Question about Dell Computers & Internet
Help please! My computer crashed during a power failure and I had to reinstall Windows XP after reformatting the hard drive as nothing else would work. I was then unable to connect to my BT Broadband and was told that I would need to re-install the drivers. I bought the computer second hand and have no extra CD with drivers. The BT helpline said I needed to find the drivers for that particular motherboard. I have opened the computer up and have several different numbers on the motherboard. Which one do I need and how can I progress this? I am using another computer at present so could download onto a digi stick and install from there. Please help. Many Thanks Mandy
  • Dell Master
  • 27,725 Answers
Depending on the brand of coputer/motherboard
it should the one with large letters /numbers closest your cpu with a version no.
hope this helps
Posted on Sep 05, 2010
I have a HP G7-250CA in which the Hard disk crashed during a bios update. I have put in a new hard drive and now want to do a fresh install of Windows XP as I do not have the recovery disks. I keep...
Hi
can you please explain to us how the hard drive crashed during a bios update ?
or how do you know that the hard drive crashed during bios update
many thanks
And did you try to reinstall windows while original hard drive was still in the laptop
did you press the F11 key as soon as you pressed the power on key
Mar 07, 2011 | HP G70-250us Notebook
Dell 6400 hangs and then crashes
Try replacing or upgrading your RAM it sounds like your PC is overworked and the bsod is probably a result of data loss due to low ram
Aug 18, 2008 | Computers & Internet
Error "Setup didn't find HDD"
Well, first of all XP is not the latest supported operating system from Microsoft.
That being said, I have not had a garbled screen followed by an error message 'setup didn't find any hard disk drive installed' on a laptop, in my limited experience with laptops (i.e. Acer One, Acer Aspire, Sony Vaio, etc.)
If you have an unexpected garbled screen it points to the pc board or mother board or the video card, but more likely the motherboard.
And, if you couple this with the hard disk drive not being detected, it reminds me of a situation where I had a no hard disk drive detected on a SCSI drive connected to my Windows 95 computer in the 1990s when I had heat related issues with the circuitry on the hard drive getting burnt out capacitors.
If the drive is not recognized, it might mean the boot sector is wiped, and essentially it needs to be reformatted and the operating system needs to be reinstalled (which you evidently tried to do).
To my memory, I never had this problem on Windows XP with a laptop, so I am thinking it's not Windows that is at fault, but the physical hardware is giving you problems.
If you boot from the CD for Windows XP and it doesn't find the drive, it's a big problem for this laptop.
I wish you luck in finding an answer to that one, seeing that it's out of warranty and XP is no longer supported by Microsoft.com.
Jul 19, 2010 | Fujitsu Siemens AMILO Pro V2000 Notebook
My laptop had been working fine, then the last
Hi yes try this, if no joy come back to me.
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To install new version of XP. Insert XP CD into drive, reboot pc pressing ESC button, or delete in some machines. This takes you into BIOS, change your primary boot device to CDrom, save changes and reboot. Select boot from CD once this appears and wait for files to be installed. Select the part of the hard drive you wish to use for your operating system (usually the largest) and select partition this drive. Delete any previous os, and reformat hard drive. (Be aware this removes everything saved on your hard drive, so always back up first) Re boot afterwards and reinstall operating system.
Jul 10, 2010 | IBM ThinkPad A30 Notebook
Acer Power SV, I need to reformat but no Wn Xp disc
buddy you have to need xp window cd you can buy it or take from your freind without xp window cd you cannot install window.
Oct 20, 2009 | AcerPower SV PC Desktop
LG GSA-E60L doesn't work...
Disc drive has nothing with drivers it works in almost any operating system...check the power and data cables
Feb 03, 2009 | LG SecurDisc 20x External Double-Layer DVD...
Boot failure
y first guess is that something is wrong with your motherboard. Start with checking that. Then if that is ok, check your hard drive because it may have gotten corrupt or even crashed. If that is ok, try reformatting your hard drive and reinstalling your operating system. Hope this helps.
Sep 13, 2008 | Toshiba Satellite A135-S4527 Notebook
Powermate ES setup cannot find hard drive
Do you have the recovery discs that originally came with the computer? If you do, I would use these to reformat the hard drive and reinstall windows. This would be the fastest option.
To do this:
Insert the disc into the CD-ROM
During boot-up and before the 'Use last known good configuration screen' you're speaking of, it'll ask you do 'hit a key to boot from CD' -- Do so
Follow the on-screen instructions. Your objective is to clean the hard drive completely (reformat) and reinstall windows (recover).
If you do not have the recovery disc that came with the computer, you can use the exact same steps above with a Windows XP disc. Be sure to 'format' and 'install' windows--not just 'repair.'
Re-boot computer when all finished.
Dec 01, 2007 | NEC PowerMate ES SlimLine PC Desktop
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
