature, the problem is likely to be with the heating element, the temperature control switch, or the wiring. If it only heats at the highest temperature, the problem is with the control or an electrical short, not the burner. If the burner works only intermittently, the problem is likely in the wiring or connectors. To test the heating element, try the following steps.
First, disconnect the heating element from the stovetop. In most cases, this is done by lifting up the burner on the side opposite of the terminals (the part of the burner that disappears under the stovetop). Remove the decorative ring.
Inspect the style of connection. If the burner element has visible blades that fit into the receptacle block, pinch the block with one hand, and pull the heating element free with your other hand. If the terminal block clamps over the element, the housing must be removed and the burner wires disconnected. Unsnap the metal piece or remove the screw that secures the receptacle block and then disconnect the element.
Inspect the heating element. If you find bubbles, warping, or damage to the insulation sheath, the burner must be replaced. If the terminals are dirty or corroded, this can cause poor temperature control, intermittent problems or complete failure to heat. Clean the terminals with steel wool or very fine sand paper to restore good conductivity.
Test theresistanceof the heating element using amulti meter. Set the multi meter to the ohms setting X1 and touch one probe to each of the terminals. A normal reading is typically somewhere between 20 and 120 ohms. The exact reading differs by manufacturer and mode. If the meter reads infinite resistance or the other extreme of the scale, zero resistance, then the element is damaged and should be replaced. If the measured resistance differs significantly from the expected range, the element is probably bad, but if possible, determine from the manufacturer what the actual resistance should be.
To test for a grounded or shorted element, touch one probe to the surface of the burner and the other probe to each terminal in turn. If you get continuity at any time, the heating element is defective and should be replaced.
The reason for my free advice is GOD is good!
Jun 04, 2015 | GE Ovens
My oven keeps cutting out (fan stops and heating) but it isn't at the temperature selected on the control knob. Sometimes it goes up to temp, sometimes it stops a LOT lower.
Apr 30, 2015 | Belling Ovens
I need a new electric heating element for my Little Chief smoker
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Dsporting&field-keywords=Little+chief+replacement+element&rh=n%3A3375251%2Ck%3ALittle+chief+replacement+element Here is one source....
Jan 15, 2013 | Grilling
Ge electric oven will not turn on
Hi Shane I need a little more info , like dose the broiler work ? dose the burners work , most times if the lower element isent working it has burn out , this is a cheep easy fix, look at the element with a flash light for damage it will have bump's on it or could be broken right off , this is the first thing to check , If it is the element I can locate you one to order and tell you how to change it but i will need the model and serial number and also is it the top or the bottom element , get back to me, and please always remember to rate this question: thanks Frank
Dec 13, 2011 | Ovens
Magic Chief "Chateau" double oven,
I just had the top completely off of our Magic Chief, which I love and refuse to part with, to fix a problem with one of the burner switches. I believe if you pry up gently in the crack in front with a blade, i.e. small pry bar or screwdriver, being very careful to not chip the paint, the top will snap loose from the two prongs that hold it in place. Then if you disconnect the cluster of wires going to the burners, which is very easy to do, (they just plug together) and remove one screw holding the ground wire toward the back, you can lift off the whole top and get to all of the good stuff. I find the quality of our old Magic Chief Chateau to be of exceptional quality, much better than I see today and I'm pleased that our burner problem was just loose screws. Good luck.
Jan 02, 2011 | Magic Chef Kitchen Ranges
My Kelvinator oven is not working. I've checked the fuses and it is getting power. The 4 burners of the stove still work and I'm getting an occassional flicker of the little orange light if a switch the...
Kelvinator oven not heating? How to replace a kelvinator fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. You searched for KELVINATOR element How to Repair Home Appliances
May 12, 2010 | Ovens
Have a ge 30 inch self cleaning stove that is putting up a f2 code
The F2 code is the computer indicating an oven over temp - it exceeded 590F with door in unlocked position or 990F with door locked. If actual temp condition occurred, you could have a bad relay, in that it isn't shutting the heating element off, thus letting it over temp. If you're able to visibly inspect the relay, (can't remember its actual location...You may need to trace the wiring back from the element. I'm sorry!) look to see if the relay contacts are actually "welded" together. This is something that can happen, thus keeping the element on all the time.
Another possibility is that if the code were set and the oven did NOT overtemp, you could possibly have a failed temp sensor. You'll see it inside the oven. It's a probe that sticks out usually from the back of the oven cavity. It's an easy replacement and you can find it at most appliance parts stores.
I hope this helps you in fixing your oven! Please let me know if I can be of further assistance. :)
Jan 17, 2010 | Kitchen Ranges
TOP BURNERS WORK BUT OVEN DOES NOT WORK AT ALL.
Sounds like a heating element. Same thing happend to my oven. You can find them around 50-60 dollars. Veryy easy to install, just remove a couple of screws and remove old element and put in new one. Make sure you shut off power to oven firstg of course.
Oct 08, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Grilling Logo
118 people viewed this question
Top Luhr Jensen Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Are you a Luhr Jensen Grilling Expert? Answer questions, earn points and help others
