Question about Philips 27PT5445 27" TV
Turning off My TV will turn off in a few mins, everytime I don't know why?
  • William Beer May 11, 2010
    As I said the (LO3) chassis goes into shut down after 5 minuts and I believe it is a regulator problem but I do not have a print so could you give me the voltage readings that are nomal. THANK YOU.BILL
Wrong
Posted on Oct 14, 2008
  • 58 Answers
Something is overloading the power supply or you have a cold solder joint some where on the circut board.
If you are a tec. look for over heated marks on the board.
hope this helps
Guy9
Posted on Jun 19, 2008
I have a 2001 chevy malibu. It will not crank nor turn over. Its not the battery I just replaced it. The theft light does not stay on (it goes off when all the other light go off). I have tried turning the...
I think i know the issue. I have had it happen to me it is your security system failing. Your car is on the list year make and model... I found a module that you can install yourself and it will bypass it allowing your car to start everytime.. Check it out and ask questions they are very helpful. Also for some reason if it does not work they will refund you %100 of your money.. this literally saved my car. Hope it helps
http://vatspasslockpasskeysecurityhelp.com/ Do It Yourself GM Security bypass
May 09, 2017 | 2001 Chevrolet Malibu
There is a vibrating noise everytime I flush the toilet or wash clothes. It's only for an instant. I have one of those big blue water regulator tanks on my hot water heater in my garage. I don't...
I've found that excessive water pressure in the pipes can cause vibration and phantom sounds coming from the plumbing. If water pressure seems to be excessive, adjusting down the main supply line can be a easy as turning as turning the main valve a few degrees in either direction.
Sep 04, 2011 | Computers & Internet
SAMSUNG LE40M86BD kept clicking for 30 mins when turning on....i replaced copacitors 1000uf 35v all 4 of them. Tv turns on and works normal. But on start up, it blinks red light 4-5 times before turning...
Tv power supply board still have more problems and dying components parts test more and replace more capacitors parts,not all capacitors parts are weak and dying are showing up bulges or puffing up.Test all capacitors components if any not showing the correct Micro Fared and voltages replace it should shoved this problems.
Aug 19, 2011 | Televison & Video
Soyo Tv keeps on turning self off.
Call your manufacturer if you are still under man. war. they can replace/repair the unit for you if not they can give you some referrals. Sounds like your powerboard is going to go out on the unit.
Aug 07, 2009 | Soyo DYLT032D 32 in. LCD Television
My Tv is turning off by itself
unplug and let sit for a min then plug back in
Jan 01, 2009 | Televison & Video
I have a 37" Polaroid tv. About 2 months ago when turning on the tv there would be a humming noise for about 15 mins, now the tv won't come on at all. I've trie d replacing the fuse but it continues to...
The humming noise is produce when the power supply is trying to compensate the other circuitry's demand for proper power getting to them. The problem is that the capacitors have lost their dielectric capabilities and are not able to filter and provide a clean power in a timely manner.
Let me know if you require further assistance.
Dec 12, 2008 | Polaroid FLM-2601 Television
Tv turning its self up?
is it showing it turn its self up on the tv by the bars or is the sound just getting louder by itself
is your remote a learning remote and does your tv have a preset volume that when turned on its to goto
if showing by bars one of the buttons on your remote is stuck or needs cleaning and
quite possibly getting an outside frequency thats interfering with your remote frequency
but if no bars are showing the service provider company i noticed my self there tv programs are flauxing in sound for some reason this to me gets annoying
May 29, 2008 | Olevia LT27HVX 27 in. LCD Television
TV just turns off
Most common reason for this problem is dry joints, ie cold/bad solder joints.
Capital98
Nov 16, 2007 | RCA 20F512T 20" TV
Philips 27PT5445 27" TV Logo
102 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
