Question about Baby Gear
Vw golf gt tdi
My husband is thinking of buying the above car 2002 reg but the passenger air bag has been deactivated. Any ideas how you reactivate this.
  • 2,039 Answers
Maybe its just disconnect you remove the air bag visuale inspection is needed some people disconnect the air bag on passager because of children be carefull if it not that its expensive to repair good luck pierre
Posted on May 13, 2008
Hi i have lost my handbook for my 56 reg vw golf gt tdi 140 on the door column there is a button and i dont know wot it does any ideas, in fact i could do with a copy of the book many thanks Chris Mitch
if its a picture of a car with lines above it its the deactivation switch for the interior sensors for the standard factory alarm. one switch before arming deactivates and i think they'll reset automatically once disarmed if not just press button again. hope this helps
Jul 24, 2010 | 2006 Volkswagen Golf
2002 VW Golf TDI open door light & alarm
check door switches remove 1 at a time and unplug it once you find the bad switch lights will go out
un plug 1 at a time
Jan 22, 2010 | 2002 Volkswagen GTI
Golf GT Tdi 115 - performance when warm.
you dont say what miles the car has done.but you should now be using semi synthetic 20/50 oil and try using a fuel additive(redex/wynns)to clean the injectors.if you are using oil it is possible that the engine has lost some of its compression due to ring/valve wear.did you know that to convert your engine to a 130/150bhp unit,you only need to change the ecu try"diesel tuning"website.....
Dec 21, 2009 | 2000 Volkswagen Golf
Interior light bulb on vw beetle
I had the same problem. Found the solution online - The Golf Mk IV has the same fittings. Pictures here: http://uk-mkivs.net/forums/t/255147.aspx
Apr 04, 2009 | 2000 Volkswagen Jetta TDI
VW GOLF MARK 4 Y REG
Hey mate i think your problem is the air flow mass sensor its a black box which its on to the big hose that gose in to you air filter it has a wire with a multiplug on it . you can disconect this then take ur car for little drive few miles and if the car is not being wore than it was before you need to go buy one quite expensive
Mar 04, 2009 | 2001 Volkswagen Golf
VW Golf 2004 2.0l GT TDI
We think it could be the engine management system - would recommend going to a reputable garage for it to be reprogrammed.
Sian
Aug 21, 2008 | 2004 Volkswagen Golf
TEmperature gage goes up and down telling me to check coolant air bag faulty comes up and hot air goes hot than cold and hot , also there is coolent in the car
Sounds like a bad thermostat. Its either stuck open or stuck closed. Get it replaced ASAP before you do damage to the engine.
Aug 17, 2008 | Volkswagen Golf Cars & Trucks
VW Golf GT GTi 2L start problem
worn coil pack?
its a problem with some golfs
type worn coil pack golf tdi on google and you should see everything on it. i think theres an uprated set out now don't quote me on it tho!
Jul 05, 2008 | 2004 Volkswagen Golf
Baby Gear Logo
93 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
