Question about Dishwashers
I have a GE Quiet Power 3 built in dishwasher. With 1 min. left in a cycle, I opened the door, removed an item, then closed the door again, but it didn't finish the cycle. The machine continued its single beeps to indicate the door was open. Reopened and closed the door. None of the buttons on the control panel respond. Have unplugged and left overnight, plugged back in, beeping continues.
  • 4,323 Answers
Hi
The beeping comes from a cycle trying to start and then not being able to complete. Try pressing Dry button for 5 seconds and check if the beeping stops. Also, try holding the reset button for 30-40 seconds to check if it stops the beeping. If this doesn't stop then you would need to replace the sequencing switch. Check out the link for how the sequencing switch looks like-- Sequencing switch Another link, part#904 is the sequencing switch--- Seq Switch GE dishwasher Hope this helps... If it does please do not forget to accept the solution or post back for assistance. Daniel
Posted on Sep 05, 2010
Dishwasher runs with door open
the door switch has failed. This is a problem because if you or someone else opens it while it is on, they could be burned by hot water.
May 31, 2013 | GE Dishwashers
I need to know what the buttons say on the dishwasher. Mine have no letters
Some SHX46 washers have 4 wash cycle buttons and others have 5. The button on the left side on top of the door is the start/stop button regardless of how many wash cycle buttons you have.
If you have 5 cycle buttons, reading from left to right they will be as follows.
1. Top Rack Only / Sanitize
2. Power Scrub Plus - (Long wash for heavy soil)
3. Regular Wash - (Economy wash for light to medium soil)
4. Delicate Wash - (Shorter wash at a lower temperature for delicate items)
5. Rinse & Hold.
These buttons are also used for cancelling a wash cycle. Hold down buttons 2 and 4 (Power Scrub Plus and Delicate) at the same time to cancel a wash cycle and drain the water out.
If your washer does have 4 buttons, it means you don't have a Top Rack / Sanitize cycle, in which case the button configuration - from left to right - will be:
1. Power Scrub Plus - (Long wash for heavy soil)
2. Regular Wash - (Economy wash for light to medium soil)
3. Delicate Wash - (Shorter wash at a lower temperature for delicate items)
4. Rinse & Hold.
With this button configuration, the cancel cycle buttons are 1 and 3.
I hope this solves your problem. If you need any additional information, please post back.
Regards,
BElectric
Dec 12, 2010 | Bosch 24 in. SHX46B05 Stainless Steel...
Door leaks at the bottom of my ge profile dishwasher
1 has the machine been pushed into the cupboard hole,this will push the door away from the front of the machine,does it hit the trim around the opening before the closeing?pull out check under are the legs still straight,some you can remove the lower front panel to look under
Dec 02, 2009 | GE Profile PDW8400J Built-in Dishwasher
Opened door during cycle, latch now stuck in closed position, can't re-close
twist a paperclip around some pliers so you have a circle opening. then hook the paperclip around the latch and pull outward with the pliers. once the latch is facing outwards the door should close again
May 30, 2009 | Bosch Evolution 500 SHE45M06UC Built-in...
Soap dispenser cover won't close
It sounds like it may be stuck between cycle steps.(this sometimes happens if the washer is open during a cycle)Try and run it through one full wash cycle as it is.Then check to see if the soap door will close.If not,the lack may be broken
Jan 09, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Ge dishwasher not drying
1 make sure heated dry is on.
2 run your cycle and when it says drying open the dishwasher. see if it has steam coming out.
3 give me your whole model number.
4. if heater is not turning on then you may have one of three issues.
1. Bad door switch
2. Wire off element or bad thermistat
3. No power going through the control. to the heating circuit.
Jan 07, 2009 | GE ADW1100N Built-in Dishwasher
Whirlpool gold start button flashing dishwasher won't start
press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
Oct 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool quiet partner III
Hello bckp,
Welcome to Fixya
If your dishwasher does not run or stops during a cycle
Is the Start/Resume indicator flashing? Opening the door or
interrupting the power stopped the cycle. Close the door and
press START/RESUME.
Does the Start/Resume indicator flash 3 times when you
press START/RESUME? The dishwasher is waiting for you to
open the door after the last cycle. Open and close the door,
then press START/RESUME.
Is the door closed tightly and latched?
(NOTE: On models with a dual-digit display, the control
displays “- -” during a cycle if it believes the door is not
latched.)
Is the right cycle selected? Refer to the “Cycle Selection
Charts.”
Is there power to the dishwasher? Has a household fuse
blown, or has a circuit breaker tripped?
Has the motor stopped due to an overload? The motor
automatically resets itself within a few minutes. If it does not
restart, call for service.
Is the water shutoff valve (if installed) turned on?
It is normal for certain cycles to repeatedly pause for several
seconds during the main wash.
If the dishwasher will not fill
Check the overfill protection float that is able to move up and down
freely? Press down to release.
Let me know if any of these procedures helped you?
Huuum
Please remember to leave a rating.
Oct 04, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Ge quiet power 3 dishwasher
According to the GE repairman who visited, the solution is to close the machine (with the lights flashing). The machine starts and goes through the cycles, which it does rapidly and then all the lights turn off and the machine becomes silent after 1-1/2 to 2 minutes. Then the machine has been reset to normal. During this reseting period nothing happens inside the machine, although you may hear a running sound.
Thus, the solution is to run the machine in this flashing light state for the 1-2 minutes it takes to go raipdly through each cycle and then reset.
I hope this helps.
Oct 09, 2007 | General Electric Adora GHDA670N Built-in...
Dishwashers Logo
88 people viewed this question
Top Dishwashers Experts
